Question about Fujitsu fi-5750C Flatbed Scanner
Yellow highlighter on page is blacked out on scan image
When I highlight on ANY color setting or adjustment, the highlighter on a printed page is showing on scanned image. If using black and white it should not appear at all but it is showing as a blacked out smudge on the image, blacking out what is highlighted on a page.
It didn't used to do this, but now it is. Could this be from some type of update to the driver? It doesn't matter what scanning program I use, it does it.
This is a pain in the rear and is a work scanner. I have to send documents with highlight marks on them to another cheap scanner in another office to get it done right.
  • kelly_watson Apr 15, 2009
    Found a solution on another site ~ need to set "dropout color" option under Advanced options to [White/(Disable)]
    Fixed it!!!
3 Suggested Answers
mohanchennai
  • 490 Answers
SOURCE: Green layer on scanned image from ADF Simplex
What model of scanner are you using? Is it white light based or RGB LEDs (Light Emitting Diodes). Very rarely it may happen that the Red and Blue LEDs are not glowing may be because of loose contact, but this very rare occurence. Try reloading driver software.
S. Mohan
Posted on Nov 19, 2008
taran_2005
  • 10515 Answers
SOURCE: I have a Fujitsu fi-5110C
Try copying without anything on glass.Do you still see the black line?
Thanks!!
Posted on Sep 08, 2010
HP CP4025 produces no yellow image
Use the built-in print-quality-troubleshooting pages to help diagnose and solve print-quality problems. 1. Press the Home button. 2. Press the down arrow to highlight DIAGNOSTICS, and then press the OK button. 3. Press the down arrow to highlight PQ TROUBLESHOOTING, and then press the OK button to print the pages. The product returns to the Ready state after printing the print-quality-troubleshooting pages. Follow the instructions on the pages that print out.
This should get you started Isn't this printer still under warranty?
Aug 01, 2011 | HP Color LaserJet Enterprise CP4025dn ...
Hi. I need to make default setting to print grayscale. Kindly give me the steps. Thanks
Color/black mix
This item allows you to configure printer settings to optimize printer and cartridge performance for the printing environment. If the printer is primarily used for black printing (over two-thirds of the pages are black only), change the printer settings to MOSTLY BLACK PAGES.
Setting the color/black mix
1. Press Menu to enter the MENUS.
2. Press to highlight CONFIGURE DEVICE.
3. Press to select CONFIGURE DEVICE.
4. Press to highlight SYSTEM SETUP.
5. Press to select SYSTEM SETUP.
6. Press to highlight COLOR/BLACK MIX.
7. Press to select COLOR/BLACK MIX.
8. Press or to select the desired option. (Select MOSTLY BLACK PAGES)
9. Press to select the option.
10. Press Menu.
Select MOSTLY BLACK PAGES if you print mostly monochrome print jobs, or a combination of color and monochrome print jobs.
Product User Manual (You may like to refer to Page 65)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 16, 2011 | HP LaserJet 4700 Printer
Can you just give me a link or quick advice on scanning with HP photosmart c5180? I would like to to scan and save to disk/save to laptop.
Scanning with HP Solution Center Software in Windows
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&cc=us&lc=en&dlc=en&product=1153481&tmp_track_link=ot_search#N43
FROM THE MANUAL ON PAGE 14 http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf Scan an image You can start a scan from your computer or from the HP All-in-One. This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must also be installed and running on your computer prior to scanning. ? On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running. Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software. ? On a Mac, the software is always running. Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One. To save a scan to a memory card 1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One. 2. Load your original print side down in the right front corner of the glass. 3. Press the Scan Menu button. 4. Press to highlight Scan to Memory Card, and then press OK. The HP All-in-One scans the image and saves the file to the memory card in the JPEG format. To scan a photo and reprint it 1. Press Reprints. 2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following: To reprint your original photo using the default print settings ? Press Print Photos. To change print settings before reprinting your original photo a. Press OK. Basics Guide 13 HP All-in-One overview b. Press or to highlight a paper size, and then press OK. The paper size choices available vary depending on your country/region. Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages. c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK. The HP All-in-One scans your original and shows a preview of the photo on the display. d. Press OK to display the selection menu. Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies. If you want to edit the photo before printing, press to highlight Edit Photo, and then press OK. e. Press to highlight Done, and then press OK. The Print Summary screen appears. f. Press or to highlight one of the following options, and then press OK. Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and time stamp on your photo. By default, the Paper Type is set to Automatic and the Date Stamp setting is set to Off. If you want, you can change the defaults of these settings with the Set New Defaults option. Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and wasting paper and ink on potential mistakes. Print Now Prints your photo with the size and layout you selected. To scan to a computer 1. Load your original print side down in the right front corner of the glass. 2. Press Scan Menu. 3. Press to highlight Scan to Computer, and then press OK. 4. If the HP All-in-One is connected to one or more computers on a network, do the following: a. Press OK to select Select Computer. A list of the computers connected to the HP All-in-One appears on the display. Note The Select Computer menu might list computers with a USB connection in addition to those connected through the network. Chapter 1 14 HP Photosmart C5100 All-in-One series HP All-in-One overview b. Press OK to select the default computer, or press to select a different computer, and then press OK. The Scan To menu appears on the display, listing the applications on the selected computer. If the HP All-in-One is connected directly to a computer with a USB cable, proceed to step 5. 5. Press OK to select the default application to receive the scan, or press to select a different application, and then press OK. A preview image of the scan appears on your computer, where you can edit it. 6. Make any edits to the preview image, and then click Accept when you are finished.
Jun 05, 2011 | HP Photosmart C5180 All-In-One InkJet...
Hp 3600n laster printer has started printing pink blothes on pictures
You probably have a defective magenta cartridge. To test that you need Print Test Quality pages.
1. Press Menu to open the MENUS.
2. Press to highlight DIAGNOSTICS, and then press .
3. Press to highlight PQ TROUBLESHOOTING, and then press .
The message PRINTING... PQ TROUBLESHOOTING appears on the control-panel display until the
printer finishes printing the PQ troubleshooting pages. The printer returns to the Ready state after
the pages it produces are individual colors, black, magenta, yellow and cyan and a white page and a config sheet.If the defect is on all pages then it might be a bad transfer belt. If it is only on one of the color pages, that will tell you which cartridge is bad.
Mar 11, 2011 | HP LaserJet 3600n Printer
Can't print photo in black and white
Could this be the problem? From the User Guide: "Print Color images in Black and White -- Print your color images in black and white to save the ink in your color ink cartridge.
NOTE: You cannot select this setting if you have selected Color Cartridge for all Black Printing"
Dec 23, 2009 | Dell 962 Photo All-In-One InkJet Printer
Color printing, not so colorful. Even with new cartridges
Your model has some print quality pages built in to help diagnose and solve print problems.
1) Press <Menu>
2) Press <Down> button to highlight "Diagnostics"
3) Press the <checkmark>
4) Press <Down> button to highlight "PQ Troubleshooting"
5) Press <checkmark> to print the pages
If you see print-quality defects on the print-quality-troubleshooting pages, calibrate the printer. To calibrate the printer (optimize print quality):
1) Press <Menu>
2) Press <Down> button to highlight "Configure Device"
3) Press <checkmark>
4) Press <Down> button to highlight "Print Quality"
6) Press <Down> to highlight "Full Calibrate Now"
7) Press <Checkmark>
I hope this helps!
Dec 21, 2009 | HP LaserJet CP3505dn Printer
Can I scan pictures to my computer?
Yes ... your all-in-one can print, copy and scan.
Scan an image
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
● On a Mac, the software is always running.
1. Press Reprints.
➔ Press Print Photos.
a. Press OK.
Basics Guide 13
Defaults option.
2. Press Scan Menu.
Jul 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printer problems
This will sound stupid, but if you are trying to print a document in B&W with this particular model, you have to force it to print ONLY using the black ink cartridge, if you are out of color ink, otherwise, it will try to use the color cartridge by default. A highlighted word is not recognized as a black image with a colored background, it is recognized as a multi-colored image, s-o-o-o try going into your solutions menu, click on "Change settings" then click on "Printer settings" Then click on "Maintenance" tab, click on the "Ink Cartridge settings" button. From the drop-down menu, select "Black Only". Click on okay. THEN when you go to print the document go to your printer settings and click on the "grayscale printing" checkbox. Then Select "Plain paper" Of course, you have to do this each time you want to print. The MP470 is primarily a photo printer, with text and graphics abilities. It wasn't designed as an all-purpose printer... I found that out the hard way! :-) Unfortunately, this only works (so far as I've seen) if you are out of color ink... it tries to use color by default to 'create' black... I hope this helps out!
Apr 12, 2009 | Canon PIXMA MP470 All-in-One Printer
HP Color Laserjet 3500 Problem
If you are sure the diagnostics show the colours correctly, one thing I would look at is to see if it had a colour profile set up for it.Don't know whether this printer normally has, if it has not I would suggest reinstalling the driver. To check - Start/Printers & Faxes/ Rt click on printer then properties, look under Colour management tab. Pete
May 25, 2006 | HP Color LaserJet 3500 Printer
Fujitsu fi-5750C Flatbed Scanner Logo
1,104 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Jax Planet
Jax Planet
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
