Question about Refrigerators
Samsung RS2544SL/XAA and ice cube tray is "stuck" almost upside down and will not move. Reset button does nothing. Suggestions on how to fix? Can unit be removed w/ out breaking?
3 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: Samsung RS2555sl\xaa Refrigerator. Ice
Go to site for spare parts:
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on Jul 07, 2008
VOTIT
  • 2071 Answers
SOURCE: Ice Cube Tray Sticks
53282922_1db7fdbcf7_m.jpgHeavy Frost on the Coils
This is good! This indicates a defrosting system failure which is a simple control problem. It also means that the sealed system (compressor, evaporator coil, and all associated tubing) is fine as wine in summertime. Defrost system problems are easy fixes that anyone with a pulse can do with maybe just a little help from their friends. The problem will either be the defrost timer (or Adaptive Defrost Control board, if so equipped), the defrost thermostat, or the defrost heater. To locate these parts in your fridge, check out these cool, interactive parts diagrams.
Posted on Jul 24, 2008
Ice maker on whirlpool quit working .
If it's like my Samsung, there is a reset micro switch button in front of the box containing the ice cube tray. Press it and the machine resets, the ice cube tray rotates, dumping the cubes. It then rights itself and fills with water. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
Samsung RS2544SL/XAA getting iced and freezing
In freezers if it's getting ice inside body surface? Sometimes refrigerators doesn't defrost ice completely and shut the drain water line of defrosted ice. If you doesn't have checking instruments for defrosting heater element and other parts, there id's wary wary to defrost ice once completely once. Thank you
Oct 17, 2016 | Samsung Refrigerators
Model rs2544sl no cooling
Try resetting the frig by holding the power freeze and power cool buttons down at the same time.
Jun 12, 2017 | Samsung 24.8 Cu. Ft. Side-by-Side...
Ice dispenser will only give crushed ice; will not dispense cube ice ;I have looked at the auger and chute and nothing wrong there; when I chose cube, it dispenses crushed in both the crushed and cube...
Your selector solenoid is not working. Next to the auger motor there is a selector. You will see a plastic peice in a hole to the left of the auger.....Try to move it up and down. If it won't move it is more than likely frozen in one spot. Try to defrost it. If that does not work then replace the solenoid.
Sep 07, 2009 | Kenmore Refrigerators
Two issues
Well here is How I fixed My French Door Ice Maker, It made the same loud crashing sounds, and seldom put out much ice. To the point that it made no ice at all.
First, Make sure you can get water out of the front, if not, your water lines may be clogged.
The second thing you can do is hit the secret RESET button on the upper front side of the ice maker. See my first image for it's location, it is a soft rubber button.
The third thing.. In my case the reset button worked for a little bit. But eventually stopped. I had to remove the ice maker, and found that that several rows of ice had gotten stuck. The swinging arm that smacks the ice out would just strip the gears banging that ice to no avail. So opening the ice maker up and cleaning it out helped. I also cleaned the sensor contact with some alcohol. It is a thin metal strip close to where the gearing housing is. This I believe is ultimately where the problem starts. It allows the trays to get overfilled, and the ice can't be released. Once I cleaned out the tray of stuck ice, cleaned the sensor, plugged it back in, and hit the reset button once more, It was making loads of ice once again. If this fails, you can get a complete new ice maker online, I found a vendor on eBay selling it for a reasonable $80. You can use my pictures to see how to disassemble for repair ore replacement. My fridge by the way is the RF267AARS.
the part number is: DA97-05554A
It works with the following refrigerators
Samsung RF267AABP Samsung RF267AABP/XAA Samsung RF267AARS Samsung RF267AARS/XAA Samsung RF267AASH/XAA Samsung RF267AAWP/XAA
Oct 17, 2008 | Samsung RF265AA Bottom Freezer French Door...
Ice maker is not working
make sure you remove the ice bucket when you press the reset button. if the ice level arm gets stuck it will not rotate. also if the rotating spindle at the back is jammed nothing will move.
Aug 02, 2008 | Samsung RS2534 Side by Side Refrigerator
Jul 13, 2008 | Refrigerators
Icemaker only dispenses crushed ice, not cubes
There is an opening next to the auger that dispenses the ice.  In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed.  Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Viola! Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
check it out!  Thanks to Jake!
Apr 03, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
121 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
