Question about Panasonic PT-47WX49 47" Rear Projection Television
Colors are blurred, Please HELP
I have a Panasonic PT-47WX42F. It has allways worked great until now. The colors are blurred togther, specifically the green. it appears to be several inchs off center compared to all other colors. I bought this set used and did not recieve a manual with it, and am assuming it should be "Tuned up"? Any help would be Great. Thanks, Brett
  • Doc820520 Sep 15, 2007
    I have doen this, and can not get the green to come back in line. I have adjusted both convergence settings and still have the same problem. Any other ideas would be great.
  • 42 Answers
I think you may have changed the color control function slightly. It is commonm and you just need to go to the tv menu and correct the fault.
Posted on Sep 14, 2007
  • Lian Godkin
    Lian Godkin Sep 15, 2007
    Have you heard of gamma control? Have you tried changing all those gamma settings to 50, 50, 50? It may work.
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
Jul 16, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX42F outer most screen cracked
Look for a used Panasonic PT-47WX42F One in Local ads, Or place a wanted ad for your model. ~ Or if you want A new one, Get ahold of a TV Shop And OR Panasonic and be ready to spend lots of $$$$ ~ And yes there easy to replace!, Make sure you have a large clean area to work in, And a helper. Becarful and replace them back in as they came out! ( Top Bottom) they should be marked with a small tag or mark.... Geo*
Jul 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic 53" tv
Blue background lines with colors otherwise OK may be a loose or dirty blur drive potentiometer on small circuit board behind front grille and beneath front imerboard cover. These are hot-glued in place from factory but may be the cause f the problem. They're VERY sensitive.
If you have bowed blue lines instead of properly aligned colors, you probably have a blown convergence amplifier IC. These boards are no longer available so yours will have to be repaired. Some shops repair them but many send them out for 6-10 weeks. Fairly expensive too considering the amplifier chips are about $35 each (x2).
Jun 01, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX42F does not come on light flashes 3 times HELP!
There is a service manual which should cover this model/chassis series:
Elektrotanya for electronics experts
(PDF format - free - no sign-up needed - 100% clean)
Page 11 ('auto diagnosis feature') shows a table of LED flashes and what each one means. I'd start by checking D-board (since that is power and deflection) and going from there.
Dec 21, 2017 | Televison & Video
My darks are to dark on TV
what happens if you adjust the contrast or brightness?
Feb 21, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic 47wx42f projection
It sounds like your may need to replaced your convergence ic's loc# ic7001 and ic7002 stk392-110. That should take care of your alignment problem.
Dec 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
79 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
