Question about Cyberhome CH-DVD 300 DVD Player
Not playing movies
For some reason, i think the lens in the dvd player is stuck. I dont know why, becuase one min, i was watching a movie, then i put on another but it wasnt working, i tried the next and it still wasnt working. I tried to put on the first that i knew worked, but it no longer did. i noticed that the lens wasn't in the right spot, (nest to the spinner) and for some reason it wasn't moving, which is probably why ithe movies dont work, everytime i put in the movie it make a weird clicking sound. how can i fix that?
  • 1 more comment
  • Tasia Sep 15, 2007
    I tried to move it but it wont move, it't go back and forth, but not to where its supossed to go. And i cant find anything stuck in it.
    i think i gotta get it check out, some white piece came out of it and i dont think that was supposed to happen, and it still foesnt work
    a little white plastic piece
    Scholar:
  • 136 Answers
The clicking sound is the lens assy trying to move on the traverse mechanisim and the release spring is ticking. You might want to crack her open and look for any foreign objects in the laser area. You can also try to move the lens assy by hang gently sometimes they get stuck for no reason. Let us know :-)
Posted on Sep 14, 2007
  • Anonymous Sep 15, 2007
    try to move the WHOLE assembly not just the lense.
    >_< thats not good!!! whats the piece look like?
SOURCE:
Lost remote control of my lg dp122 and now i dont know if i can play movies
get a logitect universal remote and set it up to the dvd player.
I know what you are asking and I don't think you will be able to move or select sub menus on movies without a remote.
or buy another remote
http://www.ebay.com.au/itm/like/261378869015?hlpht=true&ops=true&viphx=1&lpid=94
Jan 26, 2014 | LG DP122 DVD Player, Multi Format...
2 symptoms; don't know if they're related or not. For some time now, when trying to watch a movie on my small screen Coby Portable DVD player, it will play just fine for about half the movie, then...
I'm sorry that the DVD player is not playing discs are expected. Based on the information you have provided, it appears that the Lens head of the DVD player is dirty. I suggest that you use a lens cleaning disc to clean the lens head and it should resolve the issue.
Thanks for understanding.
Please let me know if the issue persists.
Nov 14, 2011 | Coby Televison & Video
Wont lode movies
Please check weather the DVD which your inserted i supported by the player.?
If someother movies plays then the problem is with the DVD which your inserted.The DVD might have not burnt in correct formatt.
Thanx
Jul 23, 2010 | Durabrand PDV-705 Portable DVD Player
Older dvd player. put in movie and it sounds like
Hi, that is sounds like a dirty laser lens , try cleaned whit a q-tips whit alcool dont put to much pressure on the lens and try it to play a disk , if doesn't work and still searching the toc on the disk that means your laser pick up is out, you can see if the tirror belt is not skipping/ if not your dvd is out i mean the laser
hope that help,
have a nice day
Mar 26, 2010 | Televison & Video
Player stops during movie or will not start playing movie
hello,
the reason the dvd stops a movie while watching or doesn't play at all is that the lens is already weak.
the best advice is to replace the lens.
you can take it to an expert for repairs or fix it yourself.
to fix it yourself, you will have to get a compatible replacement lens, then try to unscrew the dvd player, carefully disconnect the components to locate the lens, try not to damage any part of it while doing this, the remove the old lens and carefully fix the new one.
couple it back together then try a cd on it. if you cant do it yourself, then take it to an expert.
goodluck.
Jan 29, 2010 | Panasonic DMP-BD60K Blu-ray/DVD Player
Pioneer dvd r/rw wont play a dvd
If your computer recognizes a disc in the drive and operates normally, Id assume you would need a DVD player or codec to be able to actually watch the DVD. PowerDVD rings a bell.
Have you tired that? I know Windows Media Player by default wont let you watch a movie without first downloading a codec.
Mar 19, 2009 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
Dvd player only plays some movies
it might be sevral reasons:
1. Check if region code is the same for movies you playing and DVD player
2. If you using video CDs or copyed DVDs, player might be preventing to playback those kind of discs, due to copyright laws or due to different speed settings for DVD player and discks you using (for intsrance you player can playback DVD/CD+R, and you using DVD/CD-R, or mximum allowed playback speed is 16 you using disk recorded at 24, but this is in case you using burned/copied CD/DVDs)
3. Check it lens is durty. For that use CD/DVD lens cleaning disk
($6 in Walmart, if you are in US)
4. Check if movies you are have the same coloring system, i.e NTSC for US
5. Check CD/DVD for scratches, some DVD players can not playback scratched disks
Please kindly let me know if my information was helpfull for you or you need more info
Good Luck
Feb 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Dvd troble
some dvd players dont play all dvd. i think the dvd player dont support the format of your dvd movie try a different dvd movie.This msg show up in every dvd you try to play????
Dec 14, 2007 | RCA D52W135D 52 in. TV/DVD Combo
DVD PLAYER NOT READING DISC
Well I have been repairing dvd players a while now and the main problem spots are laser ,spindle motor, laser tracking motor and the biggest culprit and un suspecting one the lens cable .....most of them range from the lens cable to the spindle motor though... the constant movement of the lens in watching a whole movie causes the cable to unknowingly and slowly break and if the spindle motor is defective ,on inserting a dvd the disc spins slowly and you may hear the lens chirping ... so you can check those....
Oct 06, 2007 | Onkyo DV-S535 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
70 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
