Question about Aurora Electronics AS1018CD Shredder
Won't shut off after shredding.
Will not automatically shut off after it is through shredding. Have run in reverse to ensure shredders clean. Didn't help. Have to manually turn off.
  • 3 more comments
  • stuck on go Feb 09, 2008
    My as1018cd will not shut off after shredding is finished. I have clean it and made sure there is not paper in front of the electric eye. I have just had this shredder for about 8 months and I went back to wal-mart, they informed me that I would have to contact the manufacture. Please help me resolve this problem. It is too new to not have a solution. Thank you.
  • Anonymous Mar 15, 2008
    Mine is doing exactly the same thing! It is not very old and I have looked and cleaned and it still will not shut off. Are these things just lemons??
  • Anonymous May 04, 2008
    I have the same problem with mine. I can't find any stuck paper in it. I can't figure out why it won't shut off automaticly.
  • Michael Arganetto
    Michael Arganetto May 04, 2008
    Mine did the same thing about 9 months after I got it. I've tried everything to get the little pieces of paper but just can't get it to shut off!
  • allenkauhfol Sep 16, 2008
    I also had this problem. I took it apart 2 times and cleaned it up and also cleaned the eyes. It was working fine. Last night I heard noises and went to investigate. I found the shredder was running on its own. No one had been near it. I don't know how long it had been running, but it was smoking and stinking. I unplugged it and took it outside. Definately a problem!
I FIXED MINE!!! Hey folks same problem AS1018CD would not shut off. CURE: Take apart and clean electronic eye. PROCEDURE: 1. Unplug. 2.  Remove shredder and turn upside down. 3. Remove 6 phillips head screws on back of unit ( 1 is under sticker in middle peel back sticker to access screw. 4. Carefully separate unit. 5. Pull off shredder piece. It is a snug rubber grommet fit and just lifts off( gears everything comes off as one piece. 6. Electric Eye is exposed remove screw holding in and gently slide out and wipe clean. Do both sides. While apart clear all debris and wipe entire unit as clean as you can. Put gear assembly back on grommets. Put top and bottom back together. Replace screws. Plug in. FIXED :-)
Posted on Jul 11, 2008
  • Joe Naneville Jul 28, 2012
    Thank You. Works perfectly now.
I had this problem. I unplugged the shredder removed the top and turned it upside down and got out the compressed air gas can you normally use on your computer keyboard and blew plenty of air inbetween the teeth where the electronic eye should be. Turned the top over plugged it back and it is working great! No more problems!!
Posted on Jul 29, 2010
I had the same problem just removed the paper and it still ran. put it in reverse and it literally blew up and burned my hand be careful. I had it couple of months. Just happen tonight. there is no recalls on it so that is good.
Posted on Aug 22, 2008
  • 136 Answers
Either it has some paper stuck in the electronic "eye" or there is a switch that detects paper that is stuck. Unplug it and dig around a tad you may find the problem easily!!
Posted on Sep 15, 2007
My Executive Machines EPS 1200X shredder works in reverse, but does not shred.
there should be a forward/ reverse switch that is used to unjam paper being shredded. check that
if it is automatic then check for paper stuck in the shredder causing the reverse action.
May 12, 2015 | Shredder Office Equipment & Supplies
My Black & Decker Shredder #BD-61 all of a sudden does not work. I used it tonight, but the next time I tried it does not work. The lights come on in both positions, but
On some shredders when both the forward and reverse LEDs are on it can indicate either a jam or a full receiver bag/ container (the area that the shredded paper is fed into).
Try the following steps:
  1. ) unplug the power
  2. ) open up the shredder (see 1 on diagram)
  3. ) empty out all the shredded paper (see 2 on diagram)
  4. ) check that the shredding jaws (both the entrance and exit) are clear of any shredded material (see 3 on diagram)
  5. ) put everything back together
  6. ) plug power cord back in
  7. ) force the shredder into reverse (see 4 on diagram)
Hopefully you should hear your shredder motor running. If it is switch it to automatic and try shredding again
Jan 24, 2015 | Shredder Office Equipment & Supplies
Won t shut off
Blow out the sensors with some compressed air, Using a can of compressed air, look for the sensors that detect the paper and give them a blast or two, then try it, it may take a couple of tries.
This may also be a good time to lubricate the cutting heads, if it is a good machine with metal heads a light oil applied to paper then run through the shredder will pass the oil onto the heads.
A shredder oil or light oil like 3 in 1, these usually have a narrow nozzle to limit the oil flow, draw lines, do a picture or spell your name on the paper with oil and shred it. You have just serviced your shredder.
If it is a less expensive shredder with plastic heads, shredding a couple if sheets of waxed paper will pass the wax onto the cutting heads reducing friction.
Hope this helps.
Oct 01, 2013 | Office Equipment & Supplies
The shredder doesn't automatically shred anymore. How do I set it so the "eye" works and it shreds automatically without me holding down the button?
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 04, 2013 | Quartet gbc 5550X Shredder
Constantly runs when on auto and won't accept paper
Shut off power and turn the shredder upside down. It is highly likely you will find shredded paper jammed in the mechanism, especially near the center where the feed sensor is located. A thorough cleaning should get your shredder operating again
Feb 02, 2013 | Staples SPL638X (CrossCut) Shredder
can't solve the problem, but wonder if I could get an owners manual for this same model (SPL-TMC16A)
Dec 16, 2010 | Office Equipment & Supplies
Runs in reverse, but no on auto.
check and see if there is a jam of paper inside the unit or around the sensors
Jul 20, 2009 | Royal 10X Shredder
PowerShred C-220 will not shred automatically
OK lets try.
You likely have a photo sensor that detects the paper and it is dirty.
It is likely covered with paper dust (hopefully only on the outside)
Locate the sensor and wipe it off or just wipe the entire throat area.
Hope this helps
Dec 05, 2008 | Fellowes Powershred C-220 Strip-Cut...
Shredder won't shred - all paper is cleared - works intermitantly
Run the shredder in "Reverse" mode for 15 seconds.
Oil the cutting head thoroughly as this is a High Security shredder.
Test it at 4-5 sheets.
They always overrate the capacity but if you want to keep it operating, shred 3-5 sheets max.
Running for serveral minutes could be due to dirty optic sensors. Unplug the shredder, remove the top (2 screw underneath front and 2 in back). Remove the sensors (they have a little pushbutton tab) and clean thoroughly with a soft cloth. Re-insert the sensors ensuring they lock in place, reset the top cover and test.
Jun 05, 2008 | Geha Primo 3900 HS Shredder
Aurora Electronics AS1018CD Shredder Logo
830 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
Jim Keysor
Level 1 Expert
Level 1 Expert
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
