Question about Video Game Consoles & Games
How do i open the unit to replace power jack
I need to replace the power jack on a ps2 , i have removed all the screws on the bottom of the unit but it is still locked with a spring clip,how do i open the unit without forcing it, thanks, alan
    Problem Solver:
  • 18 Answers
Yup,
This common problem and can be cured quite easily with A Free, very good, 6 step, pictorial guide which can be downloaded from this link in PDF format
http://www.4shared.com/file/147985790/765fc3d0/PS2_SLIM_PDF.html
And the replacement part can be found on Ebay ot the net, however this Ebay seller is about as cheap as they come.
http://shop.ebay.co.uk/flettech/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p4340.m38
Hope this helps!
Posted on Dec 05, 2009
How to replace the DC Power jack of my acer aspire 7735Z
Replacing a DC Power jack in any computer is no easy task. However, it can be done by any novice. First, get on ebay and see what jack you need. Search for you jack by entering Acer Aspire 7735z jack. Most of the new ones have the cable attached to the jack instead of the old fashion solder.
Next, Google this question and check out the YouTube videos regarding Acer DC Jack replacement. It will give you an idea as to what you need to do. You may want to take a video camera and record what steps you take when you take it apart so you can review how to put it back together. Also, get a sewing box or something so you can put the screws in a separate container for the order you removed them; ie: bottom screws; hard drive screws, DVD mount screw... etc..
You always have to start with the bottom and work your way to the top. You will have to remove the palm rest, keyboard, heat shields and any other piece of hardware to get to it.
YouTube is your friend...
Aug 12, 2014 | Acer Laptop DC Power Jack for Acer...
PS2 is on, but no signal
The tray has become misalligned. If you want to fix it on your own heres what you do. Remove the 6 (or 8 depending on generation) screws on the bottom. Remove the warranty sticker on the back by the power switch. With the front towards you, lift the top while tilting slightly toward the front and pivoting it by the power/eject buttons. Either remove the button assembly by popping it off the lid or just be careful not to tear the cable. Remove 4 philips screws from the cd mech lid and lift off. Remove two philips screws from the tray hinge. Lift and slide tray out of front. Push white gear frame at front of tray area to the right and hold it there while you put the tray back in. Reassembly is reverse of disassembly.
Sep 13, 2007 | Sony PlayStation 2 (PS2) Console
How do I open the iLuv iSP200 chassis?
When looking at the front of the unit. The metal grill has 4 crimped tension points on top, 4 on the bottom, and 2 on each side (total of 12). Use a small flat screwdriver to gently pry them forward, I just gently pulled on the top four, starting at one end and working towards the other. Then gently lift the grill off.
Then there are 8 P1 (#1 Phillips) screws on the front. There are also 2 Phillips screws on the bottom, 1 under each of the rubbery feet.
Once they are all removed (10 screws in total) the unit simply opens in 2 halves.
Hope this helps.
Apr 26, 2014 | ILuv ISP200
Our ps2 took a fall down the stairs, needles to say it doesn't work. any idea's?
If the unit powers on, but not reading a disk try moving the laser back and forth. If it doesnt seem to move smoothly, then the motor that moves the laser has probably come out of the socket. I have seen this on multiple units after they have been dropped. If this is the case you will have to remove the 6 screw covers and screws from the bottom of the ps2. Then remove the top cover starting at the back. Be careful not to break off the power switch. Then look for the brass gear that moves the laser back and fourth on the right side of the unit. Push it back towards the motor and back in the hole. Hope this helps
Nov 28, 2009 | Sony PlayStation 2 Slimline Console
No power up
Take out all the screws from the bottom of the PS2. There are rubber pieces covering all the screws so make sure all the rubber pieces are removed first then unscrew the screws out of there.
After that then the top cover should come off and you'll have access to the main board of the ps2.
Aug 07, 2009 | Sony PlayStation 2 (PS2) Console
I require instructions on how to replace the ps2 laser block
The screws are under the square caps on the bottom of the unit.
one may be covered w/ sticker.
Do a websearch for "changing laser pickup PS2" ...There's plenty of helpful sites.
Mar 25, 2009 | Sony PlayStation 2 (PS2) Console
Opening laptop
I had a similar problem taking apart my laptop, come to find out I had to open it up, remove the keyboard, under which there were two more screws.
Dec 13, 2008 | Computers & Internet
Power problem
You need to remove the screws on the bottom of the laptop. Once the right screws are removed the case will seperate exposing the MOBO and that and you should see the dc jack (power jack) as forwarning, almost ALL dc jacks are sodered to the motherboard..and not easy to successfully replace.
Jul 24, 2008 | Averatec 3200 Notebook
Ps2
see this video......
Jan 19, 2008 | Sony PlayStation 2 (PS2) Console
Broken power switch
Sometimes someone will have somethhing sticky on their fingers when they press the power reset button and cause it to glue in place. What you have to do is Remove the screw covers, and 6 screws from the bottom of the slim. These covers are square and one is under the warranty sticker. Tow of the rubber pad feet will remove to expose the screws. Use a knife to pry up the covers. Two of the rubber feet do not remove, they are the ones closest to the front. Open the case, and check to see if you can clean up the power switch button. It is attach to the top half. no problem getting the plastic top half wet when you clean it.
Nov 17, 2007 | Sony PlayStation 2 Slimline Console
Video Game Consoles & Games Logo
134 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
