Question about Tomtom ONE XL GPS
My tom tom one won't charge because the charging unit on the base of tom tom has lost the part that connects to the charger, do I have to buy a new one?
  • 297 Answers
She charges on USB with a PC. If USB port suplies power, not all do.
Seperate home charger for sale.
Or replace original.
I hope you talk apot that cable to cigarette lighter.
Mind you I have a Go 300
Posted on Apr 17, 2009
Nyko charger won't charge
Had same problem with blinking lights and not charging.
Plug charger base in (blinking lights), remove controllers, and plug USB cable into front charge slot (behind hinged panel). This reset charger base and lights stopped blinking. As FYI - the USB was connected to other device (charging it). Add the controllers and correct charging lights show up - including the controller 1 and 2 symbols. Controllers now charging.
Feb 07, 2012 | Nyko Charge Station 360 For Xbox 360
My tomtom won"t turn on
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
Dec 13, 2010 | Tomtom GO 700 GPS Receiver
My Tom Tom XL 325 wont hold a charge while left off
Hi, leaving the unit in the cradle exposed to the sun during hot days has been known to fry the battery causing loss of battery capacity. perhaps this could be your problem. I replaced the battery in my last GPS 4 times because of this before I analysed the problem. This will most likely be outlined in your user manual too. You might also compare the output capabilities between your blackberry and tomtom charger - it is entirely possible that you are starving the unit of a decent charge if the blackberry charger is not to the same current capacity as the tomtom charger.
Mar 19, 2010 | Tomtom One XL GPS Receiver
My cordless phone says No link to base Move closer to base - I have no dial tone - do i need a new battery?
This is the usual message that the phone gives when the battery has died and it has lost connection with the base unit. The usual fix is to remove and reinstall the battery, then place the unit on the charger for a full charge. This will usually fix the problem that you discribed. If after a full charge, you still get that message, you will most likely need a new battery. Good luck...
Nov 06, 2009 | Panasonic Lands Phones
Tomtom only charges on fast charger base. Why?
if it is not charging in the car then the socket in the car is dead, blown fuse or defective socket..
Aug 09, 2009 | Tomtom GO 920 GPS Receiver
Have TomTom 910 Having Problems Charging it.
The 910 satnav/mounting interface is dreadful- it is the cause of half the problems on this site! You can order the battery on the net. Google VF5 or Samsung ICR18650-24. To replace, strip off rubber strips. You need a mini star screwdriver, carefully pull unit out of cover gently levering at the side. Carefully observe plastic carry through which acts as button on the front and base clip underneath- this must be reinserted correctly. It is a vital part of the structure- observe it carefully! Remove upper small PCB and large PCB after removing 2 electrical connectors. Battery located under PCB. Dispense with rubber mounting. Reassemble carefully battery holder (loosely until you have placed previous plastic carry through). Tighten battery holder to hold plastic strip which must be located over mounting bracket, carefully reinsert both electrical connectors (different sizes), reattach large PCB then small one, then screw back in cover. It is likely you will then be stuck on initial screen with unit not booting correctly. You must then do software resets (opened paperclip inserted into invisible hole next to connecting strip at back). It is likely that you will have to connect to Tom Tom HOME to do this. I failed here as the darn unit will not connect to my computer.
An awful piece of equipment- I have gone Garmin!
Mar 18, 2009 | Tomtom GO 910 GPS Receiver
I bought a TOM TOM 920T new in May 2008. It stopped working yesterday on the road and I got l;ost as a result. Finally, somehow I got home. The power shuts off within few seconds of my turning it on.
Did you try to reset the Tom Tom? Did you try to see if the unit is charging or fully charged (samll green light on the lower righthand corner should illuninate when charging)? I have had problems with the power connection at the base of the unit getting loose. Try taking it into the computer and getting a full charge if it is a charging problem. Not an expert but expereinced the same problem recently.
Feb 15, 2009 | Tomtom GPS
Charger
I had the same exact problem! It should plug in to the back of the unit, but it wouldnt charge there either.
What i had to do was goto Radio Shack and buy a Universal Charger for my cigarette lighter that cost $14.00. It has multiple plugs and 'pins'. Find the right one, and set the volt/amp switch to 4 or 6 amps, whatever it says on the bottom of your TOM TOM. The person at Radio Shack helped me, they should be able to help you too!
Thanks,
Mark
Dec 30, 2008 | Tomtom One XL GPS Receiver
Tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Nov 17, 2008 | Tomtom ONE GPS Receiver
Garmin car charger
There are thee ways to charge the Garmin 750, 1: thru a car cord that plugs into the base that your unit mounts on. 2. Thru an AC charger. 3: thru the USB port on the Garmin unit itself. In your case the car cord plugs into the base that mounts your unit to the window. If that is not working, check that you are getting power from your car receptical. Check by plugging your Phone in or buying an adapter at Radio Shack that checks it. Also check the plug that goes into your car recepticle. Your manual tells how to check the fuse that is located in the end of the plug. If neither of these work your mount connection is bad. Hope this helps
Aug 02, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Tomtom ONE XL GPS Logo
879 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
