Acer Veriton M410-UD4000C Athlon 64 X2 4000+ 2GHz/1MBL2/1GB/80GB/DVD+/-RW/GigNIC/VB PC Desktop Logo
Victor Boss Posted on Sep 12, 2013
Acer m410 no bios,no sart,power len on,blank screen
jean clarel
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Oct 15, 2013
jean clarel
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
343
Points
12
Motherboard faulty try to change it
2answers
Blackscreen on start up
Welcome to fixya,
Acer Blank screen at startup My Acer Aspire One notebook goes to a blank screen at startup.
BIOS Recovery Systemkat107x130.jpg As awful as it sounds, this is a fairly common problem with Acer Aspire notebooks and it sounds like you have an issue with the BIOS - as long as you can see the power button and hear the fans running to indicate that it is not a power issue. Luckily, these notebooks come with a built-in BIOS recovery system that should get you up and running without damaging or losing any of your files. Know that doing this may void your warranty, so if you have a warranty, you should talk to Acer directly. Follow these steps EXACTLY, and it should work for you:
  1. Format a USB memory stick to FAT. Make sure it is bootable.
  2. Download the latest BIOS from the Acer website. Follow these links for BIOS for Aspire One 150 or this link for BIOS for Aspire One 110
  3. Put the FLASHIT.EXE and the BIOS file in the root directory of the memory stick.
  4. Rename the BIOS file: ZG5IA32.FD. It is important that you get the file name exactly right.
  5. Remove the drive.
  6. Turn the Acer off, but make sure you have a working battery and AC power connected.
  7. Insert the USB memory stick into a USB port.
  8. Press Fn+Esc and press the Power button at the same time. After a few seconds, release Fn+Esc.
  9. The power button should be blinking. Press it once.
  10. At this point, the BIOS will flash - don't press anything or interrupt this process. If you've done it right, the power button will stop flashing and the notebook will reboot. When it is all done, everything should be set to reboot.
Because you have an Acer Aspire One and you are getting the blank boot screen, I'm betting that this will solve your problem. If you are still having problems after following these directions exactly, then let us know and we can try to troubleshoot hardware or screen issues that may be the culprit.
Hope this helps.
Describe your acer veriton m410 problem Problem: Power supply works but no video or keyboard or mouse. USB mouse was acting strangely before the end
Mobo may be fried. Best suggestion, take it to your local computer repair shop and have the CPU, NPU, Memory, etc. tested.
Acer aspire 4315 Blank Screen!!!!!!!!
You need to Revive the bios back.
Search for Acer bios revive in google
3helpful
2answers
Acer 4810t ...does not load bios...and blank display
my acer 4810t does not load xp. it shows bluescreen error. than says use chkdskoption what can i do??
2helpful
2answers
Aspire one notebook's screen was blank
Seems that it lost BIOS. There is a way to recover it - go to macles.blogspot.com/2008/08/acer-aspire-one-bios-recovery.html
1helpful
Location of BIOS lockout Jumper on Acer F690CVM
The BIOS configuration jumper in an intel motherboard is usually in between the system battery and the motherboard's front panel internal headers (right to the Serial ATA ports)
I was trying to go through recovery thinking I could get more speed on laptop and I messed comp. up. Only get a blank black screen. tried powering down, rebooting, still can't get on. Help!! i was trying...
Flashing the Bios is a LAST DITCH effort to resolve Hardware issues. You should NEVER flash the bios unless you are absolutely certain it's the correct bios for your computer, also NEVER flash bios from within windows..
There may however be a solution for you, Acer laptop computers with the Pheonix BIOS sometimes has a " flashback" feature, allowing you to revert to your original Bios..
You will need to contact Acer to get a Crisis Bios recovery disk from them. Or ask for further information on how exactly to recover from a bad bios flash.
2helpful
2answers
Acer 8100 Travelmate - blank screen
Acer Ferrari 4000 "power on" blank screen, fan is running but no beeps, no activity in/from the HD. No reaction on a F8 start up (no Bios set up). It charges the battery OK.
KR Steen Larsen
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
