Question about Sony Handycam CCD-TR96 Camcorder
Sony CCD-TR96 won't playback tape
I am trying to view a tape on my Sony CCD-TR96 handycam. I set it to "player" mode and pressed "play". The tape starts to turn but all I see is black and the counter isn't moving. I am certain there is material on the tape and I tried another one just in case and got the same result. I don't understand why the tape is moving but the counter isn't.
5 Suggested Answers
SOURCE: very grainy playback
Same problem with my Sony CCD-TR416 recently. Know what finally worked? With camera playing a tape, I picked up the camera and tapped it sharply on a solid desktop. Had to do it 3 times. I held the camera with two hands, one on each side of the camera, raised it about 3 to 5 inches off the desktop and then quickly tapped it on the desk holding the camera parallel to the desktop so that it solidly hit with all of the lower surface of the camera body.
I know it sounds crazy. I swear it worked. I had tried cleaning the heads over and over. I examined them with a 20x loupe and they looked fine. I doubt that the problem was oxide and debris build-up on the heads.
I planned to order a new head/drum just to see if I could manage the replacement procedure by myself (I'm a chronic do-it-yourselfer/experimenter). I guess I don't need to do that now.
Why did the slam technique work? My guess: Inside the rotating head, there must be some sort of electronic track like the brushes of a motor or something similar.. Some sort of debris must have been involved in a corruption of the transfer of impulses from the heads. A few taps and it broke free.
If banging it on the desk didn't work, I was next planning to remove the drum to check for bad connections. I'm sorry I didn't have to do that.
Nevertheless, don't listen to everyone when they say that the "heads must be dirty." Nope. With the loupe, I could see mine were sparkling clean. But, I still had those multiple horizontal rows of short white streaks obliterating the video image. Tap. Tap. Tap. Now they're gone.
Try it. Couldn't hurt. Though chances are, you won't see this. I'm posting 6 months after your original post. I just happened upon your post as I researched the problem through Google. Neverthelss, someone might see my response someday and maybe they, too, will get luck with the tap, tap, tap procedure.
Posted on Jan 15, 2008
SOURCE: No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Posted on Mar 09, 2008
SOURCE: Sony Handycam Vision ccd-trv308
I have the DCR-HC32. I got the c:31:22 error with a message to reload the tape. I could load another tape and saw a post that if a tape is at the end and the tension is tight the camera has a sensor that won't load the tape so that it does not break it. I loosened the tape after a few tries and it loaded fine...no more errors.
Posted on Jun 09, 2010
shajanrs
  • 890 Answers
SOURCE: How do I transfer from
I'm glad to provide the instructions to connect the Camcorder to a Computer to transfer videos from tape. You can connect the A/V output of the Camcorder to the A/V input on the Computer and use Windows Movie Maker available with the Windows Operating System or iMovie in the case of Macintosh to capture videos.
Please click hear to get the step by step instructions to transfer videos from the Camcorder to the computer.
Thanks for understanding. Please let me know if you require any clarifications.
Posted on Aug 22, 2011
I have an older camcorder that hasn't been used in a while. When I went to try to view the tapes made on the camera, I just get a blue screen with a white play arrow. The tape is moving inside though. It...
The video drum inside the tape mechanism consists of two sets of heads. One set for recording and one for playback. It's possible the playback heads are damaged, in which case the video drum will need to be replaced. It's also possible the video drum may simply be oxidized in and the camera only needs servicing and the drum deoxidized. I don't reccomend using "cleanning tapes" as they can sometimes do more harm thab good although you try. You might get lucky and this will solve your problem.
Aug 03, 2010 | Sony Handycam CCD-TRV68 Camcorder
Tape door will not stay closed. shut tape compartment door...runs for 3 seconds...reopens.
It is possible on the CAM mode the tape reached to the end, or this is
typecal problem from Sony the sensor it detecting 2 reels to turning the tape were faulty.It require to replace the cassette compartment or it call LS chassis assy. It will cost about $200, $250 in Australia to repair it
Jan 08, 2010 | Sony Handycam CCD-TR96 Camcorder
Sony digital video camera mode no. DCR-HC14E not showing pictures/recording
If your Sony DCR-HC14E shows fine picture in playback of old tapes and does not give live view in camera mode to record then its CDD Imager problem that Sony will repair free of cost.
Click Sony CCD Imager Support for details.
Jun 10, 2009 | Sony Handycam DCR-HC14E Mini DV Digital...
My sony handycam was stolen how do i play back my 8mm tapes is there an adaptor available?
No adaptor for 8mm tapes. You need to have Sony camcorder or video-8 player for playback these tapes.
Feb 21, 2009 | Sony Handycam CCD-TRV87 Camcorder
Sony CCD-TRV65. Blue screen during playback
Just bought the exact one from a yard sale for 20 bucks. Had the very same problem with the blue screen on playback. What i did is replace the battery in the small bay when you open the viewfinder. Try playing your tape again and it will work!
Feb 01, 2009 | Sony Handycam CCD-TRV65 Camcorder
Cannot view playback!!!!
First thing to determine is if your (Playback Mode) is set for Auto or Hi 8 / 8. Select VTR setting and then select Menu. Scroll to PB Mode and select Auto. Now try playback.
Oct 25, 2008 | Sony Handycam DCR-TRV820 Digital-8 Digital...
Playback problem
Video Head is dirty/ clogged. Use good quality Video Head Cleaning Cassette.
Jun 08, 2008 | Sony Handycam CCD-TR517 Camcorder
Why wont it play LP taped tapes?
Tracking is very sensitive on hi-8 tapes in LP mode. This recorder will record and playback in LP mode. It is however recommended that if you record in LP mode that you use the same camera to play it back, that it was recorded with, or you might have problems.
Also from what I can find online, the TR427 is just an video8 camera not a Hi-8 so if you are trying to play Hi-8 tapes on it, it won't play right.
Nov 03, 2017 | Sony Handycam CCD-TR427 Hi-8 Analog...
Video Cameras Logo
97 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
