Question about Bose Companion 3 Computer Speakers
Dim Light on Control Pod...very low volume output
I've had the series 1 companion 3 for almost three years when one day I noticed the sound just stopped playing. Upon examination, it didn't stop, but played very quietly from the satellites. Also the indicator light on the control pod went to about 1/4 brightness (whether green/on or orange/muted). The volume works but goes from very faint on the low end to faint and distorted when turned all the way up. I tested it from multiple sources (computer, stereo, ipod, etc) and I get the same thing each time. I took it to a bose-authorized repair shop and was told it was most likely a faulty control pod. So I ordered a new one from bose ($35 w/ shipping) and there was no difference with the new control pod. Any thoughts?... I'm thinking it's a power issue with the subwoofer box, perhaps a bad fuse...but didn't want to open up the box if I didn't have to. Thanks.
  • 10 more comments
  • Duffy_1 Sep 15, 2007
    On the companion 3 everything runs through the subwoofer box (power, audio line in, satellite speakers, and the control pod). So its not really possible to disconnect the sub.
  • johntolfa May 17, 2008
    Same problem. Indicator light is dim/ green and volume is low and cannot be changed. touch sensativity to turn on and off does not respond.
  • tentpop Jun 18, 2008
    My Companion 3 decided to not work today. The LED on the control pod is very very dim and the sound is barely audible. I tried it on my ipod and the same thing. Does anyone know what the solution is?
  • donnaym Sep 13, 2008
    I have the exact same problem. Since the unit is out of warranty, I would like to know how to disassemble it.
  • scotth710 Sep 19, 2008
    Same problem.  How can I fix it?
  • Anonymous Oct 29, 2008
    same problem. sucks.
  • ken_repa Nov 10, 2008
    exactly the same like i do
  • Zeekr Nov 14, 2008
    Having same issue and there doesn't appear to be a solution anywhere. Very disappointed as I am a Bose dealer!
  • pukstershopp Nov 15, 2008
    Same problem here. I contacted Bose a year ago and they suggested a new control pod, so I bought it. Now I have 2 control pods for a broken unit. Bose sucks! And of course, it was a month out of warranty when it happened. Sounds like planned obsolescence.
  • rcandle Mar 18, 2009
    I have the same problem: dim indicator light, no response to touch, low
    volume output, no volume control. I just ordered a new control pod,
    but others are saying this did not work either. Everyone is having
    this problem. These units must be defective. Can we sue Bose over a
    mass defective product?
  • Anonymous Mar 25, 2009
    Same exact problem
  • Anonymous Apr 21, 2009
    Yep just happened to me 2 days ago.. Verified all connection 5 x and everything is tight. Moved entire system to another PC and got same results. I can hear the sub turn on/off, but other than that ...silence...VERY dissappointing..
I just fixed this exact problem. There is only 1-2 volts feeding the preamp IC's pin 4 JRC 2059. Positive side of C313 should be 12v(B+ to IC's) found shorted transistor just above C313. Collector goes to V+ 15v from power supply, Emitter feeds the preamp IC's. I used a 2sc3904 (NTE123Ap) unit back up and running
Posted on Jul 23, 2011
  • 1 more comment
  • drl2003 Sep 17, 2011
    Could you give more details..... a fix-it step-by-step for that would help get us up and running. Thanks.
  • dragon_67 Dec 04, 2011
    Just replace the transistor just above the capacitor marked c313 on the main PC board. Use NTE123ap if you can't find the exact one.
  • davandy3
    davandy3 Jun 25, 2012
    I have the same problem. Do you have a diagram showing where is c313 located on the main board?
To take apart the subwoofer for Bose Companion 3, peel off the label on the back panel to reveal 4 more screws that need to be removed. Then you can pull out the circuit boards
Posted on Apr 17, 2009
Back in June this problem happened. I did open up the unit to see if I could pinpoint the issue. That didn't work. I called Bose for help. What I was told but haven't followed through on it yet was this:
Bose said that I could send it to their repair facility and have it fixed for a flat $75 fee. That sounds reasonable since the unit is a couple of hundred dollars. If someone does try that before me, let us know what the outcome is.
Posted on Nov 21, 2008
I took mine apart today to check for obvious issues that could be causing the dim light and low volume... loose connections, exposed wire, or blown fuse. I disconnected the speaker, the amp, and all wiring inside and then reconnected. The fuse was not blown, although it is not one that could be easily replaced if it had. The wiring was not loose, nor did there appear to be any visible short. I put back together and tried to turn it on again... same effect. Looks like this will be my first and last Bose purchase.
Posted on Nov 16, 2008
I can not help you with your problem, but I can help you get rid of your extra control pod if you wish. My cat ate the wire on mine and now I have no sound at all (actually, I find your story quite annoying, I hope I won't have the same problem in a few months...). You can contact me at normandjf@hotmail.com and suggest a price for it.
And good luck with your problem!
Jean-François
Posted on Jan 16, 2009
Hi, I couldn't find where the C313 is. Can anybody help me please? thank so much
Posted on Aug 21, 2012
My unit recently developed the same issue. I went ahead and ordered a new control pod and that didn't work. I tried to disassemble the unit in order to determine if there was any issues, but like other users, could not get the back off. Turns out that wouldn't have solved the problem either. I'm very disappointed. Loved the quality of the speakers and hate that they gave out within 5 years. Boo!
Posted on Feb 12, 2010
Can you give more insight on how to dismantel a bose subwoofer. does enyone know how to open the sub? what to fix? how to fix it?
is there pieces nesesary to bye?
Posted on Dec 02, 2008
    Scholar:
  • 136 Answers
My thoughts on this issue is that the amp for the sub is possibly going to protect mode or is entirely shorted causing the load on the rest of the unit. If possible unplug the sub from the rest of the unit and see if it lights up like normal.
Posted on Sep 14, 2007
  • Beau  Delony
    Beau Delony Sep 15, 2007
    The two reasons then is either a bad output for the amp or something in the powersupply. These units are mostly sealed with goop of some kind so there really hard to repair but its possible, i would bank on getting a new system.
Where i can buy the volume control of the companion 5
  1. How To: Fix your Bose Companion 3 [Warning: I'm very ...
    ? 3:18
    www.youtube.com/watch?v=gXRJ5Zgq84UNov 15, 2014 - Uploaded by Guizmaille (You can tell it's the control pod and not the sound system itself.... I tried different combination) until I have a decent sound, with both speakers and subwoofer working. ... I think that you can manage to keep the volume control.
Jul 21, 2015 | Bose Audio Players & Recorders
Bose Companion 3 Series 2 Multimedia doesn't work.
Maybe a tranformer burnout, this is the most common cause, refer to a Bose service center
Jun 15, 2014 | Bose Companion 3 Series II Multimedia...
I've had the series 1 companion 3 for almost 4
Hi, This could just be a sign that your Speaker system is wearing out , and done its due...Also have you had any Power Failures or surge's Lately , if so then it could of damaged the Speakers aswell..
Hope you come right bud
Happy new year
Dec 28, 2009 | Bose Companion 3 Computer Speakers
"This device has no output controls" Bose Companion 5 problem!
Metal detectors/ Xray devices have been known to destroy magnet based electronics (speakers). This could be your problem.
Sep 22, 2009 | Bose Companion 3 Computer Speakers
Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Aug 12, 2009 | Bose Companion 3 Computer Speakers
Control Pod for Bose Companion 5 speaker system
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
Jan 29, 2009 | Bose Companion 3 Computer Speakers
Control pod on bose companion 3
try to check the circuit board with an expert
Nov 16, 2008 | Bose Companion 3 Computer Speakers
Bose companion 5 problems
Have had Bose companion 5s for about three years. The external volume deveice in not active. If I unplug it, the sound goes dead. The indicator light is stuck on green and is very dim.. The touch feature does not respond nor does the volume. Sound is set very low an barely audible. Can I get replacement external volume control or is the problem inside the base unit itself? Any help out there with a similar problem.
Thanks JT
Apr 10, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 3 Computer Speakers Logo
3,319 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
