UPS software installs a file somewhere-where???
UPS software installs a file somewhere, not in its PowerPanel directory, that is interfering with installation of other software. I need to know what files get put in what places by the software -- correspondence with tech people at CyberPower have produced no information at all.
How can I find out what files go where? Or is there a program that will log the installation process, so that I can see what it does and where it places files, and the file names?
  • puzzledpeter Apr 17, 2009
    Although the PowerPanel program installs to its own directory, finally, with the invaluable help of Pietro Boggio, Sr Tech Support person at CyberSystems Inc, and assisted by Microsoft's Process Explorer,
    http://technet.microsoft.com/en-us/sysin...
    we found, after an hour on the phone, that in Documents and Settings\Administrator\Local Settings\Temp, there was a copy of install.exe. That had been the culprit, since the program I was trying to install also called a file by the same name.
    Removal of the temp file solved the problem -- the other program is working perfectly, and Power Panel has been reinstalled.
  • 326 Answers
Run the installer application in a sandbox using
http://www.sandboxie.com/
This should show you everything.
Let us know
Good Luck
Posted on Apr 15, 2009
Where can I get a manual for my 825 AVR Cyberpower?
Here's the User Manual [click HERE] and here's the PowerPanel Personal Edition Manual [click HERE].
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Apr 19, 2011 | CyberPower (R) CP825AVRLCD Uninterruptible...
Tip
How can you crate setup file or .exe using QT platform
We are developing software but we are unable to run in others PC/Computer. As we know that QT is Platform Independent and Open source Software, which is use Nokia to develop Mobile Application.
Needs:
  • Qt
  • Setup creator
  • libgcc_s_dw2-1.dll
  • mingwm10.dll
  • QtGuid4.dll
  • QtCored4.dll
Procedure:
  • When you start a project then automatically qt creates 2 folders within main Directory. One is "Debug" and another is "release".
  • If we are want to run application in other PC then we need ".dll" files and combined them.
  • Open My Computer and go to the "Installation Drive" where QT is installed.
  • Find out the Main Directory of the QT. If you install in "c:" then go to the c drive and open "qt" folder and get a directory name as "2010.01"
  • When you open "2010.01", then you can see another directory as "qt" open it.
  • You click on Search option from the "Standard Button" bar and type the libgcc_s_dw2-1.dll file and search it. When you find it copy the file and paste into your Project Directory's "Debug" folder. Do same things for another three ".dll" files.
  • After that you can run your application by the .exe file. Does not need to open Qt and open your project then run.
  • Now you can simply copy the project Directory and paste into other PC and open Directory and run it.
  • Or you can create a shortcut on the desktop as others software. From where you can run it by Click.
Deploy and Packaging:
If you want to create a setup file as other software, need to install it. Then -
  • First download a file "icinst", it's free. After that install it.
  • After that open it from start programs and windows will be come where you select your Project Directory and do "Next".
  • You can create a License Agreement as others software.
  • Do as per the given Instruction.
Note: Before create a setup file you must be collect all dll files and paste in "debug" folder
Imon Saha
on May 16, 2011 | Computers & Internet
Tip
Change The Default Location For Installing Apps
 As the size of hardrives increase, more people are using partitions to seperate and store groups of files.
XP uses the C:\Program Files directory as the default base directory into which new programs are installed. However, you can change the default installation drive and/ or directory by using a Registry hack.
Run the Registry Editor (regedit)and go to
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
Look for the value named ProgramFilesDir. by default,this value will be C:\Program Files. Edit the value to any valid drive or folder and XP will use that new location as the default installation directory for new programs.
on Dec 03, 2009 | Computers & Internet
Installed my zebra lp2844 on a new windows 7 machine. it worked at first until i turned the computer off, now it just says device has malfunctioned. USB Device not recognized. I have uninstalled and...
If you are using an Eltron printer, and you have not installed the printer driver, follow the instructions below. You must install the driver provided below. The driver provided with your printer will not work with UPS Internet Shipping.
Installing the Eltron Thermal Printer
Make sure you have set up your thermal printer equipment, cables, and thermal labels as described in your UPS Thermal Printer documentation.
The following instructions will help you download and install the UPS Thermal Printer driver program (UPS_319_117.EXE) to your selected directory.
  1. Select the Download the UPS Thermal Printer Driver link below.
  2. When prompted by the File Download - Security Warning dialogue box to choose Run, Save, or Cancel, choose Run. When prompted by the Unknown Publisher Security Warning, "Are you sure you want to run this software?", choose Run.
  3. Select Unzip to extract the files. Once files are extracted, select OK and then select Close to close the window.
  4. Navigate to C:UPSDrivers and double-click the file setup.exe to start the Installation Utility.
  5. Select the language to install.
  6. When prompted, select the Printer Interface you will be using, then click Next.
  7. USB Connection or Other Connection and click Next. You will be prompted to choose your printer model from a list. Click Next after choosing your printer model and the driver will install.
http://www.ups.com/content/us/en/resources/ship/create/labels/technical.html
Nov 24, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Wordperfect crashed in the middle of working on a document
Find the WP directory and locate the backup file. Copy it to somewhere else.
The directory will be something like WordPerfect\12\Backup with various other directories on the front of that such as c:\program files\ etc.
Open the copy and see how much of the original is present.
Michael
Reinstall WP
Open
Mar 17, 2009 | Corel WordPerfect Office 12 Standard...
585avr isn't working w/vista OS,
While the 585AVR is not designed for Vista, it should work. You will need to use the CyberPower serial to USB cable, and the most recent version of PowerPanel Personal Edition software. You can download the latest software @ http://www.cyberpowersystems.com/software/PPPE_V_1.2.2_Setup.exe
If you have any questions, or need the CyberPower serial to USB cable, please contact CyberPower Systems Technical Support at 877-297-6937, M-F, 8-5 Central.
Oct 31, 2008 | CyberPower Office Power 585AVR...
Installation path change
Change The Default Location For Installing Apps -----------------------------------------------
As the size of hard drives increase, more people are using partitions to separate and store groups of files.
Go to :-
- Start > Run
- Type “regedit” (without “” NOOBS!)
- Go to this directory… HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
- Look for the value named ProgramFilesDir. by default,this value will be C:\Program Files. Edit the value to any valid drive or folder and XP will use that new location as the default installation directory for new programs.
Oct 19, 2008 | Computers & Internet
The contents of this file cannot be unpacked.The executable you are attempting to run has been corrupted.
When I try to install the software, I get an error message. The installation just quits. trnsp.gif Answer An installation error is defined as any issue or error that prevents the Setup program from fully completing the task. Installation errors can manifest themselves in several different ways. One common installation problem is the Setup program is interrupted with a message indicating some type of problem. Another type of installation error is when the Setup program simply disappears or doesn't complete for any reason. When Setup is interrupted with an error
Many installation issues will be accompanied with an error code and then an error message that identifies the problem. Because the camera software uses the Windows Installer, the exact definition of the problem can be obtained by looking up the error code on Microsoft's website. Two common errors are Error 1904 and Error 2711.
When Setup simply disappears or doesn't complete
Note: When installing software, administrative rights are needed to install all the files for camera software. If you are logged in as another user without administrative rights, the software may not install/function correctly.
First try booting clean. If you are using Windows XP, Windows Me, or Windows 98, click here for instructions on booting clean. If you are using Windows 2000, click here for instructions on booting clean. Once you have booted clean, then try to install the camera software.
Since booting Windows clean may disable CD-ROM support, we recommend you download the latest camera software for your camera and use the download file to install after you have booted clean.
All other installation issues
If you are unable to find a solution to the installation issue given the above information, please try the following suggestions. After each suggestion, try running the installation program again.
  1. Reinstall the Windows Installer. This Windows Installer engine can be downloaded from http://www.microsoft.com/downloads/release.asp?ReleaseID=17343
  2. Windows 2000 Only. Stop the Windows Installer service and reboot the machine. To do this:
    1. Right-click on My Computer
    2. Choose Manage
    3. Click on the plus (+) sign next to Services and Applications
    4. Click on Services
    5. On the right side on the pane, double-click on Window Installer
    6. Choose STOP
    7. Reboot the computer.
If the service was already stopped, try starting the service, then stopping the service and rebooting.
If following through on the specific instructions above do not resolve the issue, please try the following standard diagnostics:
  1. Try a different installation media. For example, if you are attempting to install the camera software via the CD, download and install the latest web release. If you are trying to install the web release, try the camera software CD. Please note, the latest software can be downloaded here.
  2. Run ScanDisk and Disk Defragmenter. Both of these utilities can be found in the Accessories program group of the Windows Start Menu.
  3. Search for and delete all TMP or CHK files.
    For Windows 98 and Windows Me Users:
    1. Click on "Start", "Find" and choose "Files or Folders".
    2. In the Named field, type *.TMP and click "Find Now"; delete all files found.
    3. Repeat this procedure with *.CHK.
    For Windows 2000 Users:
    1. Click "Start", "Search" and choose "For files or folders".
    2. In the Search field, type *.TMP and click "Search Now"; delete all files found.
    For Windows XP Users:
    1. Click "Start", "Search".
    2. In the "All or part of the file name" field, type *.TMP and click "Search;" delete all files found.
  4. Empty the TEMP directory; this folder may contain files that are interfering with the installation. To do this, use the following steps:
    1. Right-click on My Computer and choose Explore.
    2. Click on the plus (+) sign next to the C drive.
    3. Click on the plus (+) sign next to the Windows directory. (For Windows 2000, it is the WINNT directory.)
    4. Click on the plus (+) sign next to the Temp directory. The right side of Explorer will display the contents. Select all the files listed in the Temp folder and delete them.
  5. Reboot the system and try installing the software again.
Jan 21, 2008 | Logitech QuickCam Express Web Camera
Verify that you have access to that directory
First of all check that you using the administrator account to install and uninstall programs.
you probably changed your permission to Program Files directory.
Nov 08, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
