Question about Hitachi NV65AH Siding Nailer, Coil, Wire/Plastic Sheet Collation
Nails i want to know if there are several kind of siding nails? i am talking about how separeted in betwen each other (nails) . I have a hitachi NV65AH and gets jamb every 3 to 4 nails
    President:
  • Hitachi Master
  • 1,388 Answers
Yes there are many different kinds of siding nails from all over the world. Stores that sell nails buy/import nails from where-ever the labor/cost is cheapest. The importer uses a private label so the nails from one company in China will produced according to requirements and will be sold under many different brands in the US. The result is that the nails are not exactly the same from batch to batch. I have seen coils that measure from 3/16 to 1/4 inch between the nails. Closer to 1/4 inch is more ideal for your nailer. The (nv65ah) is listed as a 16 degree canister angle, however you probably purchased 15 degree nails because nothing else is available. Should be no problem assuming everything is working ok. When you insert nails into feeder, make sure that the first nailhead is positioned under the driver and not too far to the edge because the driver will bend the nail if not hitting dead center to the nail shaft. Ask for a sample section/ roll of different brands and type of nail to find the best nail for your gun. Best place to find nails is a fastener company that only sell nails/ nailers/compressors to contractors. For best results, make sure that the driver is squared/flat at the tip. If is not, remove the driver and grind it flat (do not grind too much). If driver and nails check out ok, then it may be time to replace springs/orings in feeder area. Go to www.toolpartsdirect.com and take a look at the breakdown of your gun and notice that there are several springs in the feeder area that will weaken over time/use. There should be two springs in doorlatch area, one on the feeder itself, and one large spring pushing on the feed piston. Good luck with your issue and email if you have question.
Posted on Apr 16, 2009
What lubrication procedures are needed?
Go to this web site their is a full manual and it tells the lube procedures https://www.manualowl.com/m/Hitachi/NV65AH/Manual/245587
May 01, 2016 | Nailers Hitachi Nv65ah Coil Nailer Driver...
Hitachi nv65ah driver sticks after driving first nail
Most often with this tool it is because the driver is bent. Remove the 4 bolts on the head and pull the driver straight out to inspect it. It doesn't take a lot of bend to hang it up.
Let me know if this helps!
Apr 07, 2014 | Hitachi NV65AH 212Inch Coil Siding Nailer
My Hitachi nv65ah nail gun won't set nails into 3/4 trim. I have played with the turn/screw set adjustment and it is set for the deepest setting. This gun was purchased second hand off e-bay but
If every nail is stopping at the exact same height, a likely reason is the tip of the driver is broken off so it's not long enought to drive the nails all the way to flush. If the height of the nails is slightly different you may have worn or broken o-ring(s) inside the gun and air is leaking around the driver's piston or elsewhere in the gun so that the driver isn't getting full pressure. You can take the gun apart and inspect the o-rings. If you push the driver all the way down the tip should come flush or slightly past the end of the nose piece (not the safety tip). Parts are easy to find online or at a service center if you have one nearby.
Mar 10, 2012 | Hitachi NV65AH 212Inch Coil Siding Nailer
I have a craftsman roof nailer with plastic cover for nails broken where can i get one to fit
Best place for replacement parts is the address below.
Ez to order from and usually only takes 10 to 14 days to get the parts. Click on Hitachi logo then select coil nailers, then your model number. For local parts, look in the yellow page directory for fasteners. Fastener companies that sell nails and other supplies to contractors also have parts for Hitachi nailers. Check with several. Some will even repair the nailer for you if you buy nails from them.
Good luck.
WWW. toolpartsdirect.com
Sep 01, 2011 | Hitachi NV45AB2 78Inch to 134Inch Roofing...
Driver is stuck in down position, Hitachi hc65ah nailer
did you try to flip the release on the driver head right above the safty
Jun 24, 2011 | Hitachi Parts- Nv65ah Nailer-driver...
Pieces of the coil are breaking off when firing my Hitachi NV65AH - what causes this?
If you are using wire coiled nails, this is a common issue and there really is noway to stop this, and is advisable to wear safety glasses when ever using a nail gun. I have had 1 of the wires come off a coil and literally pierce my cheek. If it would have hit me in the eye it would have done some serious damage.
Aug 16, 2010 | Hitachi NV65AH Siding Nailer, Coil,...
Sometimes shoots 2 nails. say most of the time
Your driver blade/piston may need machining. Remove the to cap of the tool and take out the blade/piston. Using a bench grinder square up the blade, then put tool back together. Then test fire tool. Good luck!!!!
Nov 27, 2009 | Hitachi NV65AH Siding Nailer, Coil,...
I have a problem with my canon IR200. with my canon ir200 with heater section, it have nails with the section and the nails or too length, so the papers or not delivering out, they are crushing there...
Hello sir;You talk about "nail" I believe we call paper separeter or finger, before you change,I like you go to clean out the finger, the surface contact with heat roller ,it very easy to build up toner over there and made little gap therefor when paper go through by, it stuck.
Jun 03, 2009 | Canon Office Equipment & Supplies
NV65ah Hitachi nail gun "how do you remove the trigger piston"??
If you do not have a breakdown of the gun go here www.toolpartsdirect.com and select brand, then select coil nailer, finally look for your model number. With breakdown, find parts labeled 51 thru 54. The trigger pin (#53) and the retaining ring (#21) hold the trigger. Remove these then remove the trigger. Find several #51 roll pins on the gun and punch out the uppermost pin where the trigger valve is located (3mm size). The uppermost rollpin holds the trigger valve in-place. After you have removed the rollpin/s connect air supply to pop-out the trigger valve. Caution, use a heavy glove (or reduce pressure) to catch valve as it can come out with force. When incerting the rebuilt valve, use caution not to cut new orings as the valve is pushed in. Good luck and email if you have more questions.
Mar 15, 2009 | Hitachi NV65AH Siding Nailer, Coil,...
Hitachi NV65AH Siding Nailer, Coil, Wire/Plastic Sheet Collation Logo
212 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
