Question about Toshiba Satellite A100-S8111TD Notebook
Need replacement adapter for Toshiba Satellite A205-S5000
    Guru:
  • 61 Answers
There is a product AC adapter called "Kerio" It will work on your PC. You can purchase in retails or you can order one. You must use the correct volts or the PC will be destroyed.
Live, Love, Laugh
Posted on May 01, 2009
My Toshiba Satellite A205 S5000 came with 2 Ram memory chips of 1GB each. The OS is Windows 7 with 32-bits. Can I upgrade the memory to 4 GB by inserting 2 memory chips of 2GB each?
Hi Lewis
yes you can
here is the link but is cheaper if you just write down the exact numbers from the website and buy in computer warehouse or shop.
http://www.crucial.com/uk/upgrade/Toshiba-memory/Satellite+A205+Series/Satellite+A205-S5000-upgrades.html
but don't forgot to clean your laptop airflow with air duster every month with this you prevent the dust clogging up.
blocked airflow lead to owerheating
and heat differential is not good especially on lead free compound because the composite of welding material contain
silver and aluminium these metals hate each other both has different friction and heat transfer.
lead is more efficient but by eu law is not permitted any more.
if you want to run fast tasks you should go for pc laptop has modified core voltage is slower than computer
and all the high spec numbers are to attract customers to spend money.
Oct 23, 2013 | Toshiba Satellite A205-S5000
I have a Toshiba Satellite a205-s5000 that I replaced the power jack in. They sent me the wrong plug, mine was hard wired into the board so I cut and spliced the new plug to the wires coming out of th
Looking up the DC Power jack for this model, shows me a Center Pin, and cylindrical metal shell; inside the jack.
Center pin is Positive, cylindrical metal shell is Negative.
Also shows it to be a DC Power Harness. Wires connected to the jack, and end in a white plug; that plugs into the motherboard,
http://www.laptopjacks.com/view_part/Toshiba-Laptop-DC-Power-Jack-TS462625.html
http://www.youtube.com/watch?v=lLPlSsEx5F4
Granted, the above is a A205-S4000 series.
(A205-S4577)
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-3.htm
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-17.jpg
So...................
1) Am I to assume someone broke the female connector on the motherboard, that the DC Power Harness used to plug into?
Hard wired in this statement would reflect there was a DC Power Harness, soldered directly to the motherboard?
2) Or is your statement that the DC Power Jack itself, for your model; is soldered directly to the motherboard; and you hard wired the new jack in place; after cutting the plug off of the end of the new DC Power Harness? (And removing defunct DC Power Jack)
Plus; Is this an A205-s5000, or one of the A205-s5000 model series?
A205-s5800, A205-s5801, A205-s5803, A205-S5843, etc.
Yes.
Trying to figure out why this A205, has a DC Power Jack soldered directly to the motherboard, and is not using a DC Power Harness.
Why?
Have to make sure you are soldering to the right area, yet alone the correct contact points.
Don't know what I'm talking about? You unsoldered the DC Power Jack FROM the motherboard? Or the jack was soldered to wires, and wired to the motherboard.
Hardwired. The term can be used for either scenario.
That's the way it was originally?
K
Let's go on.
The DC Power Jack is connected to the DC to DC power circuit; on the motherboard. (Power/Charging circuit)
This circuit is near where the DC Power Jack is mounted, or where the DC Power Harness plugs in.
In the circuit are Surface Mount Devices that are prone to go bad.
One is the Power MOSFET's, the second are MLCC's.
(Multi-Layer Ceramic Capacitor.
They, and the P.MOSFET's, are SMD/SMT
Surface Mount Device/ Surface Mount Technology)
http://en.wikipedia.org/wiki/MOSFET
http://en.wikipedia.org/wiki/Power_MOSFET
Let's use the HP Pavilion dv6000 series, and Pavilion dv9000 series Notebook PC's, for an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
These series of Notebook PC's use the;
Fairchild Semiconductor International - FDS6679 - Power MOSFET, and the,
Alpha & Omega Semiconductor Limited - AO4407 - Power MOSFET.
Look at the second photo down, with the AO4407 circled in Yellow.
Immediately below it, (Right corner), and immediately to the right of the AO4407; are MLCC's.
Smaller rectangular object with a dark wide band in the middle of it.
There is one above the one, to the immediate right of the AO4407; one above it, one to the Right of the top one; and one to the right of it.
There are also 4 smaller examples to the bottom/left corner of the AO4407.
Look to see if any are burned/blackened.
Example of availability, and cost of FDS6679, and AO4407,
http://www.mouser.com/Search/Refine.aspx?Keyword=FDS6679
Scroll down. One Dollar and one Cent, USD.
http://www.mouser.com/Search/Refine.aspx?Keyword=AO4407
Here we see the AO4407 is phased out.
Using one of the cross-reference examples given,
http://www.mouser.com/ProductDetail/Diodes-Inc/DMP3020LSS-13/?qs=%2fha2pyFadujguNNSgppBRqXbOxXLwzGsZm9SWxz1EqWpzoSJOpHpWA%3d%3d
78 Cents USD.
Just to show examples of MLCC's that are SMD/SMT.
The examples I chose are 4.7uf (MicroFarad), and 16 Volts. (DC)
http://www.mouser.com/Passive-Components/Capacitors/Ceramic-Capacitors/Multilayer-Ceramic-Capacitors-MLCC-SMD-SMT/_/N-b2cj?P=1z0wrjcZ1z0x565
Scroll down.
http://www.youtube.com/watch?v=5uiroWBkdFY
You can use a 25 Watt soldering iron, instead of a Soldering Station.
[ Plus Rosin core solder, rosin solder flux paste, flux paste brush, and Desoldering Braid. (Solder Wick ]
http://www.youtube.com/watch?v=b9FC9fAlfQE
Can things be worse? Yes,
http://koti.kapsi.fi/jpa/stuff/pix/travelmate_6292/
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 22, 2012 | Toshiba Computers & Internet
Can the memory be expanded?
Your Satellite A205-S5000 System Specs Memory:DDR2 PC2-6400, DDR2 PC2-5300icon_detail.gifMemory Type: DDR2 PC2-6400, DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-6400, DDR2 PC2-5300 with a maximum of 1GB per slot.
Sep 12, 2012 | Toshiba Satellite A205-S5000
How do you restore facotry settings on a toshiba satellite a205-s5000
create recovery disk with satellite recovery media creator in your satellite laptop, then boot up your laptop with cd recovery you create and you can start recover to factory default setting
Mar 10, 2012 | Toshiba Computers & Internet
How do you restore a toshiba satellite to facotry settings
How do I purchase a Disk Drive for my Toshiba A205-S5000
from this website:
http://www.sparepartswarehouse.com/Toshiba,Satellite,A205,PSAE3U-07Y023,Laptop,Parts.aspx
Dec 30, 2010 | Toshiba MK1637GSX 160 GB IDE Hard Drive
A205 s5000 motherboard. Where can i get one?
Google is your friend
http://www.sparepartswarehouse.com/Toshiba,Satellite,A205,Laptop,System-Boards.aspx
Sep 17, 2009 | Toshiba Satellite A205-S4617 Notebook
Dual Processors for Toshiba Satellite A205-S5000 533Mhz FSB
you got a cheap laptop. maybe from walmart or some other store that was selling it for about $400. It doesn't have a processor that you can switch out. I'm sure it's horribly slow for Visa, so my advise would be to sell it and get something with a dual core.
Feb 26, 2009 | Toshiba Satellite A205-S4607 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
248 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
