Question about CyberPower 325SL (CPS325SL) UPS System
CyberPower 325SL backup system
I have a CyberPower 325SL backup system w/ an internal battery and lately it has been plugged into another surge protector and has worked fine. I took it out to use it separately and now it will not work properly. The battery charges and when I plug in/ turn on the surge protector the "Power On" light comes on for about 5 seconds and then the system turns off and starts to make the characteristic long beep. I've tried turning it on and off and also have plugged it into several outlets in the house and the problem seems to be with the surge protector.
  • 26 Answers
That's a tell tale sign of wornout batteries. They last about 3-4 years in a UPS like this. Here's a replacement: http://www.batteryinternational.com/cyber-power-cps325sl-ups-battery-ups-batteries-f1.html
Posted on Oct 23, 2009
    Scholar:
  • 136 Answers
How old is the unit and have you ever replaced the batteries?
Posted on Sep 15, 2007
2 Suggested Answers
SOURCE:
flopez
  • 161 Answers
SOURCE: CyberPower 325SL won't work...
NEVER mix surge protectors and UPS!!!. Doing so overloads whoever of the two gets connected to the wall. This equipment is built to be plugged DIRECTLY to the wall. Your unit just crossed it's inner battery. Take it to a recycling center, then stop on your favorite electronis shop and buy a new one.
Posted on Sep 21, 2007
Why is my Cyberpower 550 VA surge protector beeping in set s of 3 beeps every few seconds after a power failure in the house?
This is a battery backup power supply as well. The beeps alert you that you need to power down your equipment before the battery fails.
The website is here with Support and Manuals
https://www.cyberpowersystems.com/support
Dec 24, 2015 | CyberPower Computers & Internet
Not Working During Power Outage
Bad battery in the UPS. To test unplug all equipment. Check outgoing power with voltage meter. Should read around 115vAC. Then unplug from the wall outlet. Check voltage again. If no voltage is present its a bad battery.
Sep 04, 2013 | CyberPower Computers & Internet
Why does the 4 outlets (surge only) of my cyberpower 685avr work while the 4 outlets with battery doesn't?
The battery only works when it isn't plugged into the wall. That's what a battery backup is for,so when the power goes out, the battery kicks in.
May 08, 2011 | CyberPower Intelligent AVRLCD...
Hi there, I'm wondering if I can use my "Trip Lite Office UPS500" as a surge protector only (the left 3 outlets), I don't need the battery back-up? Is it going to work properly without the...
Yes it will work just fine make sure that the outlets you are plugging into the 3 are surge protected. Thanks for using FixYa! Most battery backups and backup modules are surge protected on-board. John
Mar 19, 2011 | IBM Tripp Lite Internet Office 500...
Surge protectors
No no need to charge there may loose contact between power cord and surge protecter or internal loose contact between sockets that can be removed
Nov 12, 2008 | APC Back-UPS Office 500VA (BF500) UPS...
Reseting my surge protector
What is the model of your battery back up? When does it beep? What kind of beeps?
Nov 02, 2008 | CyberPower 575SL (CPS575SL) UPS System
CyberPower 725SL
hi im wesley. you plug it into surge you only plug it into battery surge if you are running a backup battery supply for your tv
Jul 10, 2008 | Computers & Internet
Turned off my system
Well, it did just what it's supposed to do, protect your system from bad power. You probably had a power failure during the thunderstorm and your UPS shut down your PC. When you turn it back on the battery was too low and it shut off you PC again.Check your UPS software in windows, you should have an option to run a self test. But it should be just fine.
A.J.
http://www.CustomAutomaticSystems.com
Jan 11, 2008 | CyberPower 325SL (CPS325SL) UPS System
The battery plug in area is dead but the surge protector side works
Hello Vicki,
What you are describing is usually a result of the batteries losing their ability to hold a charge.
The surge protector side does not rely on the batteries.
I found good batteries at a reasonable cost on ebay, but I think you're going to need to replace batteries at this point.
Hope this helps.
Charlie
Nov 18, 2007 | Cybernet Systems CyberPower 625AVR...
Sep 14, 2007 | CyberPower 325SL (CPS325SL) UPS System
CyberPower 325SL (CPS325SL) UPS System Logo
306 people viewed this question
Top CyberPower Computers & Internet Experts
Richard Glass
Richard Glass
Level 1 Expert
Paul Bade
 Mike M
Mike M
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
