Question about Lakewood HV 18-c Floor / Box Fan
Fan Blade is hard to turn - Lakewood HV 18-c Floor / Box Fan
Can try a little oil, if you can see the bushings on
the motor
Have to remove the fan, to get to the front one
That will work a couple months, then it's off the
the recycle center for the fan
Posted on Sep 12, 2013
  • Jim Lane Sep 12, 2013
    Oil makes run, but only for a few days - what is causing the binding? I would think that "wear" would loosen things - not bind them tighter.
  • Anonymous Sep 13, 2013
    The bushings wear & dry up The oiling only helps for awhile The motor is shot,the windings are bad & the fan needs to be replaced
SOURCE:
Dose anyone have a owners manual for a true refidgerator GDM-12
The fan your referring to is the condensor fan. it should not be tight to turn. it should spin freely. if it is hard to turn, its probably stuck, which is why its not spinning. Remove grill, slide the nottom portiom out so you have access to fan, remove fan blade, and spraylubricant on fan motor (around the area that the screw that held blade). Remove hair, dirt, string, or anything else that might be prevrnting fan from spinning. sometimes its easier to burn it off. If fan still doesnt spin you may have to replace fan motor.r
Sep 26, 2012 | True GDM-12 Refrigerator Commercial
Air is cold. Compressor outside works. The condensor will run for a little while, then shut off while compressor is still running.
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. purchase a new capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor.bobicehouse_96.jpg
Sep 14, 2011 | Frigidaire FAS155K1 Air Conditioner
Air conditioner fan will not turn on outside. Rudd model# UPKA-025JAZ
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. bobicehouse_41.jpg
Jul 22, 2011 | Ruud Matching Split Air Conditioner
My air conditioner tries to turn on, air comes out of vents but isn't cold, and outside the blades on the AC unit are not spinning. I hear a noise when it tries to turn on but they don't start...
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor
Jun 17, 2011 | Heating & Cooling
Have an expensive Hunter indoor/outdoor pedestal Fan that stopped working. It just "hums" and does not turn. Please help.
With the fan UNPLUGGED, try to spin the fan blade with a pencil or something that will fit through the blade cage.
If the blade spins easily, there is an electronic problem (control or motor) that must be serviced.
If the fan blade is stuck or very hard to move, the shaft and bearing are probably dirty and need to be cleaned. You can temporarily fix this with a tiny amount (a drop) of WD-40 applied to the shaft where it enters the motor. Spin the blade manually to work the oil into the bearing. If the motor spins freely, the dirty bearing condition is verified. To properly clean the shaft and bearings, the motor must be disassembled.
Jun 11, 2011 | Hunter Floor Stand Fan Stand (Pedestal)
How hard is it to change the fan? thanks
reasonablly easy allow yourself some time remove oven from housing remove back panel to expose fan motor remove internal back panel to gain access to fan blade undo nut,{it will be tight and is left hand thread e,g tighten to undo} pull of blade turn to back of oven undo three fixing screws that hold motor to back panel detach 2 wires pull off motor reverse to refit.
May 17, 2010 | Neff B1421 Electric Single Oven
How do I remove the fan from an electrolux EGC652 oven
The model no. does not seem correct.but it seems as if the hole in the fan blade which is normally D shaped has worn round.The thread on the shaft is Left handed and you will need to undo by turning clockwise. If you can get a vice grips at the back of the blade to hold the shaft then try again,or you will need to get into the back casing and try jamming the shaft at the motor housing you may need some help.Then if that works you will need to undo the 3 bolts holding the Motor body to the rear casing.The new fan would normally come with new bolts,blade and nut.To tighten fan blade nut use a 10mm socket hold the fan blade and tighten anticlockwise.Hope this is helpful.
Good luck.
May 04, 2010 | Electrolux Ovens
One fan blade stopped working and is hot to touch
The motor is 'locked up' that's where the heat is coming from. It may have a bad bushing or something is jammed. Give it a good look over you may see it. Does the blade feel hard to turn?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 08, 2009 | Minka Aire F602-BNCH Gyro? Fan
Lakewood 200I Floor / Box Fan
Probably requires cleaning- take the grille off, pull the blade free (most pull straight out- some have a pin/socket deal right behind the blades that need to be removed first) and clean out any gunk you may find inside. Be sure to unplug it first. before replacing the blade, turn the shaft with your hands to see how it moves; you might want to grease it with an electricity friendly lube of your choice. If it's still hard to turn, it may just be this fans time; box fans are cheap, and made cheap, and the wear-and-tear adds up.
May 23, 2007 | Lakewood 200I Floor / Box Fan
Lakewood HV 18-c Floor / Box Fan Logo
61 people viewed this question
Top Lakewood Dryers Experts
Bruce Showalter
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
