Question about Proscan 19LA25Q 19 in. LCD Television
I need a new power supply.
I need a power supply for LCD Proscan 19LA25Q, because the one than the LCD has is damaged. Please let me know, where I can purchase it and price. I live in Puerto Rico, but I can purchase through Internet.
  • darkfire963 Apr 28, 2009
    any of those power supplies should fit in mine correct? i have the same model 19LA25Q
    New Friend:
  • 42 Answers
What is Proscan 15LA12Q power supply output voltage and amps?
UpBright NEW AC Adapter For Proscan 19LA25Q 20LA11Q 15LA12Q LCD HD TV DC...
Price:$18.54 + $5.89 shipping
First check it or have the power supply check out with a meter. If you have 0 volts or it is dead then replace it. The main thing is the polarity of the tip, positive tip or negative tip IT MUST BE THE SAME or you will FRY YOUR TV. Good Luck.
Jun 04, 2015 | Proscan Televison & Video
Remote code
These are the Proscan codes I can find: 0047, 0060, 0760, 1060 Let me know if they don't work.
Sep 09, 2007 | Proscan 19LA25Q 19 in. LCD Television
I need a ivt-0406-01 power adaptor for my Proscan 19LA25q. Please help!
Look for 120 volts ac input and 12 volts dc @ 5 amps with the + connection in the center (hole) of the output connector. Fine at ebay , price about $ 8 US
Mar 17, 2011 | Proscan 19LA25Q 19 in. LCD Television
I bought my 19" Proscan LCD (19LA25Q) used from a
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See https://www.amazon.com/Original-Proscan-Control-E20F-19LA25Q/dp/B00KQVDRNK and https://www.amazon.com/PROSCAN-Replacement-Remote-Control-19LA25Q/dp/B009H5QVIO . Remotes.com also has a replacement remote: http://www.remotes.com/SearchResults.asp?Search=19LA25Q .
I hope this helps.
Apr 21, 2017 | Proscan 19LA25Q 19 in. LCD Television
Need new power cord and remote dog chewed proscan model # 19la25q where can i get them at
Try website 1-800-Remotes Factory original.For the remote.Try Partstore.com,Amazon.com,and Shopjimmy.com.For the A/C power coard.
Jan 01, 2010 | Proscan 19LA25Q 19 in. LCD Television
Proscan 19la25q 19in lcd
Is there a red L-E-D power light beneath the screen? that is the power off light(red). Watch closely to see if that red light momentarily turns green and then immediately red again when you are attempting to turn the tv on, that indicates a bad power supply. There are replacement power supplies on ebay. Be sure that the positive (+) is the center hole of the plug. Most likely all of them are. The output plug is 5.5mm x 2.5mm in size.
http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
Mar 08, 2009 | Proscan 19LA25Q 19 in. LCD Television
Proscan 26LA30Q-screen will not turn on
This might help you
Proscan 19LA25Q 19" LCD HDTV at Crutchfield.com Proscan 19LA25Q 19' LCD HDTV: Detailed Info, Features and Specs, and Photos. ... Instruction Manual; Product Registration Card; Limited Warranty Card ...
www.crutchfield.com/ISEO-rgbtcspd/App/Product/Item/Main.aspx?i=68319LA25Q - 46k
Mar 30, 2008 | Proscan 19LA25Q 19 in. LCD Television
Remote
This might help you.
Proscan 19LA25Q 19 in. LCD Television Logo
414 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
