HP iPAQ hw6515 Pocket PC Logo
Posted on Apr 15, 2009
Phone switches off when shaken
My HP iPAQ hw6515e has a serious problem... it switches off for minute jerks and movements.. i don't know if the problem is with the battery or with the circuit.... some one please tell me how to get it fixed and what might b the problem...
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
107
Points
Its probably problem with switch on the right of the battery. This switch turns off device when back flap is removed.
I have downloaded aviation software (APIC) to my hp iapq rx5910. The software is in the memory, but I cannot get it to work on the ipaq. Sometime, depending on what I am looking at, I get a message telling...
click on computer and see in the list for the c drive what is there
if you see aviation set up .exe
click on that and a tag that says run , click on run
It it is not there, click on the start icon (bottom lh task bar) and in the search bar under the programs section, type in --aviation
if it is on the computer it be revealed in the drive and file /folder where it is
click on it and click on open or run
How to unlock hp ipaq hw6920?
The HP IPAQ HW6920 locked in which Country's Network ?
You can Unlock it using the Unlock code from the website
Superunlockcodes there you can get the Unlock code at low cost and unlock it,check code for your network lock,Country!!!!
HP IPAQ HW6920 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your HP IPAQ HW6920 mobile phones. If you enter over a certain amount of wrong unlock codes on your HP IPAQ HW6920 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON the HP IPAQ HW6920 with a sim card that is Not accepted.
2 - The HP IPAQ HW6920 will prompt you for an unlock code.
3 - Enter the unlock code, which you can buy from our website.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your HP IPAQ HW6920 is locked to.
Each HP IPAQ HW6920 mobile phone has an unique unlock code. You can buy the unique unlock code for your HP IPAQ HW6920 mobile phone using the form above.
Internet access problem: I have a wireless router. The IPAQ internet works fine when attached to my pc. When I remove the IPAQ from the cradle, the internet no longer responds. But, the green light and...
ask on the HP forum yet, (we are not HP here)
sounds to me (seems) like weak battery
or it programmed to not use WIFI when running on wifi. on bat.
as wifi can suck such at tiny battery dry in minutes.
why not get and old CELL phone and use it and dump this old relic.
https://h30434.www3.hp.com/
1helpful
Im download app into my hp ipaq,then it hang/jam...it not running like usual..
For hanging/Jam problem, few factors can be involved, First of all you have to check, how much space is being left in phone memory after installing particular applications, To check the settings, Go to settings, Memory,
Solutions:
1. Soft Reset,
Try resetting the device while hold down the End Key for few seconds, when the phone is switched off take off battery for few minutes, then try putting the battery again, It will clear the memory used by the softwares,
CAUTION: Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.
2. Hard Reset
Hard reset will restore your Ipaq to factory default settings, Perform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.
settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so
    3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE: The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center). bilalseham_6.jpg
if you require more assistance feel free to reply to this post
Thanks for using FixYa
Regards-BA
I have a HP Ipaq H6340. I just got it from a
seem like all we get here are dead Ipaq.
why are you messing with this old device?
try a new battery, oops that costs money.
as does repairs on a device that has zero value.
why not mess with and old android phone, that has value.
ask here, be like only one playing Ipaq now.
Wallpaper problems
First of all, you need to reset your device, and replace the configurations to a factory settings, this make the things easier.
2nd: to set a picture to wallpaper the picture need to respect the characteristics of the display, and the image need to math the display size. in your case 240 x 240 and must be in JPG format.
Try to use this settings and post me a reply.
Good luck
Touble shoot
Use the handsfree earpiece and see if you can hear/talk via the ear piece. If you can hear then its probably a hardware problem with your phone's build in microphone. Otherwise try a hardware reset.
Problem
Hi, I have same problem. After upgrade bios to version 1.10 my ipaq h1940 don`t start windows. When switch ON appears HP logo, time line go to end, and ipaq stay block. No possible switch OFF and no starting windows.
6helpful
4answers
Hard Reset HP 6515
Hold down the POWER button and press the reset hole for approx 5 seconds, then remove stylus from reset hole first, follow by release of POWER button.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
