Question about Canon imageCLASS D860 All-In-One Laser Printer
Canon Image Class D880
System error: EXXX
    Problem Solver:
  • 10 Answers
Re: canon Image Class D880 - Canon imageCLASS D860 All-In-One Laser Printer Printers & Copiers
Posted on Nov 06, 2007
0 characters
3 Points
System Error
Sometimes, this class of copier will "hiccup" and throw an "Exxx" error code; most of the time nothing is really wrong, it just needs to be reset. You can try the following procedure to reset the copier: First, you press the Additional Functions key, then you press the # key, next you press > until you get to #7 Printer Function, then you press Set, next, you press > until you get to #4 Printer Reset, once again, you press Set, then press <. After this is done, unplug the copier, then plug it back in and turn it on. The machine should reset and go back to normal functions. If the code appears again, there is a deeper problem and a Canon tech will need to be called. Good Luck!
Oct 21, 2009 | Canon Image Runner 1630 Copier Copier
I just received an E003 error when running my Image Class 860 copier. Any suggestions? Thank you so much!!!
Please clean the fuser unit thermistors and thermofuses and verify the continuity the fuser heater lamp.
Sep 28, 2009 | Canon ImageClass D880 Copier
D880 printer won't put toner on the paper (prints blank)
make sure the replaced toner is in good condition and is placed properly in printer refilled toner often alarm about low ink but work properly
Jul 22, 2009 | Canon imageCLASS D880 All-In-One Laser...
Cannon image class D880 System Error E000
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
Jan 12, 2009 | Canon imageCLASS D880 All-In-One Laser...
Printer D880 Cannon System error E000. What will fdix it?
From a fellow FixYa expert, "Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in. If this don't work, get a new fuser."
Jan 06, 2009 | Canon imageCLASS D680 Laser Printer
Need printer driver for Canon D880 Image Class
Here you go. Just select your OS from the drop down.
Please rate this solution.
Nov 30, 2008 | Canon ImageClass D880 Copier
System error E000
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
Jan 14, 2008 | Canon ImageClass D880 Copier
Canon imageCLASS D860 All-In-One Laser Printer Logo
53 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
