Question about Krups Small Appliances Espresso Machine
It just doesn't turn on anymore...
This is the second Krups Machine in two years. It's a fnd1 and was working great for a year but out of nowhere it just won't turn on. Any advice?
  • Anonymous May 06, 2009
    Inherited a cremomatic coffee/espresso maker, and the espresso maker worked off and on for no reason I know. Now won't work.
    Any suggestions??
    Problem Solver:
  • 14 Answers
Check the thermical fuse.
Posted on Jul 07, 2009
I had a similar problem and this is how I solved it:
There is a small & thin plastic frame behind the button which presses the actual switch if you push the on/off button. You can reach it by sliding up the alu colored frame and unscrewing the panel which contains the LCD display (torque screws !) .
In my case the plastic frame was broken and I glued it with special glue for polyethylene plastics.
(f.i. Pattex plastics glue with activator)
Posted on Jun 21, 2009
Krups FND1 lid pressure release spring and seat came apart. How do I reassemble the safety release?
The lid is broken, you need a new lid. I have checked online and it is available, part number is MS 0927155. There will be small plastic pieces in the boiler, fill it up and tip it upside down & shake it about.
Jan 13, 2015 | Krups Coffee Makers & Espresso Machines
KRUPS FND1 HOUSEHOLD ESPRESSO MAKER MANUALS
There are similar manuals here, maybe they will be helpful for the model that you are looking for - http://kitchen.manualsonline.com/manuals/mfg/krups/krups_coffee_grinder_product_list.html
Jan 31, 2010 | Krups Allegro FND111 Espresso & Coffee...
I just recieved a krups fnd1 used..do i have all parts
You should have the main machine, the screw-top to the main machine, a handled cup that holds the grounds, and inside that should have a metal lining. Drain basin. Main body should have: Screw top, turn-switch, milk foamer attached.
Aug 29, 2009 | Krups Allegro FND111 Espresso & Coffee...
Need a manual instruction for Krups Allegro Espresso FND1
Go to krupsusa.com and click on "instructions" they have it there
Jun 08, 2009 | Krups Allegro FND111 Espresso & Coffee...
Can I get an instruction manual for KRUPS FND111
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={706F793F-3236-4CA4-B5BA-C414DF982294}&SelectedProdRef=FND1
From the Krups website.
Apr 06, 2009 | Krups Allegro FND111 Espresso & Coffee...
Learning how to use the krups FND1 espresso machine
we have problem with coffee machine faema presidentE98 2 group, the problem is motor pump is still running, water boiler is full can't stop or cut off power to motor pump? so what solution ? thank's ,
junaedi
Jan 18, 2009 | Coffee Makers & Espresso Machines
Machine won't work
This machine does not have that muck electronic, the button switch has probably a short, and must be replaced.
As said the machine is Krups, and therefore should be covered with one year warranty. Call the number listed on the user manual, or find contact from websites below:
Coffee & Espresso Machines - Small Domestic Appliances - Krups
Home - Krups UK
Jan 03, 2009 | Nespresso Aeroccino Automatic Milk Frother
Hi, we have a Krups espresso machine, model fnd1. We can't seem to make the milk steamer work, it will make the milk REALLY hot, but not foamy. Do you replenish the steam supply somewhere? Is there a...
suggestions include very cold milk.  having the nozzle just barely in for frothing.
On my model there's an air passage in the nozzle that foams quite nicely.  If you have that too, it might be clogged with milk.  You have to keep these clean with every use.
Jul 11, 2008 | Krups XP4030 Espresso Machine
Krups FND1 water escape
What position do you have the knob in? According to your manul it should be in position 9 not in position 8 for steaming.Good Luck.
Apr 11, 2008 | Coffee Makers & Espresso Machines
Krups XP4030 is stuck in the steaming mode
Here is a link for the manual. It says on Krups web sight they have a 1 year warranty,
http://www.krupsonlinestore.com/manual/55360.pdf
Nov 02, 2007 | Krups XP4030 Espresso Machine
Krups Small Appliances Espresso Machine Logo
258 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
