Question about Sony KDS-R60XBR1 60" Projection HDTV
Screen has yellow in background
About 3 weeks ago a yellow rainbow appeared on the screen in the background. Its most noticable when the picture on the TV is light , daylight vs night. It had now spread so the it covers more than half of the screen. It is there on all channels and on CDs. Called Sony but TV one month out of warranty. It seems to me such an expensive TV should not be having this problem.
  • staszek Nov 04, 2007
    I have yellow bar on the left side of the screen What to do with it
  • dgrace Dec 15, 2007
    i have very light, almost unnoticable yellow in right hand corner some one said because i had a speaker close to that corner. can i fix it or does it need repair.
  • 6 Answers
Um... this sounds like it could be the optical block inside the unit. sony actually has a class action law suit against them for this problem u can view here: http://esupport.sony.com/sxrdsettlement ...
this same thing happend to our TV and we have an extended warranty so the guy came out to repair at no cost to us. depending on the purchase date of your tv, you may be covered in the suit as well, and you can be reimbursed for any expense to repair the issue... you've likely already solved this problem, but for anyone else, i hope this is helpful.
Posted on Dec 26, 2007
    Scholar:
  • 136 Answers
Two possibilitys here: Either the screen drivers are going bad or there is a problem with the decoder board. Testing the decoder board is only replacing it. You can take a towel and gently apply pressure around the edges of the screen and if it dissappears for even a split second, theres something wrong with the screen itself. Let us know :-)
Posted on Sep 14, 2007
Blue background with "rainbow" like
Check the info from this link to see it it applies to the rainbow lines from your TV.
Jan 04, 2011 | Sony KP-65WS500 65" Rear Projection...
Intermittent 3 inch green vertical line-5 inches from right side
it you have a repair skills you need to open the TV and make sure all the ribon connectors around the circuit boards are proper connected
and if all seems to be ok, the DG board will need to be replaced.
If you dont have any repair skills I would recommend you to take you TV to a repair shop since this is complex repair
Jun 16, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Video distortion
You need to take your tv in and have the picture deflector re-aligned.  This doesn't cost much, My dad had to do that to his a few months ago and it cost 30 bucks.
Mar 21, 2009 | Mitsubishi VS-60705 60" Rear Projection...
Red spot on LCD
1) That red spot means that a pixel is stuck, actually it's very common on LCDs.
2 and 3) It usually occurs for a manufacturing issue.
4) The most of the time it doesn't mean that the whole screen is going to fail, but in my case I would take advantage of the warranty if the laptop is brand new and the warranty is still there.
Good Luck!!!
Feb 24, 2009 | Computers & Internet
Appearing rainbow colour for sometime and getting off.
There are few cold (dry) solder joints in convergence board of your tv Sony KP-46WT500
Please inspect convergence board and resold dry solder joints.
Oct 18, 2008 | Sony KP-46WT500 46" Rear Projection...
Rainbow
Rainbow effect has more to do with color wheel style and speed.
Jan 31, 2008 | LG RU-44SZ51D 44" Rear Projection...
Pictures appearing black- olympus FE 170
You checked the obvious, lens cover? (sorry had to ask) any grinding noises when you take a picture or focus\zoom?
Aug 26, 2007 | Olympus FE-170 Digital Camera
Blue Vertical Line
It is sounding like when the laptop is turned on and heats up a bit, the line appears? Sounds like one of the panels is going bad or atleast has developed a problem. below are some tricks you can try to lessen the annoyance of the line. Dual-Scan STN displays are composed of 2 panels behind a single protective panel or screen. Because you are looking through the protective screen the display appears to be one large panel even though it is not. There is a physical separation line (gap) at the point where the two panels meet. When the computer is on and being viewed it is not unusual to see the visible separation line with the Dual-Scan STN displays. The line, actually the fine gap between the display panels, appears because the color and light pixels cannot run along the very outside edges of the panels. This line (gap) between the panels can be seen as a fine gray line and is most noticeable when viewing on a screen with a white or light background. Note the line may not be as noticeable when the screen is displaying certain colors or darker backgrounds. SUGGESTIONS: It is not possible to completely eliminate the line but there are some things you can try to reduce it's visibility. 1) Lower the display brightness/contrast. The brighter the backlight the more noticeable the line. 2) Use Wallpapers and Screen savers that use darker colors. 3) In the Control Panel/Display applet under appearance try different combinations of color schemes for your Window and Background choice Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Sony KDS-R60XBR1 60" Projection HDTV Logo
73 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
