Uniden Guardian with 4.3" Touch Screen Logo
A
Anonymous Posted on Sep 12, 2013
Locked screen - Uniden Guardian with 4.3" Touch Screen
Kristen Ruddell
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 18, 2014
Kristen Ruddell
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
141
Points
Hi i have a pad lock in a small grey box on my sreen and want to knpw how to get rid of it and also what it is?
  • Kristen Ruddell
    Kristen Ruddell Jul 18, 2014
  • Kristen Ruddell
    I think I gave the wrong hot mail accidentally, my gmail you can get me on and it is :[email protected]
I have a amazon fire hd 8 how can i chang the pic. on the lock screen please help
Select a lock screen scene or personal photo to display on the lock screen of your Fire phone.
  1. From Settings, tap Lock Screen, and then tap Select a lock screen scene.
  2. Swipe down through the available scenes, and then tap to preview the lock screen. Alternatively, tap Your Photo to select a personal photo to display.
  3. Tap the checkmark to set the lock screen or the X to cancel.
By default, your phone will rotate through all of the available lock screen scenes daily. To turn this feature off, tap Off next to Rotate Scene Daily at the top of the screen or select a specific scene.
Note: When the battery is low on your Fire phone, Dynamic Perspective lock screen scenes will stop reacting to your movements to conserve battery life. From time-to-time, we will add additional lock screen scenes to your Fire phone when they're available.
2answers
How do I turn off the screen lock on my Samsung Galaxy E5
Andy, Follow steps below to turn screen lock off.
  1. Touch apps,
  2. Touch settings
  3. Scroll to and touch lock screen
  4. Touch screen lock
  5. enter your password
  6. Touch continue
  7. Touch none
  8. Screen lock has been turned off Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to turn off the screen lock on my Samsung Galaxy S5
How to Easily Master Format SAMSUNG GALAXY E5 SM E500 SM E500H SM E500HQ...
2answers
How unlocked the icon lock do Nathing when touch the screen
      Lock/Unlock Screen Portrait Orientation Mode - Apple® iPhone® 5. This helps if you can't get the screen/display on your device to flip or rotate. Access the Control Center by touching the bottom of any screen then dragging upward. Tap the Portrait Orientation icon to lock orunlock screen portrait orientation.
      Lock/Unlock Screen Portrait Orientation Mode - Apple ...
      www.verizonwireless.com/support/knowledge-base-64759/ Verizon Wireless
    Feedback
    Lock icon with circle ios7 need to unlock ' Apple Support Communities
    discussions.apple.com > Support > Apple Support Communities
    AppleMay 5, 2014 - Lock icon with circle ios7 need to unlock ... iPhone 5, iOS 7 ... it will
Jan 23, 2016 • Cell Phones
2answers
I screenlocked myself out of my LG optimus dynamic ii phone how do I getin to it
http://img-tf.deviceanywhere.com/tracfone/pub/252610/docs/L39C%20English%20UG.pdf
Locking and unlocking the screen If you do not use the phone for a while, the screen will be automatically turned off and locked. This helps to prevent accidental taps and saves battery power. When you are not using your phone, press the Power/Lock Key to lock your phone. If there are any programs running when you lock your screen, they may be still running in Lock mode. It is recommended that you exit all programs before entering Lock mode to avoid unnecessary charges (e.g. phone calls, web access and data communications). To wake up your phone, press the Power/Lock Key . The Lock screen will appear. Touch and slide the Lock screen in any direction to unlock the screen. The last screen you viewed will open.
Pattern lock attempts
There are actually few method to reset or unlock pattern lock.
  • Google account-must remember Gmail ID, password and backup PIN
  • Via app called screen lock bypass
  • via command prompt on pc
  • hard reset
all methods are described here
http://null-byte.wonderhowto.com/how-to/locked-out-your-phone-heres-you-bypass-android-pattern-lock-screen-0138807/
2answers
Screen lock open
Customize the Lock Screen
By default, the Galaxy S4 lock screen isn't the most interesting or useful lock screen we've ever seen. Its functional sure, but for those of you who like a bit more action in your lock screen, there are a few things we can do to improve it.
2helpful
Any software screen lock for moto rokr e6
Nupe there is no software who can lock the tuch screen apart from your phone's side key..
Top Uniden Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you an Uniden Video Camera Expert? Answer questions, earn points and help others
