Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
WPLN4079BR problems We are having problems with our WPLN4079BR IMPRESS charger. We have the battery on the unit but what do we press if we want to find out the battery life that is still left on the battery?
  • strauss682 Apr 16, 2009
    Okay it is working...I understand the math but is it possible to have a battery at over 100%? I have a battery that has 1200 mah and after the reading it says it was charged at 1351 at 8.5 v. That would be over 100% then...is that possible?
  • Motorola Master
  • 1,654 Answers
When you have the battery, in the appropriate cup/adapter of your BMS WPLN4079 charger, wait for any sporatic activity on the screen to cease (there is usually a little number jumping from dropping the battery in), then press the analyze button. Now your battery will cycle for anywhere from 1 to 4 hours. When it is done you will see a number representing the mAH on the screen. You take this number and divide it by the mAH capacity of the battery. This will tell you how good your battery is. 70% and above is acceptable. Anything below 70% you should consider replacement.
Note: This part number is for a BMS charger, not an Impress. However, you can charge and condition impress batteries on this charger provided you have the correct cup.
Posted on Apr 16, 2009
Can I connect the RJ11 jack to the computer and read battery data?
no it is proprietary and needs a license key for the software.
Dec 21, 2015 | Motorola Mototrbo Impress Charger...
Ptt cant go through
It is possible you have a battery or charging problem. Transmitting takes more energy than any other function of the radio. Pressing the PTT can quickly reveal a bad or poorly charged battery pack. Check your charger, clean all battery contacts on the charger and radio with a pencil eraser and try charging again. Also, you can try changing a battery out of a known good unit and see if the problem moves with the battery.
Jul 28, 2017 | Motorola SX600R Two Way Radio
I have a GE model 25836CE-B cordless phone. My problem is this: when the phone is off the charger base, after a few minutes it will keep on beeping even if no one pressed the paging button at the charger...
Actually, you can't overcharge the battery. The base is designed to hold the handset indefinitely. Once the battery is charged it doesn't do any damage. You probably just don't have the battery charged enough to use the phone. Leave the handset on the base overnight, let the thing charge, and it should work properly.
Jul 12, 2011 | Uniden Cordless Phone
The base unit will not charge hand sets . I have cleaned the contacts on base unit as recommended. Please note the remote unit charges both handsets.
The problem is in the remote charger or batteries in each phone is the issue. If you are handy with a meter, "set it to DC volts" press down on the charging tabs, you should have at least 3.6V to 12V if it reads 0 the remote charger is defective.
May 26, 2011 | Panasonic KX-TGA560 Cordless Expansion...
One of the handsets is flashing "Warning Check Battery" It is a mi6896.  We have lost two of the handsets.  We don't know how to use the "Find Handset" feature on the base unit (the manual...
Find handset works by causing the handset, or handsets to beep when you push the button on the base unit, and until you find the handset and push the off button. If the handsets do not beep the batteries are probably dead.
We have a handset that flashes "Charging", and later, "Connecting", but it never connects. When the handset is removed from the charger the handset shows "Place in charger". By process of elimination I have determined that the handset has a problem. The problem is NOT with the battery OR charger. I hope this info helps you.
-Vector721
Aug 05, 2009 | Vtech mi6896 Trio Cordless Phone
Cruise control wont engage it was intermittant for a while, now when i press the button - nothing
dear friend-it can be that the contacts is coroded.next step is to get to them.you need to remove the airbag. but first disconnect the battery.now remove the airbag(bolts is on the side.strip to get to the contacts.spray with contact cleaner and re-assemble
Jul 03, 2009 | 2003 Hyundai Santa Fe
Further question on BMS wpln4079br
Cycle test sees how many charge cycles a battery has left in it. The average number of charge/discharge cycles of a new battery is: NiCd 500-700; NiMH 300-350; Li-Ion 400. (These are averages, batteries will differ.) Analyze looks at the mAH capacity of the battery. With this number you can see what capacity the battery is still holding. (How much gas will fit in the gas tank.) You can improve this number often by running the conditioning cycle. These are better explained in the user manual which comes with the unit. Motorola part #6880309J85.
Jun 07, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
How to use a motorola battery maintenance system
We are unable to find a user manual posted online. The Motorola part number is 6880309J85 you should be able to get one from your local Motorola dealer for $15 or under. (If not, post again and we will help you purchase one.)
Feb 10, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Battery Charging, Nuvi 35
Charge the unit over night, Plug in the AC charger and you should see a lightning bolt over the battery bar graph display.
With the charger plugged in, gently press and hold the on/off power until the screen goes black and displays the text "Charging battery". After a few seconds, the screen will go black to conserve power. At any time, you can press the screen and it will light up saying its still charging.
If you let it go over night, when you touch the screen, it will say Charging Complete and you can then remove the charger. You should have full green bars on the battery indicator.
- Jim
SHARCNET-USA
Dec 20, 2008 | Garmin Nuvi 350 Car GPS Receiver
GARMIN c550 will not turn on
There is an ISSUE with the DEAD ZUMO, however some of the are solved, and some need to be shipped back.
There are a couple of options.
1) remove the battery, keep power button pressed for a few minutes. install battery, try.
2) fully recharge the battery with the wall charger, try
3) With a fully charged battery, press and hold the + button and press the power button(hard reset).
4) hold thumb firmly on top left of touch screen and hold power button till it switches on(hard reset).
5) Try a different battery (fully charged)
6) Ship it to Garmin
Sep 08, 2007 | Garmin zumo 550 GPS Receiver
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
783 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
