Question about Sanyo PLC XU35 Multimedia Projector
I turn on my Sanyo Pro XtraX, with a bulb I replaced about 100 hours ago. The light is red on standy, turns green when I turn it on, but turns off and cools down after just a few minutes. this just started to happen last night after about 8 hours of continuous operation. help?
  • stix09 May 17, 2009
    i have the same problem, the projector keeps shutting down automatically after a couple of minutes. i have not changed the light bulb yet, what do i do?
  • kierplablo May 29, 2009
    thanks I'll try it and get back.
This happens to us at work quite often. Usually, it's just that the filters are dirty which doesn't allow the projector to cool and causing it to overheat. We just blow out the filters with a can of compressed air and it solves the problem.
Posted on May 28, 2009
How do i reset sanyo pro xtrax multiverse projector "replace lamp" error message
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 31, 2014 | Sanyo PLC-XE20 (Chassis XE2000)...
Sanyo pro xtrax projector
Lamp LED should be lit when the projector is in Standby. However, the problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Dec 09, 2013 | Sanyo Office Equipment & Supplies
Sanyo PRO Xtrax Multiverse Projector powers on but no reflection appears
broken lamp?? check for little cracks in the bulb bar.
If lamp is discoloured( dark grey), overheating is cause, no cooling after using the PJ.
Sep 25, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo PRO xtraX Multimedia Projector Mod.# PLC-XP1ONA
this is the normal condition> only when green led is off and warning temp led(yellow) is on something is wrong!!
Jun 08, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo Pro Xtrax PLC-XU50
Hi there
If you have the know how open up the machine and replace the fuse on the Powersupply board ( where the AC socket sits in )
If this still occurs , I'm afraid you will have to replace the Powersupply board.
Apr 09, 2008 | Sanyo PLC-SU50 Multimedia Projector
Image goes Dim
Hi there
Keep in mind that the light will only flicker if the bulb reaches a certain amount of hours or if it is damaged completely.
Try taking out the lamp and check on the inside of the shaft if you see any black vein looking marks on it or if there is a bubble at the bottom of the shaft - this normally causes the lamp to be very dim and will need replacement.
Mar 18, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo Pro xtra projector - warning light
We have a similar situation with our Sanyo Pro Xtrax. It will be on for about a hour and then the "warning temp" light would come flashing red, and the project would turn off on its own.
Feb 08, 2008 | Sanyo PLC XU33 Multimedia Projector
Sanyo Pro Xtrax
You need to change th bulb. It's damaged
Sep 03, 2007 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLC XU35 Multimedia Projector Logo
1,304 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
