No knob on the bobin winder Husqvarna viking 6570 My knob on the bobin winder wont come out it seems to be recessed in the bobin winder
That is a problem with the high/low transmission. The screws that hold the winder post have slipped and the post pushed in to gearbox. The assembly needs to be taken out of the machine and rebuilt. A viking repair person who has been at it for a while might be able to repair this. You may need to look around as this is a repair that is not needed on machines made after the 70's and a lot of current repair people would not know how to do this.
SOURCE: Bobbin Winder won't release
i have a husqvarna rose, i has the same problem when i started using my machine. i was suggested to not wind the bobbin so fast. the reason it gets stuck is because the thread is so tight on the bobbin it actually makes the bobbin a tiny bit smaller, making it hard to get off again. if you dont wind it so fast, it doesn't get so tight.
kylee
SOURCE: Designer I software compatibility
You need the Husqvarna Viking software to turn those file extensions into the SHV format. It's about $400 at your dealer. Their web site does a nice job of showing its features. You get over 100 fonts and alot of designs too. You would open your current designs on a screen and then re-write them to the floppy or stick depending on your model of D1. It then sends the stitch information with the picture of the design to the floppy so your D1 can display the image. (The SHV format)
The VIP and HUS format don't carry the image file for your machine so it say's, "file not found", when you try to open them in your D1.
SOURCE: I have a Husqvarna Mega Quilter Viking. The
If you're sure you're using the correct needles, you should take it to a service tech to align it properly.
SOURCE: Husqvarna Viking Designer I breaking needles
Dls8864's suggestion was a very good suggestion - make sure the metal stitch plate is pushed all the way to the back. Also make sure that the thread is feeding freely - if it is catching on something it can cause the needle to be pulled aside and make it break. Does the design fit properly inside the hoop you are using? If the foot and/or needle strike against the side of the hoop, that will cause a breakage. Is the bobbin thread okay - not making a bird's nest underneath?
SOURCE: Viking Husqvarna Model 6020 stitch selector will not turn.
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
