Question about Belkin Computers & Internet
My computer won't wirelessly connect to my computer. It keeps saying 'Acquiring network address'.
  • rockleemaple Apr 15, 2009
    how do i do that?
    Genius:
  • 1,268 Answers
That means you didn't enter the correct network key when connecting to your wireless network. If your wireless network is not password enabled, you need to change the wireless channel of your router by accessing the router's setup page.
Posted on Apr 15, 2009
The wap54G is having issues. Computers trying to connect to it keep acquiring ip address and never connecting. Any advice on what might be wrong?
Hi williamrayes,
If you have a message that acquiring ip address you can Power Cycle the router for 2 minutes then try to connect again or you can try to check if the Network Key that your typing is correct (If the connection is secured). You can check the Network Key of your router by accessing the Wireless Settings Page of your router. To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security, You can personalize the Network Key if your want. Save the settings then try to connect.
Rate me if this helps so I can help others.
Thanks for using Fixya.
Feb 04, 2011 | Linksys Wireless-G WAP54G 802.11g/b...
Says i am connected but when i open firefox it says that i have no network connection... the wireless icon also says it is acquiring ip address
if the message aquiring ip address comes in computer then it says that the wireless router is not giving an ip address to your computer.... check if any static ip address is assigned to your wireless connection...if so change to "obtain ip address automatically".... right click on wireless network name> goto properties > authentication tab> uncheck "enable IEE athentication"
now try to connect again,still not restart the computer once...... this will resolve the issue.... still if it is not connected then check for the security settings in the router... if your computer is XP/MAC, it may not recognize WPA security type.... change it to WEP type and try to connect again....
Apr 19, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
I can not connect to my netgear wgr614v6 with my hp netbook. I can connect with my other laptop and the netbook has been connected before. It keeps saying "acquiring Address"
If you're trying to connect wirelessly, and it says "acquiring address" and never connects, it's most likely because your wireless network has an encryption key enabled, and the encryption key on your laptop/netbook doesn't match. You should disconnect from your home wireless network, and then try to re-connect to it. Verify that you're using the correct wireless key to connect. If that still doesn't work, you should reset your router to factory defaults so that there's no wireless key required to connect - and then try again. If you want to put the wireless key back, you can run the CD or connect to the router using the web interface and configure it again.
Mar 07, 2010 | NetGear WGR614 Router
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
My wireless network connection is always saying acquiring network address what should i do
Just wait and you will get an ip address. You will not get one if you are not associated and aunthenticated by the router.
May 08, 2009 | Computers & Internet
Set a Static IP Address on your computer to resolve the issue.
Mar 08, 2009 | NetGear WGR614 Wireless Router
Acquiring Network Address
reset the modem and the wireless router by powering them off for 30-60 seconds, then plug power back in. Wait a minute or so for the devices to reset then go to the PC and try to connect again
Good luck
Jan 26, 2009 | Dell Inspiron 2200 Notebook
I am trying to connect to the wireless in my new apartment. I have entered my network and password and that has worked fine. However, under Wireless Network Connection Status (i can get there by clicking...
On the Support tab - what does it say the "Address Type" ?
If its DHCP then check that on the TCP/IP properties;
If on "automatic IP address" then it wont take any entered IP address.
Do not put any IP address.
Check that "Obtain an IP address automatically" is checked and also "Obtain DNS server address automatically" is also checked. On wireless network tab check "Use Windows to configure my wireless network settings".
On preferred network check that your wireless network is there, if not add it and move it up
Cannot connet my laptop to he wireless router
If compuetr always saying acquiring network address you can try firt restarting the computer, but if still wont get a valid ip address, you need to adjust the wireless settings of the router and after that try to reconnect to the wireless network....
Oct 25, 2008 | NetGear WGT624 Wireless Router
Acquiring Address Problem
you will need to make sure that DHCP is enabled within the routers settings as this will tell the router to assign ip addresses automatically, then go to network connections, right click on your network card>properties>TCP/IP line>properties and tick 'obtain an ip address automatically', click ok, close window and restart pc.
Sep 24, 2008 | HP PAVILION A6230N DESKTOP PC
Computers & Internet Logo
287 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
