Question about Hansgrohe 41535000 Axor Uno Toilet Brush & Holder Chrome
Hansgrohe 41533 wall mounted soap dish install
I do not have the spec/install sheets for a hansgrohe 41533 wall mounted soap dish and cannot get the set screw out (it is not hexagonal to use allen wrenches)
I had the same problem with a Hansgrohe set screw on my toilet paper holder. Thought an allen wrench would do to open it but it does not work, I had to use the end of a pointy dinner knife to coax it out, might have also used a flat edge glass repair screwdriver also to get it out. It almost look as if it was "stripped" in the opening. I'm now trying to find a replacement set screw and came across this page. Hope that helps.
Posted on Sep 28, 2010
How to install hansgrohe toilet brush
This model has a bracket that will mount to the wall using two screws and plastic anchors. Then the brush holder will snap into place on this bracket. There will be a hole in the bottom of the holder that will look like a set screw but this is only a push pin. It is spring activated and not threaded. To remove it you simply push up on this pin and pull the holer off the wall bracket. If you need further help feel free to contact Hansgrohe Tech at 1-800-334-0455. Press 2 for Tech and Ask for David Scarborough. I'll be happy to help.
Nov 20, 2012 | Hansgrohe 41535000 Axor Uno Toilet Brush &...
Adjust hot water on hansgrohe metro shower
The hand shower and wall bar does not control temp. The valve in the wall would control the temperature of the water going to the shower. I would need to be able to identify the model number of the valve in the wall to be able to give accurate instructions on temperature adjustment. If you need help identifying this valve feel free to give me a call at Hansgrohe 1-800-334-0455. Press 2 for tech and ask for David Scarborough
Oct 13, 2012 | Hansgrohe 06496 Croma Hand Held Shower -...
I have a Grohe liquid soap dispenser and the washer is leaking soap at the base of the unit. can this washer be replaced?
it is not available from Grohe but if you take it apart it is probably generic enough to be found at your local hardware store. assuming this the problem. it may just need to be tightened up a little. either way here is a link, w/an adobe file (specification sheet), regarding the specs about 1/3 down the page on the left. you can also purchase the soap dispenser here. hope this helps:)
http://www.faucetdirect.com/grohe-28-751-deck-mounted-soap-dispenser/p54966
Jul 26, 2011 | Grohe Soap/Lotion Dispenser 28.857.AV0
I am looking for a Greewich (Delta) satin nickel wall mount soap dish and can no longer find any vendor who sells them.
I've found several different styles & manufactures of satin nickel bath hardware at Home Depot and Lowes. Soap dishes,towel rods,toilet paper holders and even matching toilet flush handles.
Jun 22, 2011 | Liberty Hardware Bath Unlimited Greenwich...
Where can i buy a replacement soap tray for the Baldwin Edgewater Wall mount soap dish?
Your product is available here:
http://www.baldwinbrasshardware.com/images_collection/baldwin_bath_edgewater.htm\
The site makes no mention of making available replacement parts. Suggest you contact the company directly to see if they would provide a replacement dish without the complete hardware package.
Contact Information:
http://www.baldwinbrasshardware.com/contact.htm
Jan 22, 2011 | Baldwin Edgewater Soap Dish in Satin...
How install the soap dish
There are a couple of designs, one is surface mount and the other is recessed. Surface mount mounts with silicone (hard to imagine it would last) and the other installed similar to a tile, but using grout. The grout install gets a hole cut in the tiles, goop everything up with grout, and goosh it into the wall, clean same as you would when working with grout.
Both designs need support until the adhesive dries.
Dec 12, 2010 | Daltile Bathroom Accessories Resin Soap...
Installing a resin shower soap dish,
liquid nails will do the job but you can also use clear silicone provided both surfaces are dry.
Feb 02, 2009 | Daltile Bathroom Accessories Resin Soap...
Soap not coming out of dispener and dishes not getting clean
Please be more specific. Make and model of machine and is the dispenser part of the machine, or mounted on the wall?
Aug 18, 2008 | Dishwashers
Hansgrohe 41535000 Axor Uno Toilet Brush & Holder Chrome Logo
187 people viewed this question
Top Hansgrohe Home Experts
ray gallant
Daryl Gleaton
Are you a Hansgrohe Home Expert? Answer questions, earn points and help others
