SOURCE: Ryobi petrol 30cc Trimmer plt 3043 ye
Hi! With the red know in one hand, push the spool down with th other to the female threaded shaft comes to the top. Then, hold the red know in the other hand with your index finger on the bolt in the middle, holding it down. Now start threading it onto the female shaft COUNTERCLOCKWISE! Once you get it, it get's easier. Good Luck!~Frank~
SOURCE: cannot start ryobi 3043 yw grass edger
Check the spark plug and sheck the gap on it then check the wire
SOURCE: Ryobi RLT30CES
I also tried this.
Hope this helps
please rate my comments - Thanks
Aky1967
SOURCE: My Ryobi PLT 2543 strimmer will run, but cuts out
I had this problem twice in the past. I solved it the first time by replacingthe plug and setting the plug gap with a feeler guage. The next time it was a decoke of the cylinder (squirting through the plug hole) replacing the plug and leaving it overnight and then cleaning the air filter. It runs like a dream and has worked in Australia, Europe and the UK with no further problems. Also the fule mix has to be just right, I actually use 22:1 instead of 25:1 and do not use any petrol / gas with additives in (like Shell).
SOURCE: Manual - Ryobi RLT30CES strimmer
Try this one:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Cheers
Nigel
Testimonial: "Thanks. Got it."
Thankyou very much it was really helpfull
