Question about Chaintech Slot 1 CT-6ATA2 Motherboard
Help me in finding driver for CT-6via3 ChipSet VIA Pro 133 ( 693A + 596B ) two chip 2 x AGPset Processor Support Intel FC-PGA System Clock 66 / 100 / 133MHz CPU Type Socket 370 AGP Supports AGP 1x / 2x AGP cards Memory Socket 168-pin 3.3V DIMM x 2 Type SDRAM Size 512MB ECC single bit Award BIOS Function PnP , DMI , Multi-device booting Protect Trend ChipAwayVirus IDE
  • Anonymous Apr 26, 2009
    manufacturer of the board is chaintech and need all the drivers
  • 32 Answers
Do you need all the drivers for the entire board or which one. also have you tried to find the manufacturer of the board. there website may have it all.
Posted on Apr 15, 2009
Drivers 7vba-2aa5
Hello the drivers from this site should fit your mainboard:
http://global.aopen.com/products_download.aspx?sDropDownProd=52
Please unzip the files bofore you install.
Install the 4 in 1 chipset driver first and reboot.
Install next the sound driver.
Here is also the VIA site:
http://www.via.com.tw/en/support/drivers.jsp
Here is some info:
SY-7VBA 133
Description
- 66/100/133 MHz FSB FC-PGA 370 Based ATX Motherboard
Processor
- FC-PGA 370 Pentium III Processors with 100/133MHz FSB
- Socket 370 for Celeron Processors with 66/100MHz FSB
Chipset
- VIA 693A + 686A Chipset
- 66/100/133MHz CPU FSB
System Memory
- Three 168-pin SDRAM DIMM sockets support up to 1.5GB
- PC133/PC100 DIMM support
- Provides ECC (Error Checking Correction) capability
On Board Audio Subsystem
- AC97 CODEC on board to provide audio solution.
SOYO has closed there support site many years ago.
Good luck
Jan 11, 2013 | Soyo SY-7VBA133 Motherboard
Manyal
EP-8K3A
Introduction
KT333 with VT8233A AGPset/266MHz FSB/3 DIMM with DDR333/1 AGP-4X/6 PCI/USB1.1/ATA-133/6CH Audio/ATX
Specification
PROCESSOR:
The Socket A compatible AMD AthlonTM XP processor 1500+ to 2700+, 600MHz to 1.4GHz AMD AthlonTM and AMD DuronTM processor up to 1.3GHz
CHIPSET:
VIA KT333 AGPset (KT333+ VT8233A)
DRAM MODULE:
184pin DDR DIMM x 3 for PC2700 Memory
DRAM Size: 64MB to 3GB
EXPANSION SLOT:
PCI x 6!A4X AGP x 1
ONBOARD I/O:
Winbond W83697HF LPC I/O integrated with FDD, Parallel, Game, Serial and IrDA v1.0 and Power-On Controllers
ONBOARD PCI / IDE:
PCI Bus IDE Port with PIO / Ultra DMA-133 x 2 (Up to 4 Devices)
I/O CONNECTOR:
PS/2 Mouse and PS/2 style Keyboard
COM1, COM2, Printer, Audio-in/out, MIC & Game Port connectors
USB:
USB connector x 4 (2 for Opt.)
BIOS:
Award Plug & Play BIOS
Built-in AC97 Digital Audio (by Realtek ALC650):
Compliant with AC97 2.2 specification
6 channel slot selectable DAC output for multi-channel applications
Supports digital SPDIF Out Function
EXTENDED FUNCTION:
Supports Hardware Monitoring Function by W83697HF
Supports exclusive KBPO (KeyBoard Power On)
Supports CPU Vcore , Clock and Multiplier setting via BIOS
Supports Memory Voltage setting via BIOS
Supports STR (Suspend To RAM) power saving Function
Supports Wake-On-LAN Function
FORM FACTOR:
305mm x 245mm x 34mm ATX Size
OS Supported:
Windows 98SE/ME/2K/XP/Server2003
Jun 05, 2011 | EPoX EP-8K3A+ Motherboard
How do you know if you get fcpga or fcpga 2 on the motherboard? it is socket 370 and fc pga 2 is mentioned in the manual but other 3 mention was fc pga thanks for any help
The difference between FCPGA and FCPGA2 is the internal connections to a single pin: in FCPGA2 it allows faster (133MHz) bus speeds. Mechanically they are the same - Socket 370. Your chipset VIA Apollo Pro133A is capable of handling it so you should buy the fastest P III you can find -it will work perfectly fine. Just make sure you have the latest version of the BIOS.
Nov 21, 2009 | Computers & Internet
I HAVE A SOCKET 370 MOTHERBOARD WHAT IS THE DIFFERENCE AND THE FCPGA VS FCPGA2? AND HOW DO YOU KNOW WITCH TYPE WILL WORK ON THE MOTHERBOARD THANKS COOL KID
Intel Pentium III and Celeron CPUs less than 1001 Mhz were FC-PGA.
Intel Pentium III and Celeron CPUs more than 1200 Mhz were FC-PGA-2.
However, Intel made CPUs in the 1000 to 1200 range that were FC-PGA
*AND* Intel made CPUs in the 1000 to 1200 range that were FC-PGA2.
So, all FC-PGA CPUs will work in almost every Socket 370 motherboard,
but all FC-PGA-2 CPUs require a motherboard that supports FC-PGA-2 CPUs.
Nov 18, 2009 | Computers & Internet
I need the motherboard manual for p4m266823x
I need driver VIA P4M266-823x, help me please!!!
Jun 10, 2009 | Computers & Internet
Would like to find onboard sound driver for board :P4M266-PM12-EL
Hi shariffah,
That board has is a Via board chipset, so you can download the 4 in 1 drivers for most of the Via chipset, HERE. But specifically for the audio controller you can go HERE. Which is also a combp driver.
Good Luck & don't forget to leave a rating based on my solution.
Thanks
Mark
Apr 07, 2009 | Computers & Internet
List of cpu support for pga 370 motherbord
The 810E Micro-ATX can only support the following processors
Intel Pentium 3 / Celeron
Jan 31, 2009 | Intel FC-PGA2 Tualatin Adapter for Socket...
My computer restarts before installation completes
GO INTO SAFE MODE REMOVE ALL OLD DRIVERS AND ANYSOFTWARE THAT MAYU CONFLICKS AND RESTART SYSTEM
SAFE MODE MAY ALLOW INSTALLATION OF NEW DRIVERS IF SO DO IT IT WILL HELP YOU ALOT.
IF NOR GOINTO CONTROLL PANEL SELECT NEW SOFTWARE LOAD NEW DRIVERS
CANDYMANGANDY
Jan 27, 2009 | Abit AX8 NVIDIA VIA K8T890 + 8237 Chipset...
Graphics driver intel m 765
Mother Board = M765
Chipset = VIA Apollo Pro (VT82C691)
Relabeled Chipset = BXpert
Drivers = VIA Arena
Apr 06, 2008 | Intel Pentium M 765, 2.10GHz...
Chaintech Slot 1 CT-6ATA2 Motherboard Logo
193 people viewed this question
Top Chaintech Computers & Internet Experts
Ed Mac
WTF Chuck.....
WTF Chuck.....
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
