SOURCE: AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE
toner type error
replace the toner cartridge
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
SOURCE: Sharp SF 2030 Copier ,need reset operator key code
First you need to know the key operator code, you can display it by pressing [C][INTERUPT] [0/ZERO][INTERUPT][22][START][13][START] then the display will shows you the 5 digits key operator. After you know the key operator code, you can go to User program, this is done by pressing [C][INTERUPT] [C] then input the key operator code, when entry is complete "P" will appear in the quantity display. Input 19 then START, input the new code and press START. To exit user program press CA
During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
SOURCE: my sharp AR 5516 shows
You have to change your developer, you can see developer spillage inside the machine it is a common problem in this particular model. Rate this and vote for this after your problem resolved.
