Question about HP LaserJet 4200 Printer
Tray 3 is not showing up at all in the printer properties dialog box. Any suggestions?
Tray 3 not showing up in the properties box for my hp 4200
Have you re-installed the driver recently? Perhaps you didn't install the correct one. for example '4200tn' (the "t" standing for 'tray"). If you have only installed the regular 4200 driver, then tray 3 will not show up by default
However, you can add it to the current driver as an option.
"Right click" the printer icon
Select "properties"
Select "device settings"
under "installable options"
Click on "tray 3 -not installed" to open drop down menu. click "installed"
Please rate my solution :)
Posted on Apr 16, 2009
How do i do a print aligennment on a hp deskjet 6540
The printer automatically aligns the print cartridges after a new print cartridge is installed. You can also align the print cartridges at other times to ensure optimal print quality.
To align print cartridges:
1. Load letter-size or A4-size plain white paper in the In tray.
2. Open the printer Toolbox.
3. Click Align the Device.
4. Click Align , and then follow the onscreen instructions
Here are directions for how to open the printer Toolbox, in case you don't know:
The printer Toolbox contains a number of useful tools to enhance the printer performance.
Use the printer tools to perform the following tasks:
• Set the Auto-off function
• Clean the print cartridges
• Align the print cartridges
• Calibrate color
• Print a test page
• View estimated ink levels
To use the tools, open the Printer Properties dialog box, click the Services tab, and
then click the Service this device button.
AND, in case you don't know how to open the Printer Properties dialog box, here you go! :
The Printer Properties dialog box is also referred to as the Printer Preferences dialog box.
Opening the Printer Properties dialog box
Follow these steps to open the Printer Properties dialog box:
1. Open the file that you want to print.
2. Click File , click Print , and then click Properties or Preferences.
Good luck to you! I hope this helps.
Aug 07, 2014 | HP DeskJet 6540 InkJet Printer
How to check the ink level onC4480 printer
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the print cartridges appear.
Or
Print a self-test report
1. Load A4 unused plain white paper into the input tray.
2. Press and hold the Cancel button and then press the Start Copy Color button.
The product prints a self-test report, which might indicate the source of the printing problem.
3. Make sure the test patterns show a complete grid and the thick color lines are complete.
• If more than a few lines in a pattern are broken, this might indicate a problem with the nozzles. You might need to clean the print cartridges.
• If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black or photo print cartridge in the right slot.
• If any of the color lines are missing, faded, streaked, or show lines, this might indicate a problem with the tri-color print cartridge in the left slot.
Nov 30, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
HP LaserJet 4200 - need help resetting default tray selections
Are you using Window 7 64 bit or 32 bit? Re-install drivers appropriate for that version of your operating system. Also look at the "Paper Handling" section in the printer menu. Be sure both trays are set for "Plain" paper.
Jul 20, 2010 | HP LaserJet 4200 Printer
Hello:
Click properties on your printer and select options to see tray options from there on you can select the behaviour of your tray
Apr 10, 2010 | HP LaserJet 4200 Printer
The printer is not printing all letters clearly. I want to clean the printing heads to see if this will help.
To clean the print head from the control panel
1.
Load letter, A4, or legal unused plain white paper into the input tray.
2. Touch Setup on the display.
3. Touch Tools.
4. Touch Clean Print Head.
The HP Photosmart cleans the print head and prints a page that you can recycle or
discard.
To clean the print head from the HP Photosmart Software
1.
2. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
box. In the Print Properties dialog box, click the Services tab, and then click
Service this device.
3. Click the Device Services tab.
4. Click Clean the Print Head.
5. Follow the prompts until you are satisfied with the quality of the output, and then click
Done.
If print quality still seems poor after you clean the print head, try aligning the printer.
If print quality problems persist after cleaning and aligning, contact HP support.
Mar 18, 2010 | HP Photosmart D7460 Printer
My hp officejet 4315 only prints in black
Good day, To print from software application (windows) follow the procedure below.(for hp officejet 4315).
1. Make sure you have paper im the input tray.
2. On the File menu in your software application. click Print.
3. Make sure the HP officejet 2315 all in one is the selected printer.
4. If you need to change settings. click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties, Options, Printer Setup, Printer, of Preferences.
5. select the appropriate options for your print job by using the features available in the Advanced, Paper/Quality, Effects, Finishing, and COLOR tabs.
6. Click OK to close the Properties dialog box.
7. Click Print or OK to begin printing.
God Bless.
Oct 19, 2009 | HP Officejet 4315 All-in-One Printer
How select paper from try
Goto Start > Printers and Faxes.
Right-click your printer and select properties.
In this dialog you can change the tray. Usually it is set as 'Default tray'. Change it, apply settings, close dialog.
Now check by printing a page.
Aug 12, 2009 | HP LaserJet P3005 Printer
How do I realign my hp photosmart c4480 printer?
To align the print cartridges from the HP Photosmart Software
1. Load letter or A4 unused plain white paper into the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
2. In the HP Solution Center, click Settings.
3. In the Print Settings area, click Printer Toolbox.
Printer Services.
4. Click the Device Services tab.
5. Click Align the Print Cartridges.
When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
The product prints a print cartridge alignment sheet.
7. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
Jul 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Hpphotosmartc4380 the printing is badly out of line .How do yoy align the cartridges?
You may want to run the alignment program again. Below are the steps as found on page 84 of the manual found here.
1.
Printer Toolbox.
2. Click the Device Services tab.
3. Click Align the Print Cartridges.
The HP All-in-One prints a print cartridge alignment sheet.
4. When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
The HP All-in-One prints a test page, aligns the print head, and calibrates the printer.
5. Load the page print side down on the right front corner of the glass, and then press
Oct 07, 2008 | HP Office Equipment & Supplies
HP LaserJet 4200 Printer Logo
1,159 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
