Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
How do I get the key symbol off - on my condenser dryer
This is the child lock. It prevents the buttons working.
Press and hold the 'MENU' button for until the symbol dissapears (about 5-6 seconds)
You can activate it the same way once the cycle is going thus preventing accidental changes to the programme.
Annoying until you know how but useful when you do.
Regards
Blitzspear
Posted on Jun 09, 2009
Error code LOC ?
LOC means that the control lock has been engaged. (This feature also keeps a child from changing any setting when a load is in progress or starting the dryer with the cat in the unit.) On at least one Frigidaire dryer, press and hold the Options and Select touch pads for at least 10 seconds (until the display changes) to toggle the lock on and off.
Usually, the two keys to press for the Control Lock will have a line between them with a padlock symbol in the middle of the line. (This symbol will be in a very small font.) This may help you find the keys to press if other models of Frigidaire dryers use a different combination of touch pads.
I hope this helps.
Oct 24, 2013 | Frigidaire Electric Dryer
My siemens iq700 dryer wont start it has a symbol of a key?
Press and hold the "Finish in" button until the key symbol goes out.
Nov 05, 2012 | Dryers
The machine showing a key symbol
Must be locked
lots of machine use a lock out mode to prevent children from playing with the machines. Not familiar with siemens equipment
Sep 25, 2012 | Siemens ultraStack WT46E300US Electric...
Have a Bosch logixx condenser dryer. key sign on screen
You have activated the child lock, basically you have held the start button for over 3 secs. turn the dryer to the cycle you want and keep your finger on ther start button to deactivate. If this doesn't work you may have a module problem. Double check your manual for child lock info. if no module go to link and enter you Enr number.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Jul 02, 2010 | Bosch Dryers
Our Bosch Classixx Condenser Tumble Dryer works but there is no heat. I have cleaned the Condenser Unit and the filter and emptied the water, but still no heat. Please advise. Thanks Craig
my wte84105gb condenser dryer (bosch) as a symbol on it looks like a glass with wavey lines inside it will not dry please advise what to do .
Feb 26, 2010 | Bosch Axxis WTA4400 Dryers
A key symbol has displayed on my panel and the dryer will not work. Not sure what I need to fix. opened door to take out some clothes and now it won't start up againg... beep beep and key shows
the door lock has gone it sounds to me the dryer wont work unless the door is shut so if its not picking that the door is shut then it wont work
hope that helps :)
Oct 15, 2009 | Dryers
I need advice on dryer for my kitchen.
This isn't an add its two different units that I have installed and are both condensation dryers. Which in my opinion is better for your needs and lacking venting.....LG and Miele also have 15 cycle so now the decision is what your needs and Budget. Prices range from 700-1500 but well worth the money. Bosch Axxis Condensation Dryer (model: WTMC8320US) you can machine-dry clothes without venting hot, moist air (or indeed any air at all). The Axxis Condensation Clothes Dryer condenses the moisture in the hot air to water and releases it through the water the need for ducting and a blower motor to help expel hot air. Ventless dryers make installation easy, fast, and very cost effective. And since little heat is lost when the air passes through the condensing chamber, it takes very little energy to raise the temperature back to optimal drying levels, thereby saving you energy. The Bosch Axxis ventless dryer features the unique DUO TRONIC system with 11 auto dry cycles that tailor the drying cycle to your clothing. And Bosch's exclusive DUO TRONIC system combines two moisture and three temperature sensors to automatically deliver precision drying. This machine virtually operates at the touch of a button to prevent over drying and damage to your clothes. With the stacking unit I think this is your best option due to keeping moisture, and later mold problems due too condensation. The Ariston Stackable Condensing Dryer ASL75CXSNA is the perfect choice for any home lacking venting capabilities and is the largest condenser dryer on the market, bringing the convenience of a compact laundry system to any home. Wrinkles are minimized with the innovative Pre and Post CreaseCare feature - periodically tumbling the clothing until you come back to remove it - and the handy Bidirectional Rotation of the stainless steel drying drum. Clothes gone musty from long closet stays can be quickly and easily refreshed with the ASL75CXSNA using the intuitive Air Fluff cycle, and the 12-hour Delay Timer allows for freshly-dried loads at your convenience.Key features include: spacious 16-pound load capacity; 180º reversible full metal door; removable lint filter; included stacking kit; Easy Iron option; and electronic Sensor Controls. The Ariston Stackable Condensing Dryer ASL75CXSNA has the high class, top performance, and compact convenience to be a welcome addition to any energy efficient home.Note: This item pairs with the matching Ariston Stackable Washers. I hope this was helpfull~ Have a good day
Feb 05, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch exxcel wvt1260
I have a Haire combo unit. (washer/dryer) The dryer is a condenser type. I had a this problem with the dryer part of my unit. It was still under warranty at the time so naturally I called. When the tech came out he discovered that the heating element had melted the fan all over the blower elements. this problem could have been fixed, however, Haire came out with a newer model and couldn't get the parts anymore because they weren't making them anymore. Needless to say that totally sucked. But, at least the washer still works great. Upon doing a little research, I discovered that most condenser dryers do get too hot to support one or more of thier internal elements. I would not get another dryer like this without asking about this problem and if there has been any rectification of this issue and how so.
Jun 23, 2007 | Bosch Exxcel WVT 2850 Front Load Washer /...
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
497 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
