Question about Frigidaire GLGF386DC Stainless Steel Gas Kitchen Range
My professional series oven preheats and then stops heating.
My professional series oven lights up, heats to the selected temperature, but then the temperature drops or it stops heating completely.
  • 6,784 Answers
HI, there may be some issues within the dual safety gas valves. they mat be malfunctioning. these valves control the gas flow and if the shut prematurely, it will disrupt the heating process. You could also have a sensor issue as well but, im sensing that this abnormal shutdown is being cuased by a fualty Dual oven safety valve assembly.
Please rate and god bless:)
Posted on Apr 15, 2009
  • Michael Masters
    Michael Masters Apr 15, 2009
    Here is a picture of this valve assembly below.
I hit the bake button on my oven and after 10 secs it says preheat and thats all that happens nothing else no heat at all
Your oven will continue to indicate that it is preheat mode until the thermostat senses the proper set temperature. If you are getting no heat then you will need to address that issue. This could be many things but the most notorious would be the heating element. Could be the control panel as well. Some ovens have a knob for preheat, bake and clean with a separate knob to adjust the temperature. Make sure both are set properly.
Regards, Tony
Apr 07, 2011 | Kenmore Ovens
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
How do I know when the oven is preheated?
Depending upon your make and model of oven when you first turn the oven on to heat a light may come on that says 'preheat'. When the oven is heated to the temperature that you set it for the light will go off and some models sound a tone or beep as well. If your model does not show you in any way when it is preheated ( such may be the case in an older oven)you can purchase an oven thermometer for that purpose. If you will send the information regarding the make and model of your oven, I can give you a more specific answer.
Thank you for using FixYa. Please rate this answer..
Dec 24, 2010 | Ovens
Preheat the oven and it will not heat up to temperature nor will preheat light go off.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 13, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
I have a Thermador wall oven (POMW301/02) when bake is selected, heats up very slowly until the pre-heat light goes off. And then the oven light stays on but it doesn't hold the set temperature. While it...
Due to the nature of the self-cleaning cycle heating the oven to above normal temperatures what likely happened is that the temperature sensor went bad. The sensor is a small rod about 6 inches long and 1/4 inches wide that sits in the back of the oven. You can remove it from the back side of the oven which will need to be pulled from the wall. Replacing it should solve the problem.
Let me know how this works out for you.
Benjamin
Dec 28, 2009 | Ovens
Caloric Heritage Series oven has no preheat achieved indicator
I have the same range. There is an indicator light next to the temperature setting for the oven. when it comes on, it's pre-heated.
Apr 05, 2009 | Heritage Kitchen Ranges
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Viking oven broil keeps on
it is designed to preheat this way. after the unit cycles the red indicator light off the first time than both elements turn off. when it calls for heat again only the bake elements comes on. makes the preheating work faster.
May 05, 2008 | Viking 30" Professional Select Built-in...
Oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Mar 26, 2008 | Kitchen Ranges
Frigidaire GLGF386DC Stainless Steel Gas Kitchen Range Logo
363 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
