CERAMIC HOB EC 60 T. WHEN TURNED ON HAS THE LETTER L ALONG SIDE EACH OF THE ELEMENT ADJUSTMENT CONTROL BUTTONS WHAT DOES THIS MEAN ? AND HOW CAN I GET THE HOB TO WORK CORRECTLY AGAIN THANK YOU
Hi i had the same problem the L means Locked after lots of combinations of button pressing it is the - button in the middle and the 4th RING front right togeather that will unlock it took a couple of goes so persevere
To resolve the ceramic hob being locked out (L displayed on each control)
press the middle button (mine is marked with a - sign) and keep it pressed down, then press the top right button...hold for a few seconds until the L
disappears. My hob then became fully functional again.
Switching off the childproof lock
1. Press the ON key.
2. Then immediately press the Plus key of the cooking zone at the left-back and the Minus key of the cooking zone at the right-back simultaneously.
3. Then press the Minus key in order to deactivate the childproof lock. The "L" will go off.
If this doesn't work or you have a different model, please post back and I will let you know the correct deactivation method for your model.
Hope this helps.
Regards,
BElectric
Same issue /etter L next to each control. If I hold the on sensor each control beeps and displays E r 0 3 from left to right top to bottom.
Any ideas anyone?
