Question about Hotpoint RGB745 Gas Kitchen Range
F2 IS FLASHING ON STOVE AND BEEPER WILL NOT STOP
F2 light is flashing on stove and beeper will not stop--please help--gas range
    President:
  • 373 Answers
F2
During
BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature. F2
During
CLEAN Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Posted on Apr 15, 2009
Whirlpool WFG231LVS oven is not working but stove top works fine
Does the main controller display anything? Is clock working?
Is it flashing and error code? F1, F2, F3 etc?
Apr 08, 2013 | Whirlpool WFG231LVS Stainless Steel Gas...
Nat.gas stove model 362 75491991 when the oven is on and up to temp i get an F2 code and the beeper will not stop.
F2 Oven Temp Exceeds 590 with unlocked door
High resistance in Sensor, likely a bad sensor
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 19, 2010 | Kitchen Ranges
Ge oven codes
F2 means your oven temp got too high. At least, that's what the control boards thinks. More than likely you have a bad oven sensor or bad wire to it or a bad connection somewhere between the board and sensor.
Dec 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Range flashing code f2eo
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open
Dec 13, 2008 | Kitchen Ranges
Hot point beeper wont stop
This is a code for an over temp condition.
If the oven is cool then there is a problem in the sensor circuit, usually a failed temp sensor.
Post back if you have any questions.
Nov 18, 2007 | Hotpoint SY21 Style Line Gas Single Oven
F2 CODE BROILER ELEMENET WILL NOT TURN OFF
Either the relay on the control board is stuck and allowing power to the element or the element is shorted to ground.
Nov 10, 2007 | GE Spectra JBP78 Electric Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
364 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
