Question about iRiver iHP-120 MP3 Player
Check hdd connection - iRiver iHP-120 MP3 Player
How to fix mx-c311 error code e7-06?
The Causes
Compressed image data abnormality. HDD connection trouble when HDD is installed.try to check and see wether connectors are connected properly
. Remedy
If the job at an occurrence of an error is a FAX job, check the FAX PWB. Check connection of the MFPC PWB and the HDD. Replace the MFPC PWB.
Jul 16, 2014 | Sharp MX-C311 Primary Transfer Belt Unit
Hdd not detected
IF YOU MEAN IN COMPUTER HAVE YOU INITIALIZED THE HDD.
GO TO ADMINISTRATORS TOOL-COMPUTER MANAGEMENT.
-STORAGE -DISKMANAMENT (LOCAL).
THERE SHOULD YOUR HDD BE INITIALIZE IT.
Oct 04, 2013 | Asrock P4I45GV R5 Motherboard
I have a hp elitebook 2530p laptop problem is the hdd is not detect so i change the hdd connector for example - to + +to - problem create display is gone but laptop is on so what we do plz send the...
Hi Friends,
First of all HDD inducted connection, No any - or + option. simple hdd and cable same option given. If you are - to +, or + to - connection may be you HDD damage. So you check it you HDD wall conduction or not. If wall status then you change HDD cable and port and open bios and see you HDD show or not. change you SMPS power connector used different port connector. Nest problem is Display not then you check SMPS proper power comming, No any beep sound in PC, RAM, etc. Finally Change HDD and then check it.
Thanks..
Aug 30, 2013 | HP EliteBook 2530p Notebook
Computer doesn't recognices HDD how can i reconfigure it
Either your HDD died or the connecting cable came loose. Open the HDD enclosure and check to make sure it's connected properly. Maybe reseat the drive.
Jun 29, 2012 | Toshiba Satellite 2545CDS Notebook
Copier reads e7-03
E7
Content HDD trouble
Detail
HDD connection failure
If the HDD responds an error or does
not respond for 30sec, it is judged as
an error. (Other than the system area)
Data abnormality in the file
management area (when the cluster
chain is broken)
Cause
HDD is not installed properly to the ICU
PWB.
HDD does not operate properly in the
ICU PWB.
ICU PWB trouble
Check and
remedy
Check installation of HDD to the ICU
PWB.
Check connection of the harness of
HDD to the ICU PWB.
Use SIM 62-2, -3 to check read/write of
HDD.
Replace HDD.
Replace ICU PWB.
Aug 05, 2011 | Sharp MX-2300N Color Copier
I have 2 hdd's running on raid 0 and want to run another 160 hdd, and win 7 is not picking up the hdd
is the 160 hdd new? check for physical connections, check your disk management, check there if your hdd is deteced, you might need to initialize and format it first..
Hope it helps!
Feb 17, 2010 | Computers & Internet
My computer has problem HDD can not detect.mother board ASUS P4VP-MX, how to solve the problem, thx
Please remove the IDE cable from Hard drive and from HDD controller ,re-connect the cable with HDD and HDD controller.If still not resolved then connect with another IDE cable and check it .if not resolved then check with another HDD controller and check in the BIOS its detecting or not .If not then issue that Hard drive is faulty might be logic card .its better call vendor for repair it.
Nov 19, 2009 | Computers & Internet
Cant detect my western digital hard drive help! philippnes!
Shut down the computer.Disconnect the ide cable from hdd .Just connect using primary hdd and boot the computer. Shut down the computer. Connect the secondary hdd both IDE and power cable. Restart the system and go to bios . Check if the both hdd are detected in bios. If detected boot to desktop. If not detected reset bios settings to default.Restart computer and check. IF still not detected shutdown computer.Disconnected secondary hdd and primary hdd,connected secondary hdd to primary ide connecter and check in bios. If still not detected try connecting secondard hdd on different computer and check.
Aug 17, 2009 | Computers & Internet
I have 20 GB HDD which can'not detected is any software detect it
try to check it on CMOS setup, and see if ur HDD is detected there, then also check the jumper settings of your HDD, is it connected as master drive, or slave, then check other devices jumper settings for CDROM or other HDD connected to your PC. (do this for initial troubleshooting)
Dec 14, 2008 | Symantec Computers & Internet
In Ricoh aficio 401
The SC360 is Hard disk drive error 1. This means that the machine does not detect the connection signal from the HDD.
CHECK THESE; poor connection between the HDD and the HDD controller,
the AC power connector to the HDD is disconnected,
HDD defective,
HDD controller board defective,
BICU defective.
Make sure all connections are tight and secure, make sure power is connected securely, make sure HDD ( hard drive) is not bad if so replace. If the above are fine, replace the controller board and if the problem is still there, replace the BICU board.
Nov 15, 2008 | Ricoh 6513 Copier
Open Questions:
iRiver iHP-120 MP3 Player Logo
43 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
