Question about Parrot Ck3200 Ls - Color Cell Interface Cell Phone Interfaces - Bluetooth Cell Phone Hands - Free Kit Remote Keypad With Color Lcd Display Full Radio Integration
Parrot suddenly gone quiet...
My parrot has worked fine for two years. Today it is connecting ok rings as normal but once answered or when a outgoing call made the voice remains only on the handset not thru the parrot. I have deleted and reinstated bluetooth connections but this has made no difference. Connection is definately there just the voice thru the phone not the parrot. ANy ideas?
thanks
  • 4 Answers
SOURCE: parrot evolution
There is a tiny reset on the back of the parrot. Use a paperclip to depress and reset the device. This should remove any pairings.
Posted on Jun 23, 2008
SOURCE: Parrot to GMC Sierra setup.
here,
When I did this truck I had to go to the amp under the center console. Good luck
#510564: 2007 GMC SIERRA C1500 2DR TRUCK
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery ORANGE (+) RADIO HARNESS
Accesory (CLASS 2 DATA) (+) RADIO HARNESS
THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON AND AMPLIFIER TURN-ON ARE CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
Ground BLACK/WHITE (-) RADIO HARNESS
Illumination GRAY (+) RADIO HARNESS
Dimmer BROWN (+) RADIO HARNESS
Amp Turn On PINK (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (+) LIGHT GREEN
RF Speaker (-) DARK GREEN
LR Speaker (+) BROWN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Amp Location UNDER CENTER CONSOLE
Steering Cntrls OPTIONAL
THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT.
Speed Cntrl OPTIONAL
Radio Security YES
Posted on Feb 18, 2009
SOURCE: can't connect my nokia 6300 to Parrot Bluetooth Car kit V5.1
Try "1234". That's the code on my parrot kit.
Posted on Mar 24, 2009
SOURCE: passcode for hands free parrot bluetooth device
on the device
go to settings - pair with phone... - other phone
and the pin code will be dispayed on the screen
Posted on Apr 08, 2009
For the Parrot Minikit- that attaches to the visor. The default is 1234
Posted on May 28, 2009
Hi Guys had a parrot with LCD display for a few years now when I start the engine it does not boot up, normally if you have the phone with you it will prompt you to connect if you dont have the phone with...
The software has crashed. You can try pulling the fuse for the parrot and it may boot back up but i would do a software update if you have had it a few years. Make sure the kit says 'goodbye' when powering off, if not then it is wired wrong. Parrot web site has a list of certified installers.
Feb 21, 2011 | Parrot Hands-Free Car Kit with LCD Display...
Parrot CK3100 cutting out/Blank
try pushing the wire into the display, this commonly comes loose.
Jan 19, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
The parrot comes up with memory full when I
try holding the 2 bottons in for 1 min to reset the kit, if this doesnt work it will have to be replaced
Jan 12, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
My Nokia will connect with Parrot CK3100. On
you can adjust the ringtone and volume in the sttings menu.
Oct 18, 2009 | Parrot Hands-Free Car Kit with LCD Display...
Pairing a Parrot CK3100 to Iphone 3GS
My iPhone 3G is now connected. Did 3 things:
1. Deleted every existing paired device on the Parrot CK3100.
2. Pressed all 3 buttons at once. Parrot CK3100 screen lit up and buttons lit up after about 5 secs. Turned car engine off. Parrot switched off. Turned car on again.
3. Went to settings, advanced settings, pair device (and also switched on iPhone bluetooth) and tapped Parrot CK3100 on the iPhone screen (which had now appeared) - phone connected.
After about a minute sync iPhone phonebook appeared on Parrot.
Hope this is helpful.
Jun 27, 2009 | Apple Cell Phones
Nokia 5800 wont connect
Have you used the Parrot with another phone? In which case you need to clear it's memory to put it back into pairing mode.
Hold down green and red together until she tells you memory is cleared, then she prompts you to pair your phone.
Jun 17, 2009 | Parrot Par Ck3000 Evolution Ck3000...
ANSWERING CALLS
Check to see that it isn't set to "call forwarding".
Feb 10, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Minikit no sound
I called Parrot today because I have the same issue and they said I need to mail it back to them, they will try to fix it and if they cannot fix it they will mail me a new one.
Aug 22, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Problem connecting Nokia to Parrot CK3100
take the Parrott CK3100 back to the store you bought it from and have them assist you with it.
Feb 28, 2008 | Nokia N95 Cellular Phone
Parrot Ck3200 Ls - Color Cell Interface Cell Phone Interfaces - Bluetooth Cell Phone Hands - Free Kit Remote Keypad With Color Lcd Display Full Radio Integration Logo
106 people viewed this question
Top Parrot Cell Phones Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
