Question about Ovens
Lang gas oven
We bought a used double deck Lang GCCO oven and the bottom oven won't start even though the pilot light is on. Any ideas?
  • leonora Dec 14, 2007
    pilot light is on but oven won"t start
    Scholar:
  • 136 Answers
The thermostat may be faulty for that section of the oven, it checks to make sure there is a pilot flame via a thermostat that turns the gas on. The thermostat that turns the gas on is usually located next to the pilot light.
Posted on Sep 15, 2007
SOURCE:
Hi The pilot light when out and the oven has stop working does the pilot light double as a fuse ?? BSO 6000
No. The pilot light uses a thermocouple(safety device) to let the main gas valve know that the pilot is lit so that the main gas valve can operate safely by not letting the main gas valve turn on without a lit pilot light. This way, in no way can the main gas valve turn on until the heat from the pilot light causes the thermocouple to produce an electrical current which allows the main gas valve to operate when the thermostat switch closes.
Nov 22, 2015 | Ovens
Program board
Check with Lang regarding availability of a board
Aug 09, 2013 | Lang Manufacturing 1 Deck Electric...
Why is the main 24 volt coil contactor chattering? I replaced the 3-pole contactor and thermostat but problem not solved.
chech the voltage going to the contactor if it is less then 21 volts i would change the transformer. sometimes the contactor will chatter because it is not getting enough voltage.
Nov 23, 2011 | Lang Manufacturing LGM-ECCOAP 1 Deck...
The Pilot Light on my Delonghi DEBIE 24 SS Electrical is on even though the oven is off - any idea how to correct this?
The pilot light stays on most none electric lighting for gas appliance, this is normal if you do not have an electric ingnition on your oven.
Hope this is helpful
john
May 17, 2011 | Ovens
Neff double oven u1442, main oven thermostat light does not work even though oven heats up. Is there a fix?
If the oven is heating up o/k, then I would suggest that the oven pilot bulb has failed, I have come across this on several occasions, it usually just means replacing the oven pilot light.
Mar 18, 2011 | Neff U1452 Double circotherm plus Electric...
It won't heat up... even though there is a flame
Check The Power Source
If the gas oven won't turn on, the first thing to do is check the power source. Most modern gas ovens are electrically powered. Check to make sure the oven is plugged in and the breaker isn't tripped.
Check the Heat Source
When a gas oven won't heat, the pilot light can also be set too low; if the pilot is lit but the oven isn't catching, adjust the flame.
Newer gas ovens use electric ignitors that produce sparks. If the oven doesn't heat, the ignitor could be broken.
Feb 05, 2010 | Ovens
Pilot, controler and gas knob needed replacement
If you have the older Bakers pride manufactured more then 20 years ago and it has never had service, it sounds like the safety valve is defective, that's the red button you push in the light pilot, if the pilot is lit and when you turn the manual gas valve on for the main burner to lite and still it does not you problem still may be the safety and/or a failing thermocouple.
Apr 02, 2017 | Bakers Pride CO11-G2 Gas Double Oven
Lang gas pizza oven.. Main burners won't lite!
Hello. It sounds like, from what you said, you have a new thermocouple. The device it is attached to, the pilot safety, could have a problem internally that allows gas to the pilot, but does not open the main part of the valve, or electrically has failed on the main coil. If you have a thermostat with wires on it, you can jumper the wires, to bypass it, temporarily please, if it comes on, you need a thermostat, if not, it is the valve most likely.
Hope that helps, and thank you.
Feb 18, 2009 | Bakers Pride FC-616 Gas Single Oven
Won't light up
had the same problem, safety gas valve is sticking get a small hammer and tap saftey valve. Just bought a new saftey valve about 3 weeks ago pilot light lite but now flame. I have a blodgett oven made in the 60s. Blodgett is getting away from there swithes that they have been replacing them with a replaceable thermocouple.made by robert shaw. My supplier said that they are not on the market yet. oops! good luck from oswego ny pizza villa.
May 01, 2008 | Blodgett 911-DOUBLE Gas Oven
Ovens Logo
120 people viewed this question
Top Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
