Question about Whirlpool GU2400XTP Built-in Dishwasher
Normal Light Blinking - Dishwasher not working
We have a Whirlpool GU2400XTPB1 diswasher that apppears to have stopped mid-cycle and will not work. The Normal light is blinking rapidly and all other lights are off. I have tried to push the Cancel/Drain button, and the Normal light stays lit and there is a line lit up in the upper corner of the Time Remaining area but nothing happens. If you push the Start/Resume button, nothing happens. I reset the circuit breaker, but that didn't work either. I do have the Tech Sheet, but it doesn't make sense to me. Any suggestions?
  • 2 more comments
  • vangoff Apr 04, 2009
    Same problem. None of the suggested fixes work.
  • Anonymous Mar 13, 2014
    Hello - my Whirlpool 980 series dishwasher suddenly stopped working. It won't drain or fill or wash. The buttons light up when pushed, but nothing happens - except that the heating coil heats up. Any suggestions?
  • Anonymous Mar 16, 2014
    The LED labeled '3' is lighted and none of the buttons will start the machine. I have tried the code to run the drain pump (5xnormal button followed by start, 3 flashes, then press 'normal') but nothing happens. Any ideas?
  • Anonymous Mar 25, 2014
    Start/resume blinks when I hit the start button. Nothing happens no noise, just blinks. Any help will be great.
I also have a whirlpool gu3200xtvb3 normal light is flashing but it is unresponsive I have not got any answers that worked the pushing normal and heated dry sequence does nothing.
Posted on Aug 17, 2012
  • llhansen63
    llhansen63 Sep 19, 2012
    I have the same problem. I have put on 3 new control panels. Still nothing works right. Lights flashing all over the place. HELP!!
I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
Posted on Nov 24, 2007
Whirlpool quiet wash plus dishwasher
Sounds like the timer module is going bad. Might be getting moisture on contacts. That would explain why it works one time and not the next.Just trying to help!
Aug 14, 2013 | Dishwashers
I have a Whirlpool Dishwasher Model #GU240CXTPB1. The normal light won't stop blinking. Tried turning the breaker to reset, but still blinks. No other button works.
Whirlpool dishwasher reset sequence is usually to hit the heat dry then normal then heat dry then normal buttons within 5 seconds and it usually resets.
Mar 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
The clean light is blinking diswasher won't start
Push these buttons in this order High temp wash > Heated dry>High temp wash >Heated dry all the lights will come on and this will reset the board and run it through a short test cycle but more than likely it will come up again,It's a failure in the heating cycle either the heater itself or the turbidity sensor which sits mounted up into the tub right behind the drain pump...hope this helps
Sep 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gold- quiet partner III
An angel of mercy on another blog posted this solution and it worked for me as well. My Whirlpool Quiet Partner Dishwasher would not work due to the CLEAN light flashing in 7 interval sequences. I followed these steps and my dishwasher is not working perfectly...hope it works for you:
"Well for mine which is a Whirlpool Gold Model # GU2400XTPS3, I found the seq of buttons that I had to push to reset the curcuit board. I think it may of been in this forum somewhere. But I had to push - Sani Rinse, Heated Dry, Sani Rinse, Heated Dry, and then the dishwasher went through it's diagnostic cycle and then after that the light stopped blinking and the dishwasher works great. Supposily, there is a Product Tech Sheet behide the kick panel of every dishwasher, but mine was gone so I had to find the information on the internet. You might want to do a serach for the correct seq of buttons you have to push to reset the curcuit board. If you know for sure that the heating element is bad, you will have to order one. "
Mar 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Blinking light on start button and no action!
Call a technician from the place you purchased it. It should still be under warranty. If not by them, then I would try the manufacturer. Warranty Job
Dec 04, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Its not working at all!
Sounds like the main wash/circulating pump is faulty
Jul 08, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
1,441 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
