Oki c5600, how can I solve FATAL ERROR 177? - Office Equipment & Supplies
4 Suggested Answers
  • 10 Answers
SOURCE: OKI C5600 printer is printing Blank pages
you looking at 3 posibles one is the scanner may need to be replace or the low voltage power supply or you looking at a posible drum problem
Posted on Jun 30, 2009
SOURCE: does anyone know what is
If you look on top of the fuser roller(upper orange roller), there is a thermistor (orange rectangle plastic that rides on the roller) you will see four wires going into that housing. Two are for the thermistor and the other two is for the fuse that is built into the housing. You would have to use a soldering iron to melt the plastic that the fuse is sitting in. You would have to figure out what to use as a fast blow fuse.
Okidata makes it difficult to take out the thermistor because the nut is locktite on the screw. Try using the soldering iron to melt it. Just make sure you dont damage the thermistor.
Posted on Jul 03, 2009
SOURCE: How do i solve fatal error 980
If you have 980 fatal error and have checked that there is no paper stuck in fuser or you have removed the paper and still have error, then you should contact Oki, there is a fix for this exact problem, if you contact them they will send you a patch which you will need to run on the printer. This will fix your problem
Posted on Mar 02, 2011
How to fix fatal error 177 in oki mc860
177 is a thermistor problem within the fuser. Just replace the fuser to cure the problem. Remember to replace the fuser with the power off.
Feb 08, 2017 | Oki Electric Industry MC860 AllInOne Led...
Getting error 142 fatal error
unplug the unit then clean the printer and all drum units and etc with compressed air. Replace the drums and replug should solve the problem.
Dec 10, 2009 | OKI C5500n Printer
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
How do i put paper in the bypass feed of the OKI C5600 printer? I can't find the bypass tray or how to put thicker paper through the machine.
The bypass feeder or multipurpose tray as OKI call it is situated above the standard or 1st cassete paper tray.
It is usually hidden. Ther is a door door with an handle. Pull the handle to open it and then extend the tray.
For images and instructions on how to feed the paper, check page 13 and following pages of the User Manual you can download from here:
http://www.c5600.co.uk/library/documents/c5600/C56uEN1.pdf
Also, I leave you the link to the support homepage for your copier. On the left side of the page there are several useful inks (to download drivers, software and documents, how-tos, explanation of errors, etc.):
http://www.c5600.co.uk/index.asp
Aug 19, 2009 | Ricoh Aficio 250 Copier
Oki 5800 shows 177 fatal error
A 177 is a fuser code. The fuser is the part that gets hot. Try rebooting the printer. Try taking it out and putting it back in (with the machine off). You might need to replace the fuser unit.
Jun 08, 2009 | OKI C5200n Laser Printer
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Nov 22, 2008 | Ricoh Aficio 250 Copier
OKI C5500 Fatal Error 177
From OKI error log:
Lower heater temp state - Low
backup roller thermistor indicates low temp
seek service if turning off/on printer does not solve problem
Apr 15, 2008 | OKI C5500n Printer
C5200 printer
177 - Replace fuser
Dec 12, 2007 | OKI C5200n Laser Printer
165 people viewed this question
k24674
Marvin
Marvin
