Question about Lexmark C510 Laser Printer
How do I clear the memory for the Lexmark c510 printer when I receive a memory full warning?
  • dheerendra_p May 20, 2009
    38 memory full error
  • 300 Answers
This is from the service manual, unfortunately there isn't a cold reset, you can perform an EP factory reset in the diagnostic mode, but this won't cure your problem. Investing in some more memory is the best answer
Press Go to clear message
and continue printing job. Job
may not print correctly.
Press Menu to open Job Menu
and cancel current job.
To avoid this error in future:
• Simplify print job by
reducing amount of text or
graphics on a page and
deleting unnecessary
downloaded fonts or
macros.
• Install additional printer
memory.
Posted on Apr 24, 2009
Fax memory full lexmark x
Memory full, cannot send faxes
The printer fax memory is full. Press the check mark button to clear the message and cancel the fax.
• Reduce the fax resolution and try to send the fax again.
• Reduce the number of pages in the fax and try to send the fax again.
http://www.edvdrucker.de/Downloads/Handbuch/Lexmark/Lexmark-X254-User-Guide.pdf
Jul 09, 2014 | Lexmark X364dn All-In-One Laser Printer
My Lexmark C510 Laser Printer was giving me- 83 Photodev Cart Warning so I replaced Photodeloper but printer is not recognizing that I replaced it
To specify which supply has been replaced:
Make sure the printer is on and the Ready message is displayed.
  1. Press and release Menu until you see Supplies Menu, and then press Select.
  2. Press and release Menu until you see Replace Supplies, and then press Select.
  3. Press and release Menu until you see the relevant item:
      • Yellow Toner
      • Magenta Toner
      • Cyan Toner
      • Black Toner
      • Photodev Cart
      • Fuser
  4. Make sure the item you replaced is on the second line of the operator panel. Press Select.
  5. Press and release Menu until you see Replaced, and then press Select. The Saved message appears.
  6. Press and release Return until the printer returns to the Ready state.
Feb 14, 2012 | Lexmark C510 Laser Printer
Lexmark C510 printer doesn't print yellow color.
Try the old one again. If this works you have a defective new catridge. This sometimes happens.
Feb 20, 2010 | Lexmark C510 Laser Printer
2 of 4 Lexmark c510 high yield cartridges are less than 100% ful
You could be right that you have just purchased a wrongly manufactured ink cartridges. Some manufacturers have a shipping issue called bad batches. You might have just got one of them. If the software says that you only have this much of ink, that is absolute. Possibly it maybe just a software cache where it still reads the previous reading. To clear the cache, simply turn off the printer and unplug the power for few minutes. You also need to restart the computer where the printer software is installed.
Jul 26, 2009 | Office Equipment & Supplies
My lexmark C510 printer keeps saying short paper but it is full. What is going on?
You may have too much paper in it.Take some paper out and try it again.
Jun 01, 2009 | Lexmark C510 Laser Printer
How do you open the rear door of the C510 to clear a paper jam?
Hi I hope you have this solved already... but you just grab the edges and pull from the top sides. It feels really weird, but it will be fine.
Mar 30, 2009 | Lexmark C510 Laser Printer
Error message 83 - photodev cart exhausted
The photoev cart is the photo developer cartridge.
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Dec 08, 2008 | Lexmark C510 Laser Printer
Lexmark c510 error message ;83 photodeve cart missing
See User Reference
pages 184 and 185
"Message:
What you can do:
Continuing below
Message:
What you can do:
Continuing below
Message:
installed.
What you can do:
Nov 26, 2008 | Lexmark C510 Laser Printer
Error #82 Waste Bottle full or missing for Lexmark C510--printer will not print
clean out inside of waste bottle.
reason: ink on the side interrupts a lazer which then sends a message to the printer that the toner if full when it is not. If this doesn't work dust around the area around the waste bottle with a clean paint brush
Jack Hneriques
Jul 31, 2008 | Lexmark C510 Laser Printer
CODE 38 mEMORY FULL
A laser prints a whole page at a time, some pictures or pdf's require more memory than is installed on a original machine, you can buy additional memory modules to install on your printer which will allow you to print the entire document. I bought two 1 meg modules for about $50 each and have not had a problem since. Check your user manual or the lexmark web site to make sure that you are getting the right memory. The lexmark memory is about half the size of normal computer memory.
Dec 07, 2007 | Lexmark C510 Laser Printer
Lexmark C510 Laser Printer Logo
885 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
