Question about Garden
Stihl f5 280k engine manual or engine/curb settings
Where can I get a STIHL-CHAINSAW MS361-REPAIR-SERVICE-MANUAL
Here's another service manual for your Stihl,they don't make this model no more. Stihl MS361 Service Manual Cylinder Engine Clutch
May 31, 2017 | Garden
Hi there, Im looking for a repair/workshop manual for a Stihl HS80 hedge trimmer. Any assistance would be greatly appreciated. Cheers Gavin
Stihl don't publish manuals as such, they want to preserve their dealers. An HS80 is not complex and if you go to Barretts Small Engines online they have exploded parts pictures which should be all you need to strip it. Stihl do owners manuals online.
Sep 27, 2016 | Echo Stihl Primer Fits Hs80 Hs80 Hs45 Hl45...
Is the LA adjuster for oiler to chain& what 1/4 turn per run to check ratio??
PDF]STIHL MS 261/261 C Chain Saw Instruction Manual ' STIHL ...
www.stihlusa.com/.../ms-261-261c-chain-saw-instruction-manual.pd...
Stihlde la rueda dentada usada y de otros ... this manual to operate your chain saw. ..... 1/4 turn). Misaligned, damaged or broken cap. N. If the cap does not drop fully .... adjust the chain while the engine is running! Warning! To reduce the risk of fire ...... bolts and screws except the carburetor adjustment screws after each use.
[PDF]STIHL MS 200 T Arborist Chain Saw Instruction Manual ...
Dec 15, 2015 | Stihl Garden
Need repair and service manual for Stihl 012 chain saw engine
google the stihl web site and if there are manuals available ,you will find them there.
May 27, 2015 | Stihl 021 023 025 Ms210 Ms230 Ms250...
What are timing marks on 2001 kia rio 1.5 engine
3-13 Degrees
Application:
With manual transmission
Note :
Before top dead center, at specified curb idle speed.
Locate data link connector & connect jumper wire
between ground & engine test terminals.
After completing adjustment, remove jumper wire.
Curb idle speed (750 RPM) transmission in drive.
3-13 Degrees
Application:
With automatic transmission
Note :
Locate data link connector & connector jumper
wire between ground & engine test terminals.
When adjusting idle speed, set parking
brake & chock drive wheels.
Curb idle speed (750 RPM) transmission in neutral
Aug 18, 2010 | Kia Rio Cars & Trucks
I just purchased a Stihl 041AV chainsaw and need to know what the gas to oil ratio is. Thanks.
The quick/easy answer: Use Stihl (or comparable) two-stroke engine oil at 40:1. A good name brand gas is less likely to gunk up your engine.
Background:
The old manual recommended Castrol SAE 40 mixed at 20:1 with regular gas.
All the modern Stihl chainsaw manuals recommend using 90+ octane unleaded gasoline mixed with Stihl two-stroke engine oil at a 50:1.
Since this is an older saw that runs at a lower RPM than modern saws, you probably don't want to run it quite as lean as 50:1. 40:1 is going to be about the right mix
If you want a printed manual for your chainsaw, you can request one here.
Chainsaw collectors corner has some other useful specs here.
If this answer was useful, please give it a vote! Thanks.
Jun 14, 2010 | Garden
Stihl hs 45 Trimmer
remove clutch from stihl hs 45 engine
Apr 07, 2009 | Garden
Garden Logo
310 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
