Question about Philips 9P6040C 60" Rear Projection Television
Picture size decreases and increases with non uniform edges
On power up the picture is about one third the size of the actual screen size. The edges of the picture that is displayed are non uniform and almost have a rounded appearance. The picture displayed increases and decreases in size at random. After the set warms the picture gets larger and becomes more stable. However the full picture size is never achieved.
  • 4 more comments
  • learmech Sep 15, 2007
    This is a Phillips Magnavox 9P6040CI
  • learmech Sep 16, 2007
    This is a conventional three tube rear projection. Thanks for your question!
  • Anonymous Nov 10, 2007
    Same exact problem!
  • michael50 Nov 14, 2007
    We have the same problem, what do we need to do to fixthe picture?
    The model is C101
    Please email [email protected]
  • TVTOM Nov 29, 2007
    Same issue. Did anyone ever find out how to fix this? Was it the convergence issue?
  • Anonymous Nov 16, 2008
    1. My screen has shortened on the right side. I need to no how to adjust it with the remote.
    Thanks!
  • Philips Master
  • 3,459 Answers
Common problem. If its warped but stationary I would agree its most likely the convergence chips.
If however it shrinks/expands its most likely the opt chip. You can get a repair kit from www.magnavoxhelp.com for this common problem. Other symptoms may be no audio/video but this problem typicaly happens after you encounter the 1st problem ( shrinking/expanding video)
Posted on Sep 27, 2008
  • Edward
    Edward Oct 12, 2008
    If you have any of the following problems you may want to check the site www.tvrepairkits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
    Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
    (Note: The below symptoms typicaly occurs after having the expanding/shrinking screen problem above)
    Symptom: No Audio or Video but power light is on
    Symptom: Audio works but no Video. Power light still work
    Symptom:  No Video. Audio is intermittent. Power light still works
  • Edward
    Edward Jan 26, 2009
    Common problem and fairly easy to fix.
    Problem
    Solution:
    Check with the site www.TvRepairKits.com. They have built a kit to fix this problem.
    Scholar:
  • 136 Answers
Is this a DLP or a conventional 3 tube rear projection?
Posted on Sep 15, 2007
  • Beau  Delony
    Beau Delony Sep 16, 2007
    Sounds like a convergance IC problem, Either replace the convergence IC's or replace the convergance board.
SOURCE:
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Entire Gimp window is too big, cannot re-size
go to control panel display and do the resizing then in the pixel settings
Feb 12, 2018 | GIMP GNU Image Manipulation Program
Cannot see full picture mitsubishi
Look for a button on the remote that says either P-Size, Aspect, View Mode, Zoom or Ratio. Press the button on the remote to change the size to Stretch, Full etc..
www.aaatvservice.com
Jun 26, 2012 | Mitsubishi Televison & Video
Can you make horizontal pictures fit the frame
I'll assume your picture is already oriented properly (horizontally), i.e. you do not need to rotate it.
There are 2 modes for displaying the photo ... (1) the ORIGINAL mode - displays the photo in actual photo size, which may result in part of the photo not being visible on the screen, or, (2) the OPTIMAL mode - which reduces the size and resolution to best fit the screen.
To set image size mode, select the SETUP on the HOME screen display, then highlight and select the DISPLAY IMAGE SIZE button, and go from there.
The first (ORIGINAL) mode is usually the default mode. When you select the OPTIMAL mode, the picture will be scaled to fit the size of the screen ... but you may see "dark" bars (e.g. on top and bottom of the screen) if your picture does not fit the exact screen size.
Jan 02, 2011 | PANDIGITAL 8.0" Digital Photo Frame...
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
Picture size exceeds TV screen
If you are also using a Cable Box, make sure that the zoom selection, (Format) ,on the Cable Box remote is set properly. Especially if the TV Remotes Aspect Ratio is set to a Wide Format.
Hope this helps,
Skyassoc
Oct 20, 2009 | Televison & Video
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Screen is all shrunken and in one corner...Convergence Problem... i think
I had the same issue. The screen would shrink and then expand over and over. After thrity minutes it would correct itself.
After a few months of doing this it just broke - no sound and no videe but the power light was still on.
I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
Apr 18, 2008 | Philips 9P6040C 60" Rear Projection...
Philips 9P6040C 60" Rear Projection Television Logo
209 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
