Question about Microwave Ovens
Microwave oven replacement Model#MWF307Z-3 Allegro series
We have an old Gaffers & Sattler electric microwave/oven wall unit (around 1970) and the microwave went out. Any way to find a replacement for it? We happen to really like it, so would rather replace the microwave oven part of the unit. We live in Bremerton WA Any ideas?
    Scholar:
  • 192 Answers
You can look for parts here on FixYa,
good luck hunting, I have the same prob, with my Sharp convection M/ wave. I have been looking for 3 yrs. now and it only a 1982. Good luck DFD
Posted on Apr 15, 2009
I have a old jenn air wall oven and a old jenn air microwave mounted on top. it was a countertop model. when i removed it it was plugged into the top of the oven. would that be a 110 appliance outlet?
The Jenn Air microwave that is mounted above the oven in your unit is 110v 60Hz. The socket in the upper rear right corner of the oven is a 110v 6Hz socket and is where the microwave would be plugged in. If you are going to replace the microwave, you can plug it into that socket. If you would rather not use that socket, you will have to drill a hole in the side of the cabinet holding the over/microwave to get the power cord out.
Sep 29, 2014 | Jenn-Air Microwave Ovens
My gaffers sattler gas oven stopped turning on. can not smell any gas when i turn it on.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 25, 2011 | Microwave Ovens
Microwave electrical problem
Unplug, take all the screws out from around the case. Remove case. There is a fuse inside (Without Model number I can't tell you right where it's located) It looks like one of the old round car fuses only it's white colored. It's made of ceramic. Replace it and put unit back together. This is a common problem when one does what you are saying yours is. Be thankful that's all, if you had anything working it would be something major and would be cheaper to replace unit if it a counter top model.
  • NOTE: DO NOT REPLACE WITH CAR FUSE. USE ONLY MICRO WAVE FUSE.
Please rate solution
Sep 05, 2009 | Kenmore Microwave Ovens
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Need New Microwave
Is the interior flaking the only problem with it?
It can be sanded smooth and clean and dried thoroughly, then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, if you want to replace it, I would suggest contacting Jenn-Air Customer Care here and telling them your model number.
They can probably give you the model number of a new "drop-in" replacement.
Dec 12, 2008 | Jenn-Air JMC7000 Microwave Oven
ELECTRICAL POPING SOUNDS
Hi there - I assume you have a rack in the Microwave. What happens is the rack due to putting something in and out of the Microwave some times wears against the back wall of the cooking chamber. As this happens it wears through the paint and exposes the metal casework.
You then get microwave arcing between the metal rack in the microwave and the cooking compartment casing which gives that spitting popping sound. I would say get some white model paint and paint over the scorched spot (as long as its not gone so far as to wear a hole in the case work).
Wait for it to dry and stick the rack back in and try again to warm up a cup of coffee or something and see if it stops.
Also if you pull the grill slightly forward in the holders towards the door and test it you may notice that it doesn't pop as much so I would paint it and pull the grill forward and see if you still get the issue.
Best of luck.
Sep 04, 2008 | Whirlpool GH7155XHS Microwave Oven
Removing an old old microwave oven
look in the cabinet above the microwave, there should be 2 bolts which go through the bottom of the cabinet and screw into the microwave. remove these 2 bolts holding the unit steady then tilt the unit down and away from the wall.
Aug 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Have an older gaffers and sattler stove with microwave built into top. do you know what wattage the microwave is. tahnk you. Paulamrella@verizon.net
Check the manufacturer plate label on your microwave. It may be written like this- KW usually beside the Manufacturer model number.
You could also do a little calculation by checking the voltage and ampage readings. multiply them is going to give you wattage.
Jul 24, 2008 | Microwave Ovens
Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Jan 31, 2008 | Microwave Ovens
Microwave Ovens Logo
204 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
