Question about HP Pavilion ze2000 Notebook
Will not boot up
When I try to boot up I get a black screen with bios looking print that states: PXE-E61 media test failure, check cable. I have tried everything that I know, which is very limited. Unplugged, took battery out, etc.
There is a noise that sounds like a plate or something that should be spinning inside is skipping or something. This laptop sits on a desk and has never been dropped, thrown (maybe soon) or otherwise abused.
I appreciate any guidance.
  • Roberta Smith
    Roberta Smith May 11, 2010
    as you boot up tap i believe it is the F8 key... that should allow you to boot to last known good configuration.... i can't remember what key you hit to change the boot order... i believe it is F2... currently it is booting to a network and you want it to boot to the hard drive.
  • 52 Answers
Simple
  • Disconnect any USB or 1394 (Firewire) devices that are attached to the computer.
  • Remove any CD and DVD discs from the drives.
  • If your computer has a floppy disk drive, remove any floppy disks from the drive.
  • Press and hold the Power button for 20 Seconds.
  • plug in the ac adapter and press the power button.
see if it boots back to normal and if it didnt work
Press and hold the F10 key while you press the Power button to turn on the PC. Release the F10 key after text is displayed on the screen of the PC.
After the BIOS Setup Utility is displayed, use the Right Arrow key to select the Tools menu.
Select Hard Drive Self Test .
Press the Enter key to start the test.
The Hard Drive Self Test will provide an Estimated test time . A Quick test, a Comprehensive test, and a SMART test will execute when the Enter key is pressed.
If any test fails , contact HP service and support for instructions on how to order a replacement hard drive.
Posted on Apr 15, 2009
    Problem Solver:
  • 5 Answers
I believe that your hard drive is broken and the pc is trying to boot from the lan card
  • 32 Answers
I have only seen this once and I hope it fixes your problem. please open all the bottom plates of your laptop and see if you can get any loose parts out of the laptop. it may be shorting out the system. the only other thing it could be is your harddrive. but if it wasnt dropped or anything like you said. I dont think your platters in your harddrive would of just shattered. I hope this helps.
Once powered on it goes to black screen and says - INVALID SYSTEM DISC,replace the disc, and then press any key.
Are you sure the BIOS is set to boot from hard disk?
It looks like it is trying to boot from network (PXE) and then from floppy disk.
Jan 04, 2014 | Computers & Internet
Tip
PXE-E61: Media Test Failure
Issue:
My computer gets this message when I try to boot it:
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting Intel PXE ROM.
Solution:
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Remarks:
Shouldn't be enabled by default
[more...]
on Jan 04, 2009 | Acer Aspire 3680 Laptop
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 07, 2010 | Toshiba Satellite Laptop
Error Message: PXE-E61 Media Test Failure Check Cable
Try resetting the BIOS to the default settings and reboot
Nov 28, 2009 | Compaq Armada E500 Notebook
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
Video card failure replace your video card
Feb 10, 2009 | Lenovo ThinkPad T41 Notebook
check your harddrive, is it detected in bios ?
if no, it could be motherboard or hdd, but most of the time is hdd problem, so just replace it.
if yes, your operating system is corrupt, so you can reload your operating system.
Sep 30, 2008 | Computers & Internet
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
HP Pavilion ze2000 Notebook Logo
191 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
