Question about Jabra COMMUNICATIONS BT160 Bluetooth Headset Headset
How to turn on my BT160
Is there ant way i can connect my BT160 to my phone.while its chargng. Solid blue light is on.
  • 77 Answers
Cant charge and use at same time
Posted on Apr 15, 2009
I can not get the headset to turn on.
If I read everything correctly in the manual I believe the light only stays on when the device is in the pairing mode. If the light flashes every second, the headset is on a call, if the light flashed every three seconds, it is in standby mode.
Standby mode: is when the Jabra BT160 is passively waiting for a call. When you 'end' a call on your mobile phone, the headset goes into standby mode.
Make sure your phone is bluetooth equipped.
You must first successfully pair the headset with your phone. The manual shows you how.....
1. Put the headset in pairing mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to 'discover' the Jabra BT160 Follow your phone's instruction guide. This usually involves going to a 'setup,' 'connect' or 'Bluetooth' menu on your phone and selecting the option to 'discover' or 'add' a Bluetooth device.
3. Your phone will find the Jabra BT160 Your phone then asks if you want to pair with it. Accept by pressing 'Yes' or 'OK' on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Go here for a copy of the owners manual....
http://www.mainresource.com/PDFs/GNBT160User.pdf
Hope this helps.....
Jan 27, 2018 | Jabra BT160 Wireless Headset
Just bought the bluetooth and its asking for a passkey. idk if that passkey comes from my phone or the bluetooth, and how can i find out what that passkey is
go to the menu on your phone select manage connections set up bluetooth then you'll see search listen, etc. position on search don't press yet
get your ear piece ready: press the on button and hold it until you see a solid blue light (not blinking but solid) if it blinks try again until you get a solid blue light (it takes about 5-8 seconds) when that happens go to your phone and press search it will look for devices (it may find several) look for your earpiece model and select it
it will ask for a code or passkey, type 0000. Then it's going to ask if you want to bond or pair click yes and it will connect
check on the connection manager again and your bluetooth should be on and connected.
if it works for you, don't forget to rate me
thx
Jun 03, 2010 | Jabra BT160 Wireless Headset
How do you put the device into discovery mode
Before you use your Jabra BT160, you need to pair it with your mobile phone. 1. Put the headsetin pairing2 mode Make sure that the headset is on. Press the answer/endbutton and press the volume up (+) button at the same time, until asolid blue light comes on. 2. Set your Bluetooth phoneto ?discover? the Jabra BT160 Follow your phone?s instruction guide.This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menuon your phone and selecting the option to ?discover? or ?add? aBluetooth device 3. Your phone will find the Jabra BT160 Your phonethen asks if you want to pair with it. Accept by pressing ?Yes? or ?OK?on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros).Your phone will confirm when pairing is complete. In case ofunsuccessful pairing, repeat steps 1 to 3.
USER GUIDE
Jan 03, 2010 | Jabra COMMUNICATIONS BT160 Bluetooth...
Need PIN code to re-connect Jabra BT350 Bluetooth Headset w/phone
I had the same problem-- i asked a verizon wireless guy and he said it's almost always four or six zero's so "0000" or "000000". Hope it works for you!
Jan 23, 2009 | Jabra BT350 Bluetooth Headset Headset
My LED never goes solid...??
MINE HAS ALWAYS BLINKED TO BUT IT STILL WORKS MINE HAS NEVER STAYED SOLID
Aug 30, 2008 | Jabra BT160 Wireless Headset
I do not have manual for jabra bt160 how do i connect to phone
Wear it how you like it 4
5
English
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2 )
For optimal performance,wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight.In general,you will get better performance when
there are no obstructions between your headset and your mobile phone.(See fig.5 )
Answer a call
Tap the answer/eend button on your headset to answer a call
End a call
Tap the answer/eend button to end an active call
Reject a call (DDependent on your phone supporting this feature)
Press the answer/eend button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (ssubject to phone
settings) automatically transfer to your headset
Activate voice dialing (DDependent on your phone supporting this feature)
Tap the answer/eend button. For best results, record the voice-dialing tag through
your headset. Please consult your phone ’ s user manual for more information about
using this feature
Redial last number (DDependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+or – ) to adjust the volume (See fig. 1 )
How to...5
1. Put the headset in pairing 2 mode
Press the answer/eend button and press the volume up (+) button at the same time,
2. Set your Bluetooth phone to ‘ discover ’ the Jabra BT160
Follow your phone ’ s instruction guide. This usually involves going to a ‘ setup,’
‘ connect ’ or ‘B luetooth ’ menu on your phone and selecting the option to ‘ discover ’
or ‘ add ’ a Bluetooth device.** (See example from a typical mobile phone in fig. 4 )
Pair it with your phone 3
English
Turn on your headset 2
Press the answer/eend button to turn on your headset
Press and hold the answer/eend button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
The Jabra BT160 is easy to operate. The answer/eend button on the headset performs
different functions depending on how long you press it.
Instruction:Duration of press:
Tap Press briefly
Press Approx: 1 second
Press and hold Approx: 5 seconds
Getting started
Your phone then asks if you want to pair with it. Accept by pressing ‘ Yes ’ or ‘ OK ’ on
the phone and confirm with the passkey or PIN 3 = 0000 (44 zeros).
http://www.jabra.com/Sites/Jabra/UK-uk/support/Pages/JabraBT160.aspx
It is all in there www.jabra.com
ARTGIRL
Jul 18, 2008 | Lands Phones
How do i install the phone
From Jabra's Support site:
Place the BT160 in pairing mode:
1. Turn the BT160 on. To do this press and hold the answer/end button until the light flashes blue, then release.
2. Press and hold the answer/end button and the volume up (+) button until you receive solid blue light. This may take up to 10 seconds.
3. Go into the Bluetooth menu on your cell phone and follow the cell phone’s instruction guide for pairing a Bluetooth headset. This generally involves going into a “devices” or “hands free” menu and adding a new device. Your phone may ask if you want to pair with the headset, accept by pressing “yes” or “OK” and confirm with the passkey or PIN 0000 (4 zeros).
Jan 20, 2008 | Grandstream BT 101 IP Phone
My Jabra BT160 won't connect to my Nokia 6103 why?
hold the on/off button and the + button for 2 min. If you fail at the first time. Try again, until you see the blue solid light. Search again in your phone, you should see Jabra bt160. Enter 0000 at the passcode. Good luck
Nov 07, 2007 | Jabra BT160 Wireless Headset
Jabra bt160
hold the button down for a long time
Apr 17, 2007 | Jabra COMMUNICATIONS BT160 Bluetooth...
Jabra COMMUNICATIONS BT160 Bluetooth Headset Headset Logo
182 people viewed this question
Top Jabra Radio Communications Experts
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
