Question about Kenmore Sewing Machines
I have a Kenmore 30 Stitch, model 385.1884180 serial #21105527-it has started making a grinding noise when using stretch stitch choices. I have cleaned the machine. But the sound comes from inside the arm, not the needle area.
Easy fix... same thing happened to me. take the back part off by the on and off switch and you'll see the loose belt. loosen the single screw next to the smallest pully and adjust tension.
Posted on Jun 29, 2010
I would like to know what stitch number to put my sewing machine onto to stitch stretch material. I have a Elna 40 sewing machine regards Judy
Looks like stitch #06 might be a stretch stitch. You could probably also use a slight 08 or 09 zig-zag. Unless you are sewing something really stretchy (lycra) IMHO, a slight zig-zag is fine and actually is a lot faster than a stretch stitch which takes a few stitches forward and then one or two stitches in reverse. The stitch #09 is something that I use frequently for stretch fabrics.
Elina 40 Question and Answers
May 31, 2016 | Elna Sewing Machines
Looking for free manual for Kenmore 12511. or instructions on how to a just machine to sew stretchy material
Sears carries a lot of Kenmore manuals, however, there is usually a fee. Have never seen one for no cost.
BTW--be sure to use jersey or stretch stitch needles (ball point) for knit fabrics. You probably should use either a zig-zag or stretch stitch so the threads don't "pop" when the fabric overstretches the thread.
https://www.seamwork.com/issues/2015/06/knits-without-a-serger
search the internet for "sewing stretch fabric" or "sewing knits"
Apr 15, 2016 | Kenmore Sewing Machines
My new Singer machine ("Curvy") purchased last week (3/2014) has a page on stretch stitches. The way the book is written, it lists Straight Stretch Stitch on the same page as Ric Rac, HOneycomb, and...
A zig-zag is also a stretch stitch. Usually, a "built-in" stretch stitch will stitch forward a couple and then stitch backward and then stitch forward again (time consuming and uses a lot of thread--but suitable if that's what you want). Whatever you are sewing, whether it is a seam or finished raw edge and the fabric is stretch, you will need to use a stretch or zig-zag. A straight stitch will pop the threads as soon as the fabric has to give.
You can test your stitches on some scrap fabric and see what looks best.
An Over-edge stitch is just that, just a stitch over the fabric edge. It probably would not be suitable for sewing a seam.
Apr 09, 2017 | Singer Sewing Machines
I do really need to buy a stretch needle
Yes, for stretch or knit fabrics you need to use a stretch or jersey needle, they have a ballpoint which will push through the fibres and not pierce them. Right needle for the fabric sewn is critical to good stitch formation and each needle has a use life of 6 hours. Small zigZag stitch will work, straight stitch may pop under wear 10_23_2013_1_18_05_pm.png
Oct 23, 2013 | Sewing Machines
I am trying to alter a swim suit, and I need to use a stretch stitch. Does the Singer model 2638 have this feature?
Here is the stitch selection page from your manual
I would suggest that you use the stitch called "elastic overlock" using a stretch needle, you need a ball point tip on the needle to press between the elastane fibres in lycra. A stretch needle is blue, coated with a substance that makes it easier to stitch these types of man made stretch fibres, often size 75. If you can't get one of those, then use a ball point needle, size 70 or 80.
You need a stitch with forwards and backwards movement so that the stitching doesn't break under stress. Your machine also has a stretch straight stitch and this would be a forwards and backwards straight stitch so this will work too but can look a bit 'heavy' sometimes. But even triple zig zag narrowed down will work often.
If you are sewing leg edges with lycra, shop made garments will have clear swimsuit elastic sewn into the seam using a coverstitch overlocker, you'll never get as good a result with a regular sewing machine but you can get a reasonable finish with practice. This elastic is available to buy, you might want to use the overlock stitch to attach it to the fabric edge, stretching as you go, then turn it to the inside and use a stretch twin needle and straight stitch to top stitch from the outside, stretching the fabric as you sew.
Trust this helps you a little, 4 thumbs up if so. :-)
Jul 13, 2011 | Singer 2638 Mechanical Sewing Machine
I've got an Elna 634 overlocker, and want to turn
Just trim the fabric to the desired hem length plus one inch, then overlock around this raw edge with thread close colour match to the fabric.
You then have the choice of either stitching around with a stretch stitch on your sewing machine, or hand sewing.
Being lycra shouldn't change how you hem them unless the trouser leg is extremely close fitting and the hem seam is going to be under tension.
My first choice would be using a twin needle in straight stitch from top side but this finish can pop/break if the hem is under tension. But perfect for most knit hems.
If you hand sew then you can turn up hem allowance and put a length of fusible hemming web inside the hem allowance and press it to hold. Then do a back stitch hand sew around to hold hem in place.
If you sew with the regular sewing machine, then use either the stretch stitch or a very small zig zag, and a ball point or stretch needle.
On ready to wear you would see a coverstitch hem but your overlocker doens't have this stitch.
Jun 12, 2011 | Elna Sewing Machines
My Kenmore sewing machine model number is 17630, & when I try to set the stitch length from a Straight Stitch setting to a Straight STRETCH Stitch setting, there isn't any difference. I have the length...
Take a look at the stitch length dial. If you turn that dial counter clockwise (to about 7 o'clock), it will set to stretch stitch. Then all of the stretch stitch features will work. When you want to go back to straight stitching, just move that dial back to what ever stitch length you wish.
Nov 26, 2010 | Kenmore Sewing Machines
Hi i want to buy a sewing machine wich one is best. kenmore or brothers sewing machine
I would prefer Kenmore, enmore makes perhaps the largest selection of mechanical machines. The very cheapest Kenmore sewing machines, like the Kenmore Mini (*est. $100) and Kenmore 15208 (*est. $120), stick with a four-step buttonhole, and have just six and eight stitches, respectively. The Kenmore 15212 (*est. $150) and Kenmore 15218 (*est. $170) both have a one-step buttonhole. The cheaper Kenmore 15212 has 12 stitches. The slightly more expensive model has 18 stitches, including a smocking stitch, overcast and elastic stretch stitch in addition to the basics. Both Kenmore sewing machines are good, basic models, say reviews. Both have just a 90-day warranty, however. Bear in mind that Kenmore sewing machines are made by different Asian companies each year, resulting in varying degrees of quality; this also explains the low prices. Some users report difficulty with tension and light fabrics.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 03, 2010 | Kenmore 19365 Computerized Sewing Machine
How do I do a stretch stitch?
The bes way to hem a t-shirt on a household machine is to use a double needle, straight stitch. You will see two straight stitches on top and zig zag on the back. Just make sure the zig zag catched the top of the hem.
Feb 19, 2009 | Kenmore 12102
Sewing Machines Logo
294 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
