Question about Viking 27" Professional Select Built-in Electric Double Wall Oven - VEDO127
I have electric double oven VEDO275SS by Viking that are 11 years old. The top oven heats fine but the bottom oven heats out of control. I tried to see how hot it was getting so I put a oven thermometer that went to 600 and it broke. No matter at what temperature you set it, it will heat super hot . I called out a Viking repair man and was told they no longer make the teperature gauge for the oven,so there was nothing they could do. I called Viking and they said the same thing. They only keep the parts for 7 years. I don't know where to look for a replacement, or if the part could be fixed. Any help would be greatly appreciated. Judy
    Problem Solver:
  • 5 Answers
You need to have a new thermostat fitted or the old one re callibrated if possible
Posted on May 29, 2009
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Oven doesn't heat up to the right temp--lower oven Viking Pro
Adjust the knob to the actual temperature. There are usually screws inside toe back of the knob for this purpose.
Mar 23, 2009 | Viking DEDO205 Stainless Steel Electric...
Viking Double Electric Oven VEDO127T
Probably a faulty heater element, some ovens have more than one element in the compartment, so it is possible you only have part heat.
Dec 01, 2008 | Viking 27" Professional Select Built-in...
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Bottom oven not working
It is quite possible the control electronics have failed. There are separate relays for the upper and lower ovens. Ours recently failed the upper oven with the same symptoms and it was the electronic control. The other part is the overheat thermal sensor for the oven may be out.
Aug 01, 2008 | Whirlpool GBD307PRS Stainless Steel...
Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Nov 14, 2007 | GE JKP45 Electric Double Oven
Viking 27" Professional Select Built-in Electric Double Wall Oven - VEDO127 Logo
810 people viewed this question
Top Viking Ovens Experts
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
