My tower will not turn on I don't know what could be wrong with it under the power supply it's red. I only had it for a few month's and I tried everything.
  • 32 Answers
Does the power supply come on? theres a little switch on the back of the power supply it says 110 or 220. make sure its on 110. Also the red is coming from a light on the power supply or on the boards below the powersupply?
Posted on Apr 15, 2009
I have a Hp Dc5750 mall factor desktop that was working fine 2 months ago we moved and i shut down right and have not touched it for 2 months now it is making 2 short beeps and flashes a red light whe
Check the power supply connections inside the tower. The move may have dislodged one or more. You should also remove and re fit the RAM sticks - make sure the power lead is dis-connected when you do this.
Jan 25, 2013 | HP Compaq DC5750 Small Form Factor PC...
I have a Sharper Image Power Tower 200 and I don't know where to plug in the power cord. Thank you.
On the same side were the turning knob is located, all the way down under the base there is a very subtle slot to plug in your cord.
Aug 13, 2011 | Sharper Image Power Tower Motorized DVD...
If the red light on Compaq Evo D510 P4 keeps on blinking and the PC wont start when you try to power your PC then whats the problem ?
Power Supply.
Weak voltage power rail, or more than one.
(There are three power rails for the Power Supply used in your computer;
1) The 3.3 Volt power rail
2) The 5 Volt power rail
3) The 12 Volt power rail.
Wires with Orange insulation carry 3.3 Volts
With Red insulation carry 5 Volts
With Yellow insulation carry 12 Volts.
Each wire is connected to one power rail in the Power Supply.
{All Black wires are Ground wires}
The Power Supply in your computer is an SMPS. Switched-Mode Power Supply,
http://en.wikipedia.org/wiki/Switched-mode_power_supply )
I don't know what form factor your Power Supply is because you didn't state which model it is.
Small Form Factor (SFF)
or
Convertible Mini-Tower
or
Ultra Slim Desktop
Post additional questions in a Comment. Also state what model your Compaq Evo D510 is.
Regards,
joecoolvette
Jul 03, 2011 | Computers & Internet
I have a purex triton 300 pool heater that will not turn on. The power is on and there are no red lights. It is all green. The AUX green LED light is also on (don't know if this will help). I tried...
red light is calling for heat check control unit for heat enabled if ok see if heater runs with firemans switch jumped if ok control if not check safety circuit
Sep 11, 2017 | Pentair Pool & Spa
The power light is red and the bulb light is blinking red
OK...Did you replace the lamp with a Sony original? If you did, then carefully check that the door is closed properly.
May 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
My power brick light is yellow until i turn on the console then it turns red. whats wrong?
The power supply turns red when it detects a fault such as the power supply has to much current, the voltage is too high or the temperature of the unit is too high.
A few ways to trouble shoot this would be .
1. make sure the power supply is cool
2. try plugging the supply directly into the wall instead of a surge protector ,
3. if that doesnt work call 1800 4 MYXBOX and get a new power supply.
Dec 13, 2009 | Video Game Consoles & Games
Where exactly is the fuse on a emachine t3958
The fuse on the power supply would be on the primary side (before the transformer). It's usually either under the cover, or it's in the red voltage selector switch.
But...if you have some lights on the motherboard, it's not the fuse. The power supply has to send out a couple different voltages (usually +/- 5V, and +/- 12V). If parts of the computer have power, then you probably are missing one of the voltages. You could get a voltmeter and check each one, but chances are you will just need to replace the power supply.
Oct 15, 2009 | HP Compaq 175-Watt Power Supply
SR1000T won't power on
The click sound is the relay clicking when the power on. The power supply has something wrong so the protection relay is triggered and cut off power to main board. Test fans see if they are stucked and spinning smouthly. Smell if anything burn from the power supply box. Most likely, you need to change the power sup. Good luck
Aug 11, 2009 | Compaq Presario SR1000T (568657) PC...
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
