Question about Garden
The fitting on the pressure hose is bigger than the fitting on the side of the washer
  • Philip Gaut May 11, 2010
    You've identified the problem, so how can I help???  Or is this just a complaint?  If so, I think you should target the manufacturer.  If you need help on this site, please identify make and model of machine, and state whether the pressure hose is one that you bought with the machine, or a different one.
2 Suggested Answers
kbhooton
SOURCE: How do I fix a busted water pressure hose? Can I cut the hose and replace the fitting at the end that attaches to the machine? Where can I buy another hose?
you can buy a new hose at Currys.
Posted on Jan 14, 2015
Testimonial: "Did not see anything about a pressure at Currys."
Where do youput in freon for a/c
you would need a manifold gauge. red hose to high pressure side (bigger fitting). blue hose to low side (smaller fitting). yellow hose to 134a tank. ideal pressure is 40psi for low side max and 200 psi high side
Jun 25, 2014 | 2003 Mercury Sable
Install high pressure hose. Cannot get shaft of hose fitting to go deep enough into fitting so retaining clip will engage
There are several different configurations for these fittings. If you bought a generic replacement hose, it may have a different fitting than what is on the machine. May have to replace the fitting on the machine, or buy a hose specific to your pressure washer.
Apr 09, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
Power Washer has no pressure, any ideas
1. If you have an inlet chemical injection valve make sure that the hose is intact and that the valve is closed.
2. Purge all air from the line by holding the nozzle actuation lever open until all air has been purged. When you connect the water supply hose turn it on before connecting the high pressure hose and let the unit self purge to the pump outlet high pressure hose fitting. Then connect the high pressure hose.
3. You could have a stuck spring and ball inside the high pressure head of the pump. You can tip the unit on its' side and add a substantial amount of WD-40 to the water supply hose fitting in an attempt to free the springs and balls.
4. Try BRIEFLY running the unit without the hose connected to see if there is high pressure water ejected from the high pressure fitting.
5. Inlet water screen at hose connection is clogged (hose screen and rubber) Check screen for debris.
6. The water strainer is clogged. (Almost looks like an LPG regulator just after but in line of the supply hose connection to the pump)
Order of troubleshooting
1, 2, 5, 6, 4, then 3.
Thanks for using FixYa!
Kelly
Mar 19, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Hi, so long since i used my pressure washer i cant
  1. connect your garden hose to the bigger screw type part
  2. turn on your water and let it flow for 1 min
  3. then kink the hose and attach the hi pressure hose
  4. then put it on
Aug 01, 2009 | Garden
Can of r134a hose won't stay on low pressure port
Low side is the smaller of the two fitting wise, but usually the bigger hose.
Jun 25, 2009 | 1997 Buick LeSabre
Where is the AC Low pressure valve on a 1999 Pontiac Grand Prix?
sometimes its behind the alternator real close to the firewall. Find the bigger of the two hoses and pipes the low side is always bigger. Also the cap is blue and the fitting for the charging can will only fit on the right valve.
Apr 24, 2009 | Pontiac Grand Prix Cars & Trucks
I dont know where to add freeon to my 1999 kia sportage 4x4
Find the A/C compressor. Look a both lines going to it. One line should be bigger than the other. The bigger line is the Low Side (suction port) follow that line it goes to the firewall to the evaporator that is in your dash. The low side pressure port is somewhere in that line between the evaporator and the compressor. That port is where you check low side pressure and add freon. Don't worry if you buy a charging kit from a part store you can't hook it up wrong, the low side port and the high side port are different sizes and the hose won't fit. With the A/C running on high, low side pressure should be about 35psi.
Mar 01, 2009 | 2000 Kia Sportage
Flashing f h code
ck to be sure drain hose is at least 30 ins from floor and not fitting tight in standpipe ..remove top on left side some have a flowmeter ..round object with 2 small hoses try tapping it if works replace it .if still have problem flowmeter may still be bad ..pressure switch on right side toward back
Nov 16, 2008 | Kenmore 46462 Front Load Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
