Question about Garden
Carburetor flooding,very hard to start,mixture very very rich
My troy bilt lawn tractor has a briggs and stratton 21hp ohv, twin V engine. Its running very rich,and its has become inpossible to get started,and when it does start,black smoke,till i run it up to fast setting. New plugs last week,and the fuel filter has put on last year,it has probably 50hrs on this inline fuel filter. Can the carb be adjusted my myself? Thanks Jaxon1949@triad.rr.com
2 Suggested Answers
  • 15 Answers
SOURCE: tory bilt lawn tractor replaced with new battery
What most likely happened is the diaphram in the carberator has burst. It is a simple fix if you take your time, use reliable resources and be patient. The parts can be picked up at the local hardware store.
Posted on Mar 25, 2010
Hard stating flooding
Search Results
    Rider mower carburetor flooding - help ! - YouTube
    ? 1:30
    https://www.youtube.com/watch?v=ZYqtKvLXYtY
    Sep 29, 2010 - Uploaded by Joyce Boncal
    It won't start. ... Rider mower carburetor flooding - help ! .... ( HOW TO ADJUST VALVES) FIX HARD TO START Lawn Tractorwith OHV Briggs ...
    How to stop a Briggs crankcase from flooding with gas Order ...
    ? 11:34
    https://www.youtube.com/watch?v=VhEiLMtPR5M
    Aug 5, 2013 - Uploaded by doublewide6
    If your tractor keeps leaking gas into the crankcase see how you can fix the problem by ... The hard starting is caused by fuel filling the cylinder.
    Basic Troubleshooting - Lawn & Garden Tractors - Cub Cadet
    cubcadet.custhelp.com/.../basic-troubleshooting---lawn-%26-garden-tract...
    Sep 13, 2002 - Engine fails to start, Engine flooded, Crank engine with throttle in FAST... Engine runs erratic or stalls, Tractor running with CHOKE activated ...
Jan 25, 2016 | Garden
Engine rpms is constantly going up and down.
Is the air filter clean?
Governor Ajustment Briggs V-twin - YouTube
? 3:12
www.youtube.com/watch?v=tOoArROpM_oJun 26, 2010 - Uploaded by IFIXIT4U The Briggs manual does not do a very good job. You have to adjust the tension on the two springs to set the RPMs that the engine runs at the low and high position. ... I really really need help guys my race motor has a 21hp vtwin brigs, .... Briggs & Stratton opposed twin carburetor series 1 of 3 disassemble ...
Sep 17, 2015 | Briggs & Stratton Briggs Stratton Intek V...
I have briggs and stratton powered mower with the 18.5 v-twin ohv intek engine modle 407777 type 0121-E5 CODE 000512ZYG MY PROBLEM IS THAT MY CRANKCASE IS FULL OFA GAS OIL MIXTURE THE OIL FILTER ALSO...
When the float in the carb sticks, it allows fuel to drain into the cylinder, that runs pass the rings into the crankcase. When the crankcase is full the pistons cannot go down, and the starter won't turn the engine. Drain all the oil gas mixture, and refill with proper oil. Replace float, needle and seat in the carb bowl. Throughly clean fuel passages, and bowl. If motor won't turn, remove spark plug and turn over engine a few times to remove gas oil mixture from the cylinder too.
Oct 02, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
Tory bilt lawn tractor replaced with new battery
Mar 25, 2010 | Briggs & Stratton Garden
Briggs and stratton platinum 5.5 hp ohv i/c engine
The carby probably has a block either in the idle, jet or float valve. These are both internal to the carby. To fix this, you will need to pull the carby off the engine and get it serviced by a tradesman. If you feel keen, split the carby apart, then run a very small drill bit (.38-.7mm) through the Jets by hand. Also spray carby cleaner in there and blow out with air blower.
Mar 14, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
21hp intek v-twin runs only with choke on full
You are not getting enough fuel.... by choking it you are enriching the mixture with less air , more fuel.Some where in the fuel system or carbureator something is still plugged.Or the mixture screw is too far in.
Oct 30, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
229 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
